85% tuned.
I finally got all the right peices to my puzzle called the Direct port system. Took it to the dyno and at least got a semi tuned run. Now i need to fine tune it.
Looks as though I have work ahead of me. The peaks and valley's between 2600rpm-3700rpm are products of the legend ECU tring to figure out to do with the timming. Eventally at 3800 rpm it figures it and rolls with it. The Tuner told me that i should really look in to finding a way to retard the timming. even if im running rich i could sill detonate becasue it could be too advanced. Something that struck the tuner very odd was the fact that at 5800 rpm all power drops off. He says that with Nitrous it should make power for long after peak is achived compared to NA. However not exactly the same cutoff compared to N/A, but pretty close the power dies off all at once no matter what you do to the A/F. The fine tuning needed is to step up the Nitrous jets one up and step one lower on the fuel(if even made, i think i already have the smallest). With the apexi tuned, fuel pressure adjusted, and pretty much the smallest jets for fuel in NOS existance, the A/F still ran way too rich between 3300rpm-5800rpm At least the tuner said by the amount of TQ and WHP i have If i were to have full traction it would be good for a mid 12 second pass. I'm wating for UPS to show up with my slicks. The two Dynos are to types of tuning configurations, both with their own strong point ans disadvantages. One makes more peak power while the other makes more all around. 305HP 335LBft Flywheel power@15%loss ~TRu Hybrid
AEM EMS Powered. 9 yrs and counting. Results, Where are yours? 12.953@107.865MPH 95 deg. Jun. 07' 3.5 6spd-#55 jet Nitrous 316WHP@5500RPM 345Lb-ft@4100RPM NOS 06-07'N/A 234WHP@5700RPM 229lb-ft@4600RPM 06-07' 13.782@99.135MPH N/A 95 deg. Jun 07' 03' G35c Auto Vortech Supercharged pshhhh 311WHP 274WTQ13.1@102MPH-on the brakes(108MPH) Hand fabbed Go-Kart 18whp 24wtq 8 page spread Honda Tuning 09-06' issue PM or Email only. Respect that! My Legends Website www.2slik4u.com Last edited by Dv8 : 07-31-04 at 09:01 PM. |
That is beautiful man. I will one day harass you and hire you to help me with my car.
-Vinh
Aegean Blue KA7 w/ an Evolution Exclusive body kit Custom crystalized JDM one piece headlight Carbon fiber hood Type II engine 2 1/4 mandrel bent cat back exhaust. Type I Bayou stage II ECU - A'PEXi S-AFC II Walbro 255lph Fuel Pump 17" Enkei CDR9 on Fuzion ZRi Eibach Pro-Kit/Koni Special Struts, front & rear KMS Front Tower Bar Addco Rear Sway Bar Front STS Cross drilled/Slotted rotors Goodridge Steel Braided Brake Lines |
#6 (permalink) | |
Limited Quantities
to your Legend! DV8 ![]()
<form action="https://www.paypal.com/cgi-bin/webscr" method="post"><input type="hidden" name="cmd" value="_xclick"><input type="hidden" name="business" value="debbiewhelan@bellsouth.net"><input type="hidden" name="item_name" value="Help Pay For Forum"><input type="hidden" name="item_number" value="forum1234"><input type="hidden" name="no_note" value="1"><input type="hidden" name="currency_code" value="USD"><input type="hidden" name="tax" value="0"><input type="image" src="https://www.paypal.com/images/x-click-but21.gif" border="0" name="I1" alt="Make payments with PayPal - it's fast, free and secure!" width="110" height="23"></form> There is only one LEGEND! We may never see another one like it! |
I was thinking about your 3.5L. and you say you are running the legend ecu, I was thinking that you might need to go to the rl ecu because of the 300cc difference wouldn't that mean that your spark and the hole air fuel ratio is of by 300cc. short of full stroke. I mean you would not have spark and fuel at the right time because the ecu still thinks that it is a 3.2L so you correct me if i'm wrong but that sounds like the problem to me on your tuning ussies. Since these's motors do not have distributors it relies on the ecu right so that could be why it just shuts power off at that rpm and your timming seems to be off alot. I thinks your idea with the 3.5L is a outstanding idea I want to do it my self but just waiting for the bugs to get worked out of the swap first.
