Old 11-07-06, 10:08 PM   #1 (permalink)
Renaissance.
whats77inaname's Avatar
Car 1: 91 5MT LS, 271k
Car 2: 91 5MT LS, 183k
Car 3: 03 G35 sdn (wife's)
3.5 swap questions
1) Christian, if I'm not mistaken, you're using Type II heads, whereas Diaz, you used the entire RL setup. Why did each choose the heads you chose? Advantages/disadvantages?
2) Am I to assume that the pulleys on each (3.5 vs. 3.2) block differ?
3) Both of you are using Type I ECUs, correct? No CELs?
whats77inaname is offline
Old 11-07-06, 10:11 PM   #2 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
IMO the RL heads are the way to go but enlarge the valves and get the cams redone.
~Alex
Alperovich is offline
Old 11-08-06, 12:35 AM   #3 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
If you use Legend heads the intake manifold won't fit (Legend or RL manifold) unless you widen the manifold. Same goes for the coolant passage in front of the manifold.
The advantage of the RL heads is that the manifold will bolt right up as normal. Disadvantage is the smaller intake valves (same size as Type 1) and weaker valvesprings (roughly equivalent to Type 1).
The Type 2 heads have the advantage in every way, except for the rather big problem of the manifold fitting.
The crank pullies are different and will not interchange.
The best of both worlds would be reworked RL heads with Type 2 intake valves and valvetrain, along with Type 2 cams or regrinds. Not cheap I would imagine to have the headwork done to fit the larger valves.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 11-08-06, 09:16 AM   #4 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
The quote I got on mating the Type II valvetrain to the RL heads was $600. I really need to send my stock RL cams out for a regrind.
Ken, can you look up to see why the 02-04 RL engines had more horsepower and torque than the 96-01 engines? I'm wondering if they did anything to the heads or cams to get that extra push.
The Crank pulleys are totally different.
I'm using a totally stock Type I ECU. The only reason I have a check engine light is because my EGR valve is blocked.
I chose the entire RL setup because it was a lot easier than having the intake manifold customized, and having that water neck extended. I didn't have access to Type II heads either. Bone stock, my engine pushes 225 hp and 236 lb ft torque at the flywheel.
Mike Diaz is offline
Old 11-08-06, 11:14 AM   #5 (permalink)
Dv8
Get sucked in...
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Whats777,
Its like Ken said. I did the type II head route because I saw the RL heads and the internals looked different to me back then. No one had done it and someone like ken wasnt around to tell me the differences between the two. I had a chiltons book that showed valvetrain specs; the TYPE II was superior to both the RL and Type I, so I wasnt going to pay for the RL heads if i didnt need them. I had no idea that the Type II heads were going to offset my manifold, but they did and i dealt with it by widing the manifold. If i would do it again i would have reworked the RL heads to have all the TYPE II componets fit. I want every ounce of power out of my motor with the options that are redily avalible. I may still do it whenever i pull the motor again.
Until Mike D dynos, we dont have a comparrison as to what the heads really do. I have a lot of dynos from when i first did the swap to now with headers and cams ect. so i would be really curious to compare Mike's progresses from stock to headers and cams.
So mike, you need to dyno.
~Dv8
Dv8 is offline
Old 11-08-06, 11:51 AM   #6 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Originally Posted by Dv8 View Post
Whats777,
~Dv8
I'm working on it. I need to get moving before it snows. My car doesn't know what snow (and salt) looks like.
Old 11-08-06, 12:25 PM   #7 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
I caught Mike's video on Youtube the other day,
and damn that coupe has balls! The 3.5's low-end
is vastly greater than the 3.2; both you and DV8 have
no problem roasting tires.
Ken--have you swapped yet?
k.
mrkeith is offline
Old 11-08-06, 01:05 PM   #8 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
k.
I can eat up a set of tires pretty damn quick. I can pull smoke until the middle of 3rd gear.
Old 11-08-06, 01:22 PM   #9 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Dyno results coming tonight. I finally got in at my buddy's shop. $50 for 3 runs.
Old 11-08-06, 01:55 PM   #10 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
/\ sweet mike! thats a pretty good deal too! can't wait for the results!
~Alex
Old 11-08-06, 01:59 PM   #11 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
I don't have an extra O2 bung, so he said he's gonna use a sniffer at the end of my exhaust pipe.
Old 11-08-06, 07:38 PM   #12 (permalink)
Renaissance.
Good deal. I picked up a 3.5 long block, and before anything goes in, I'm curious to see how this stacks up against Christian.
Old 11-08-06, 08:40 PM   #13 (permalink)
Dv8
Get sucked in...
Dv8's Avatar
am i allowed to make a guess?
here goes:
1-250whp
1-250lbft
no seriously
185WHP
210LBFT
give or take 10 on both....
~Dv8
Dv8 is offline
Old 11-08-06, 09:18 PM   #14 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
From my PM to Christian:
max power = 187.64
max torque = 218.37
My air fuel ratio was between 12:1 & 13:1 the entire time. My torque curve is horrible because of the fluctuations in the air/fuel ratio.
There's at least 4 major dips in the torque curve. Torque and horsepower maxed out at 5200 rpm.
I have to scan the sheets at work. I have a lot to work on, that's for sure.
Old 11-08-06, 09:22 PM   #15 (permalink)
Renaissance.
1) Is the car starving for fuel at any point?
2) How steep is the drop off after 5200rpms?
3) SAFC coming?
In comparing your numbers and Christian's numbers, it tells me what I needed to verify: with an RL motor, and a few mods, it is possible to have a mid 14 sec. Legend, which is my goal.
Mike, I know you don't have headers. Do you have an exhaust? Any other mods besides the air intake?
