#31 (permalink) | |
I would actually like to see the VIS dyno test preformed on a 3.5 RL stock motor now.
I know we can squeeze 250whp from these motors N/A. I'll be making a hybrid T2 intake manifold as part of my turbo build, it probably wont be dyno'd N/A however. On the pre-ems dyno graphs when using the stage 2 bayou type 1 ecu, fuel correction was handled significantly by the AFC. Hey Eric, I should of printed out the overlay of my 316/345 over yours and mine N/A dyno, that would have been real interesting to dissect ![]() ~Dv8 Quote:
#33 (permalink) |
I'm the Stig!
exactly, removing the VIS showed LOSS of power and torque. we SHOULD all keep our vis.
#34 (permalink) | |
Suffering in the low end, but in between the other two canidates, low and high. I consider it the better blend of the test. An overlay of no VIS(no: 09) and best dyno (no:14) should have been done. For those interested in topend & peak power on a manual 3.2 and not concerned with daily driving, no VIS is actually best. Matt's compromise of switch activated flaps might be even better. ![]() ~Dv8
#35 (permalink) |
Type II King
yea i think if we had a switch to open all flaps at 5200 rpms, but keep the flaps working at the lower rpms, that would be the best setup, as far as just removing the flaps... there is a big loss of lower end power and its not worth it.
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, safc II, strut bar, F/R sway bars, FL tie bars, ksports,tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA |
#36 (permalink) |
Type II King
unless thats pretty close to where they both open normally anyways... we could find out my just printing out my normal vis system dyno with these to tell
#37 (permalink) | |
legend status
But anyway, awesome stuff guys. I think it's safe to say that the midrange of the 3.5 is definately the determining factor when you line those two cars up on the street. I'd also like to point out that the dv8 N/A 3.5 dyno (after EMS) is almost identical to a stock 350z dyno, not bad at all! Last edited by acc-unit : 10-23-07 at 01:30 AM. |
#38 (permalink) | |
I'm the Stig!
I'd like to see a dyno of a 3.5 (with its stock head) with a similar setup to these guys. that should be a interesting comparison. and i defiantly agree that we CAN make better use of our flaps.
#39 (permalink) | ||
Yes. The crank labrat pulley weights around 2-3 lbs. On a type II thats a 7-8lbs difference(10lbs). The other 3 pulleys(PS, AC, ALT) probably account for 3/4 to 1 lbs together in savings. Kyle wrote it all up somewhere. The whole kit makes a big difference, I only have the PS and ALT pulley. Beating up on 350z and G35's is what i pride myself on ![]() Quote:
~Dv8
#40 (permalink) | |
Of the Telion Chip
#41 (permalink) | |
Legend Agent
I never said the gains with the type II heads were insignificant, I just questioned whether it was actually worth all of the work with frankenstein-ing the intake manifold and water passages. Also, Kenso discovered that the TII cams and stiffer springs would drop right in to the 3.5 heads. The basis of my questioning it was Kenso's type II manifold upgrade dyno. He got 90% of the benefits of the Type II motor just by upgrading to the TII manifold. There is also the issue of the 3.5 heads having a less robust valve train. I would like to see an expert comment on what the suggested upper RPM limits would be for the 3.5 heads. -Matt
The dude with a chip on his shoulder. Stop asking me to compare my chip with Telion's damnit. Mines better. No, really, stop asking ![]() The Legend Garage |
#42 (permalink) | |
![]() Did those type 2 springs in a rl head actually work? Wern't people snapping bolts? ~Dv8
#43 (permalink) | |
Legend Agent
I'm pretty sure telion has TII cams and springs installed in the 3.5heads. Swift supposedly had them also. The reason telion was snapping the bolts was because the tapped hole in the head was filled with oil preventing the bolt from going all the way down (hydraulic lock). -Matt
#45 (permalink) | ||
My EMS pwns you!
![]() Quote:
Power falls off before 7k anyway. N/A better springs aren't really needed and eric's dynos prove that.
__________________ AEM EMS Powered. 9 yrs and counting. Results, Where are yours? 12.953@107.865MPH 95 deg. Jun. 07' 3.5 6spd-#55 jet Nitrous 316WHP@5500RPM 345Lb-ft@4100RPM NOS 06-07'N/A 234WHP@5700RPM 229lb-ft@4600RPM 06-07' 13.782@99.135MPH N/A 95 deg. Jun 07' 03' G35c Auto Vortech Supercharged pshhhh 311WHP 274WTQ13.1@102MPH-on the brakes(108MPH) Hand fabbed Go-Kart 18whp 24wtq 8 page spread Honda Tuning 09-06' issue PM or |
