Of the Telion Chip
Ewwww I like I need a tranny, Yes use your Legend harness but you will still need the TDC wiring from the RL harness if you wanna make an adapter without cutting your existing harnesses TDC sensor wire (I think) but also Yes you can find a JDM RL engine not sure what the differences are or even if there are any but that is what I have in my car. There is also another wire that will possibly need to be extended and brought over from the other side I am trying to remember what it is I believe it is the coolant temp sensor on the water passage
\/Provider of The Telion Chip click here\/ http://telionsite.com or search Telion Chip 3.5, TII cams,pnp mani & springs,Telion Chip,HID's,H&R's/Koni's,Addco Sway bars,TII calipers,RH C2's,R.J. shifter,DV8 EGR plate,CAI,OBX headers,2.5" exhaust,hi-flow cat,K2 muffler,Stage III clutch,S&D rotors, KVR pads, blackend damper, a CF hood, AFC NEO, 3.5 Aluminum pulley, & Web cams. C&R Racing radiator and more to come. Last edited by Telion : 06-01-07 at 12:26 AM. |
| Does anybody know about these Wiring Harnesses? | EZgoinLegend | Aftermarket Parts | 1 | 01-30-07 06:54 PM |
| Sedan Headlight Wiring | 93LegendSedan | Second Generation Legend (1991-1995) | 5 | 04-07-06 01:13 AM |
| McCulloch HID KITS - Wiring Harnesses now available | TriPPiNDaNE | Group Buys | 18 | 11-07-04 11:55 AM |
| Bose amp wiring adapter | James92LS | Audio, Video, & Electronics | 1 | 08-12-04 05:35 PM |
| Need expert help with driver's door panel Wiring! | Dethred | Second Generation Legend (1991-1995) | 2 | 08-05-04 02:20 PM |
