Old 07-19-06, 06:30 PM   #1 (permalink)
Tristate Committee Member
aww-shiet's Avatar
Car 1: 94 Acura Legend L Sedan
Car 2: 93 CB7 Turbo
Car 3: 1988 Acura Legend L
Send a message via AIM to aww-shiet
7-8k rpm legend
Is there anyway we could build it to make it up that high. I forgot what kenso's rpm is and DV8's but hope its pretty good.
ohh i just noticed i hit 222 posts
aww-shiet is offline
Old 07-19-06, 06:40 PM   #2 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
haha ur sig was too big ... also congrats on the 222. kenso's car rev's past what it says on the tech. so it might be just that high!! check with him though.
~Alex
94 GS
Alperovich is offline
Old 07-19-06, 07:36 PM   #3 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
thanks alex and thankyou administrator
Old 07-19-06, 07:59 PM   #4 (permalink)
Car 1: 1994 Legend Coupe
Send a message via AIM to Joe E - Florida
I made a thread about it a long time ago.
All you really gotta do to rev to 7k is get a chip.
If you want 8k.. you might want to rebuild your heads with some performance parts... only problem, there aren't any for the Legend
Bad at math? 6.5 yrs and Im still slow.
Below are results, not that great, but results.
14.109 @ 101.46
OE - 179.9WHP and 153.7 Ft Lbs on Chrome 215/45/16 Wheel
AUG 04' - 190.7 whp and 177.9 ft lbs
CAI and ASP Pulley on 18" Konig's 225/40/18.
227.4 WHP and 221.1 Ft Lbs - Empty Bottle
30.17-0.59 in.Hg. @ 96ft CF=0.99
APPROX 3,000 total posts total w/20+ usernames
Joe E - Florida is offline
Old 07-19-06, 08:03 PM   #5 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
yeah but at that high rpm you need to change at least ur cams in order to produce power at that rpm
~Alex
94 GS
Old 07-19-06, 08:14 PM   #6 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
dude you just hit 222 also. this is a werid day. thanks for the info.
Old 07-19-06, 08:17 PM   #7 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
wow that is kinda wierd
~Alex
94 GS
Old 07-20-06, 12:36 AM   #8 (permalink)
Pedobear is watching you
tnelson's Avatar
Car 1: 2002 TL-S, white
Car 2: 1992 Corvette
Ok, currently, no, the legend has a fuel cut at 7 ish. So no, it wont rev there unless you have a chip. If you have a chip, unless your powerband is way up high (ie, short runnered intake manifold(not ~19 inch like a stock type II, or 23 ish like a stock type I) you need more like a 10 inch) and it would be nice to have it matched with a set of headers with fairly long but not huge primaries and cams with enough lift and duration.
Yes, you could rev a legend engine to 8500 or better, but you need to speak with buzzard about the valvetrain. There is some conversion needed to get it up that high consistently and reliably.
The bottom end will be fine, as it is a fairly high bore:stroke ratio. And a legend tq. band tends to fall on its face around 4500, so unless you use a custom manifold and possibly headers (or manage to boost the hell out of it) to shift that powerband, good luck.
tnelson is offline
Old 07-20-06, 02:22 AM   #9 (permalink)
Car 1: 1993 Gray Legend Sedan
I can chip the ecu to go as high as you want, at least as long as its manual so you can acturally shift when you want. Stiffer springs would be needed to safely keep the valves from floating much higher than the stock revlimiter. Cams would be the first thing to getting it to actually make power any higher. Somebody was working on a cam gear, on a sohc that could be used to shift the power band up a little bit with the stock cams at the sacrifice of low end torque. If you just wanted to rev a little higher and maybe gain a little HP up top that might work.
beav is offline
Old 07-20-06, 02:26 AM   #10 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Car 2: 91 Legend L - parts
Car 3: 96 Honda Saber 32v
Send a message via AIM to Ken
theres no point in reving that high if you're not producing power up there
. k e n
Ken is offline
Old 07-20-06, 02:37 AM   #11 (permalink)
tnelson's Avatar
tnelson is offline
Old 07-20-06, 09:40 PM   #12 (permalink)
'hood Garage
hotlavaflow's Avatar
Car 2: KA24DE-T S13
Originally Posted by tnelson
Ha ha ha ha ha ha
hotlavaflow is offline
Old 07-20-06, 11:18 PM   #13 (permalink)
badintentions's Avatar
Car 1: 1994 gold Legend 6spd 2dr.
Car 2: 1956 mg td-sold
Car 3: 03 RC51
Send a message via ICQ to badintentions Send a message via AIM to badintentions
a typeII with a stage II chip will rev out to 7800 (manual) you can tell you don't make power past 7.
94 l gold 6 spd (sold)
-Ranger Joe CAI -obx headers
-polished intake manifold
-Bayou stage II -FUT's lower tie bar brace
-Magnaflow exhaust -MLS strut bar
-5spd clutch and flywheel
-Ksport coilovers -Addco rear sway
-17" Arospeed rs-gt
94 l sedan 5spd.(totaled)
SAY NO TO THE COMB OVER 08'
badintentions is offline
Old 07-25-06, 04:38 PM   #14 (permalink)
Dv8
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Im making above 200WHP past 7k with the cams. My rev limit kicks in soon thereafter. I bet it would push right through 7,500k still at 200WHP.
Wonder if Beav can cut the rev limit out of my bayou chip.
~Dv8
Dv8 is offline
Old 07-25-06, 05:37 PM   #15 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Dv8--
I recall your dyno sheet vividly, and remember thinking
that you should able to run faster quarters with a higher rev.
By the way, I have been showing off your videos to all of my friends
Fucking sick to say the least, man...
k.
mrkeith is offline
anyone have a carfax subcription here? LGNDARY978 Second Generation Legend (1991-1995) 15 11-22-06 02:10 AM
Acura Legend fact sheet.(stolen from G2 section) zany First Generation Legend (1986-1990) 2 06-12-06 07:30 PM
Legend Graveyard Brent85 All-Legend and RL Gallery 11 02-06-06 03:59 PM
ECU Codes - blinks 3, mechanic says 30 90LS90 First Generation Legend (1986-1990) 12 07-14-05 01:00 AM
Guess who's back in the Legend Family??? SammyD Second Generation Legend (1991-1995) 46 08-27-02 09:15 PM
