Old 02-11-05, 01:42 PM   #1 (permalink)
Car 1: 1994 LS sedan
Send a message via AIM to 94HOTLGND
bayou stage II chip confusion
when buying a used chipped ECU....
is it true that an chipped ECU from a 91-93 auto, different that a chipped 94-95 auto? or is it 91-92 and 93-95? or is there a difference at all?
wtb AT compared to MT? if you have an auto, does it need to be an auto chipped ECU?? HELP??
david
true...true!
94HOTLGND is offline
Old 02-11-05, 01:57 PM   #2 (permalink)
TSX pupils
Car 1: 1995 Legend GS
Send a message via AIM to Daddymac117 Send a message via Yahoo to Daddymac117
yea, there are 4 diff ecus....the ones for the Type I Auto, Type I Manual, Type II Auto, and Type II Manual. But if youre just doing a Type I-Type II swap, you can get away by still using the Type I ECU, but the Type II would still be best. And if youre not sure about the differences between the Type I and Type II, check the newbie FAQ.
and yea, autos need auto ECU, manuals need manual ECUs
FS: Weapon R Secret Weapon intake (NON TCS/Type I) in box, never used. $140 shipped.
I'll make a thread once i figure out the best way to ship it, but PM if interested.
Daddymac117 is offline
Old 02-11-05, 01:58 PM   #3 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
The Type II ECU is different than the Type I,
so they've got separate aftermarket chips.
The auto and manual ECUs are different too.
k.h.
mrkeith is offline
Old 02-12-05, 09:25 AM   #4 (permalink)
werd.....
RangerJoe's Avatar
Car 1: 92 LS coupe 5spd
there are actually eight different ECUs.
type 1 manual federal
type 1 manual california
type 1 auto federal
type 1 auto california
type 2 manual federal
type 2 manual california
type 2 auto federal
type 2 auto califronia
RangerJoe is offline
Old 02-12-05, 10:00 AM   #5 (permalink)
TSX pupils
type 1 auto federal
type 2 auto federal
wow...didnt know that...
whats the diff between federal and california?
Old 02-12-05, 01:24 PM   #6 (permalink)
so if i were to buy a used chipped ECU, i would have to make sure that it is type I auto. i got that so far, but what about the years?? can i put an ECU from a 91, in a 94??
dude, the whole california/federal ordeal just screwed the pooch. please explain!! thanks!
david
true...true!
Old 02-12-05, 02:25 PM   #7 (permalink)
TSX pupils
david
the years dont matter...all that matters is whether the engine is Type I or II and manual or automatic. Switching ECUs from an auto 91 Base Sedan to an auto 95 LS Sedan would work because both are still Type I's and both auto.
Old 02-12-05, 03:16 PM   #8 (permalink)
Old S*hool Member
TCS and non TCS matters too.
Octane is offline
Old 02-12-05, 05:11 PM   #9 (permalink)
cool, thanks for the info. so what's up with that california / federal one??
david
true...true!
Old 02-12-05, 05:17 PM   #10 (permalink)
Car 1: .
david
the California/Federal thing is only based on the required emmisons. A non-CA car can have higher emmieions. If you do not live in Cal. I would recomend any aexhaust that fits your non-CA cars system. Other than that have fun!
Later!
Lee
sleeprlegendcp is offline
Old 02-12-05, 06:40 PM   #11 (permalink)
L E G E N D
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
When you take into acount, 49-state ECUs, Manual VS auto, TCS vs non TCS, you have many many ECUs floating around.
FutureX 2001 is offline
Old 02-13-05, 01:34 AM   #12 (permalink)
werd.....
RangerJoe's Avatar
where did you come up with 49 different state ECUs, california is the only specific one because of their rediculous emission laws. thats where there are cali, and federal ecus.
and i dont think there is a different one for TCS, i think the tcs system runs through the abs and speed sensors on the hubs of the front wheels. but someone could probably correct me on this. the system is very simple compared to stuff you see today.
Old 02-13-05, 02:13 AM   #13 (permalink)
L E G E N D
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
49 State ECU is the Federal ECU. There is a different one for TCS, if you take a NON-TCS ECU out of a Legend and put it in a Legend TCS car, you will get a TCS light come on and possibly a check engine light, same if you reverse it. This is one of the reasons there was many complications when the ECUs were being chipped.
The TCS system might be one of the first systems to come out, but it still uses the ECU to control the amount of RPMs the engine will be able to put out, via the throttle.
from the great MikeD:
as far as I know, that you can use it for the models L to L and
LS to LS (means Coupe to Coupe and Sedan to Sedan). Here is the part No. (Coupe to Coupe and Sedan to Sedan absolute the same.
Caution: You can also use the ECU from the LS Coupe into the L Coupe, but NOT THE OTHER WAY RETURN!!! (Means L Coupe into LS !!!)
And the next different is, if you own an Type II Legend (235 PS). These engins owns an different ECU (because TCS = Traction Control System). The Type II L Coupes donīt have an TCS system !!!
Hope this helps...
Mike / Cologne (Germany)
Old 02-15-05, 05:52 AM   #14 (permalink)
now what about if you have a JDM engine??
true...true!
Old 02-15-05, 06:26 AM   #15 (permalink)
werd.....
RangerJoe's Avatar
we are talking about USDM legends. use a USDM ecu with your jdm motor, it wont make any difference.
Type I Stage 2 Bayou Chip implanted into a Type II ECU NickD Engine & Performance Modifications 29 04-21-05 12:53 PM
Where can I get the Bayou Stage II chip? acurasflagship Engine & Performance Modifications 5 01-05-05 02:40 AM
Bayou Stage II Chip Discussion - Merged CBRKid20 Engine & Performance Modifications 50 01-05-05 02:15 AM
Bayou Chip - Stage I or Stage II pitterchi Second Generation Legend (1991-1995) 6 04-13-03 01:39 AM
My Bayou Stage II Chip - Up for Experimentation dmenn Engine & Performance Modifications 3 11-05-02 02:36 PM
