#16 (permalink) |
Your not getting quality responses because you didnt ask in the correct section.*Moved*
This one has been discussed before as has the CL Type S comptech flywheel. The NSX wont work, forget why, you can search, while the CLS has a strong chance of working for 1k+ I actually went to comptech a while back with a legend dual mass flywheel and compared it to the CLS and NSX alongside a shop engineer. ~Dv8
#17 (permalink) |
Soon to be BOOSTED!
Car 1: SOLD:91' Acura Legend Sedan LS Car 2: 94' GS 6 Speed Car 3: 94 GS 6 Speed(CLONE) iTrader: (52)
I still have to check the bolt hole locations and the width of the crank shaft. If the NSX flywheel bolts up do you think it would be possible to use a NSX clutch.
SIG BY ALPEROVICH MODS---ALL OF THEM!!!!!!!! Check out my gallery! http://www.acura-legend.com/vbulleti...ebirth-126357/ The project... http://www.acura-legend.com/vbulleti...thread-120596/ Ksport Kontrol Group Buy!! $760 Shipped http://www.acura-legend.com/vbulleti...ed-123764-new/ |
#18 (permalink) |
Soon to be BOOSTED!
I just compared the 5 speed flywheel vs the early 90's NSX flywheel that I bought and the bolt holes are identical and the hole for the shaft is the same size as well. The only difference is that the NSX fly is 1 tooth smaller than the Legend fly.
Does anyone think that this would be a big problem? These teeth butt against the gear for the dif correct?
#19 (permalink) | |
Legend Agent
-Matt
The dude with a chip on his shoulder. Stop asking me to compare my chip with Telion's damnit. Mines better. No, really, stop asking ![]() The Legend Garage |
#20 (permalink) | |
Soon to be BOOSTED!
The outside diameter on the Legend fly is 1'-7/16" whereas the NSX fly is 1'-5/16". The Legend fly is almost an 1/8" bigger. The teeth on the Legend fly are slightly more pointy, whereas the NSX is a little more flat. If you place the two fly wheels side by side and join the teeth together they intertwine about half way. Matt, how critical of a difference to you think this is?
#21 (permalink) |
Legend Agent
Why is the match out of the question? Do the bolt holes for the pressure plate line up? If the NSX flywheel is smaller in diameter the starter pinion may not engage properly with the ring gear.
-Matt
#22 (permalink) | |
Soon to be BOOSTED!
I wonder if it would be possible to swap starter gears??
#23 (permalink) | |
Legend Agent
. If the starter doesn't mesh properly its probably going to be a bitch to get it to work. Now you need to compare the height of the NSX pressure plate and see if it will position the clutch to fully engage with the input shaft on the Legend transmission, along with being the same number of splines.-Matt
