Old 11-13-07, 05:21 PM   #1 (permalink)
Car 1: 1992 LS Sedan - 3.5
3.5TB and TII manifold
I'm getting a manifold from Forevralegend without the TB, so I'll be using the 3.5 TB.
The fast idle valve is relocated, so would I just plug it up on the TII manifold and use the connection on the 3.5? Vice versa? Would the internal configuration not let me do it this easily?
FallenAngel is offline
Old 11-13-07, 07:21 PM   #2 (permalink)
Type II King
Forevralegend's Avatar
Car 1: 94 Legend Gs type II
dont use the 3.5 tb use any from a 3.2 legend, there is one on ebay right now for like 20 bucks, its being sold by a member in this forum, or you can get one from your local junk jard.
mods-
Forevralegend is offline
Old 11-13-07, 10:46 PM   #3 (permalink)
Def. a solution, but I'd prefer it if it were posible to use the 3.5. Can any mechs chime in?
Old 11-13-07, 11:03 PM   #4 (permalink)
Legend Agent
sr5guy's Avatar
Car 1: 95 BMW 740I
Car 2: 91 L Sedan Rosewood
Car 3: 91 LS Cpe 3.5 *sold*
No, do not use the 3.5 TB. It has different vacuum ports and will cause an idle issue. Also, the TPS sensor is calibrated differently. There is no benefit to using it and the EVAP fuel inlet is also a different size. Need I say more?
-Matt
No, really, stop asking
The Legend Garage
sr5guy is offline
Old 11-14-07, 03:47 AM   #5 (permalink)
Dv8
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
T1 or T2 TB
plug it up. Youll have to extend a sensor wire or two.
~Dv8
Dv8 is offline
Old 11-14-07, 03:58 AM   #6 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
If it is a TII manifold and you are using the TII neck (don't know the real name, part between the TB and the manifold) then you need (would be best off) to use the the TII the ports on the TI TB/neck and TII TB/neck are different where the gasket mates the two. The TII has more. Anybody have a pick of what I am talking about?
Telion is offline
Old 11-14-07, 12:08 PM   #7 (permalink)
Type II manifold.
what about the fuel line, "RL fuel rails, fuel pressure regulator, and fuel damper" >> guessing it back to Legend parts. Sh**
Old 11-14-07, 12:40 PM   #8 (permalink)
Of the Telion Chip
Telion's Avatar
Find some close ups of my engine bay Here you go was faster for me to.
Originally Posted by Telion View Post
Ok so I had a request to show the TI headers and Y-pipe mounted to the engine. Trust me in the fact that this was my third choice for this part of my exhaust setup right here but my primary choice the OBX headers I cannot afford right now, and my secondary choice was teh RL headers but I had a bolt strip on me, so for the sake of time I did this. Eventually they will be swapped out for a custom Y-pipe (Ko) and OBX headers. that would compete the exhaust setup on my car. And I don't know if people previously said whether or not the (TI) headers fit but they do. And oh yeah the header heat shield for the RL has a beefier look.
Disclaimer: I am not the cleanest at home make-shift mechanic<--term used loosely
Now in a soft whisper like in the movie Alien. . . . .
"Release me!"
Telion is offline
N/A intake manifold mod TheMadScientist Engine & Performance Modifications 77 07-31-08 02:04 PM
Intake Manifold knucks3man OEM Parts 2 05-26-06 04:14 AM
PLEASE! Where is the egr manifold pipe and manifold,can I do this! New navigation too clean_customs First Generation RL (1996-2004) 0 06-26-05 01:19 AM
oil in intake manifold??? RangerJoe Second Generation Legend (1991-1995) 7 02-23-04 03:26 AM
just got my intake manifold Dan88Legend Engine & Performance Modifications 18 04-28-03 12:49 PM