#8 (permalink) | |
Thanks ALL its been quite some time. The RL ecu is OBD2 thus restricting me to tring it because it would throw all kinds of codes. The air and fuel arent the problem since the Nitrous supplies both its own and the AFC is being tunned according to the wide band 02's readings. the timming is the only entity thats not yet tunable. I have to find a tunable timming unit that intercepts the signal form the ecu and modifys it to my specifications. Dethred, I remeber talking to willy a while back about timming. He told me that it wasent modified in the chip over stock. Ill have to look into what MSD can provide along with APEXI etc. I also should lookinto a NSX ECU and see what its like. I know its DOHC but i know that it can be programed any which way. ~TRu Hybrid
It would not be that hard to swap out the wire harreness and ecu and some of the sensers if you could not find such a thing to interciept the timing then you would have obd2 that could have it's pulses. But i really think you have 15-20hp and 10-15fbt left to unleash when you get this timming right. The timming being off is not going to change very much on the torqe but it will smoth it out nicing. The big difference is the hp rating i think you will see a big jump in numbers there, you might even get power at higher rpm. Those are still very impressive numbers will the timming being off 300cc's. I think all you would have to change with the sensers is the map,o2,tps, maybe crank senser and maybe egr valve. I would think they would share alot of the same sensers, the wire hareness would not be that bad to do but you can't do any of that inless rl's had manuel transmissions I don't know if they did or not but there is got to be something out there I know that some msds you can retart the timming you should try and check one for a new z06 vett the have simular coil packs i'm sure you could find a universal one., but good luck let us know what you found.
#10 (permalink) | |
Hi! I'm Ryan.
English Please? DV8: I could have sworn he said there was a timing increase. If not then awesome. I wonder if there is anyway to mess with timing like those Cheap ebay timing advance kits supposedly do... point being are there any possible wiring/resistor options available before you have to dump money into a new ECU or more in depth tuning? |
#11 (permalink) | |
I need more like 6-8 degrees retard upon Nitrous induction. ~TRu Hybrid
No matter anyway you look at your timming is off by 300cc beacuse the legend ecu thinks it is still a 3.2L. So I was thinking about this pretty hard and you don't need to buy anything because all you have to do is move the timing belt one tooth and the legend ecu will be fireing pretty close if not dead on. And you won't throw any codes because it is off 300cc right know so I think you could get that back by one tooth one the belt and the rest on the timing adjustment on the firing wall but you are going to need to re-adjust the fuel ratio because you were off that far when you tuned it. but just make sure when you change it one tooth you spin the motor over at the crank just to make sure it has clearence but I'm pretty dam sure it will. let me know your feed back on this, you could do a commpresion test and you will see the the valves are not closed all the way at the right time, does your starter sound like it spins a little bit easyer then it should be. I can't belive I did not think of this when you said the RL as one more tooth on the belt, it will work if not it will work alot better then it does now.
The Mac vs. The Mack
anyways,
C: I think the problem is the timing not because the engine is thrown off but because of the rod speed. the current timming is set to fire at smething like 20-40 degrees BTDC. where the rod speed of the Legends. supposedly, i read a while back that an engine with a too high rod speed with bad timming can out run the flame. no matter how much you put into it you end up on the ragged edge. Jay, you have a misconception of how a stroker engine works the engine spins at the same speed the pistons are at TDC and BDC at hte same time just on the 84mm stroke of hte Legend the piston stays at TDC and BDC longer than the fast moving 91mm stoke of the C35
"Untainted by Concept of Limitation" -BozzSpeed ![]() -Reiko my baby -The MAIN person Thank you Leon. Your words help God said it, and it was so. Forum Rules flossin, breakin off the intersection crossin
RL'in, ackin a iz-ass on them bosses |
#14 (permalink) |
if you move the belt one tooth it is the same thing as if you turned your distributor you are making the valves open at a different time that is why it has teeth on it the valves and pistons need to move at the same time or else or timming is off so you adjust 6-8 degrees by altering that valve and piston time I'm not saying you can do this on any thing but i think this might bring his timming a little closer then it is. correct me if i'm wrong but i think the crank senser should control where and when to spark.
#15 (permalink) | |
So your right i could physically move the belt one tooth advance or retard, but thats dangerous, because if the ECU decided to do +/- on the timming, it in addition to the belt being one toth +/- could mean serious trouble. You have to understand another thing about the legend, the crank sensor is behind the driver cam sproket, not on the block. that there proves the extra displacement donesnt matter to the ecu if its a 3.2 lt or a 4.0 as long as the sensor is reading the same rotational signal everythings good to go. So bottom line, i'll call MSD on monday and see what they can put together for me. TRu Hybrid
AEM EMS Powered. 9 yrs and counting. Results, Where are yours? 12.953@107.865MPH 95 deg. Jun. 07' 3.5 6spd-#55 jet Nitrous 316WHP@5500RPM 345Lb-ft@4100RPM NOS 06-07'N/A 234WHP@5700RPM 229lb-ft@4600RPM 06-07' 13.782@99.135MPH N/A 95 deg. Jun 07' 03' G35c Auto Vortech Supercharged pshhhh 311WHP 274WTQ13.1@102MPH-on the brakes(108MPH) Hand fabbed Go-Kart 18whp 24wtq 8 page spread Honda Tuning 09-06' issue PM or Email only. Respect that! My Legends Website www.2slik4u.com Last edited by Dv8 : 08-02-04 at 06:22 AM. |
| HELP!Engine Light ON:Machine test shows no problem!So I tuned her up! But still on??? | Legend"11 | |||
