Old 08-08-05, 06:21 PM   #1 (permalink)
Blk/BlkGS6
Car 1: '94 Black/Black Legend GS Sedan 6 Speed
Car 2: '92 Silver LS Coupe
Car 3: '94 Cashmere L Sedan
Send a message via ICQ to legend4life Send a message via AIM to legend4life Send a message via MSN to legend4life Send a message via Yahoo to legend4life
Clutch Hydraulic System Problems, Slipping SPEC Stage III Clutch-Please Help Diagnose
Here is my problem:
My new spec stage 3 clutch starts slipping, but goes back to normal if I let the pressure out of the system by simply opening the nut on the hardline at the clutch damper, #20 in the diagram, http://www.acuraparts247.com/sunnysi...All&vinsrch=no
after 70-100 miles it will start slipping again, i will open and close the nut on the line at the damper again, and it will be fine again. leads me to beleive there is a leak and air is getting into the system somehow or the fluid is not going into the master/slave or there is some excess hydraulic pressure ? I am thinking of replacing the master cyl #6, slave cyl #8, the clutch hose #15, and also that damper #20 in the clutch hydraulic system parts diagram linked above. Do you think replacing all of these would definitely eliminate the issue?
I am thinking instead of buying a new oem damper and oem clutch hose, to make the hose in stainless braided line, and the damper why not just eliminate it with a stainless braided hose/pipe or stainless fitting where the in and out holes of the damper used to be. Should work fine and cheaper than the oem stuff, and I don't see any other cars with clutch dampers, so it must be a luxury thing, maybe I will get better more consistent and responsive clutch pedal feel or more feedback in the clutch?
Let me know what you guys think. Any advice is appreciated. Thanks!
legend4life is offline
Old 08-08-05, 07:09 PM   #2 (permalink)
Dv8
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Originally Posted by LEgEnD4LiFe
Here is my problem:
check the bleed screw onthe slave cyl? start with replacing the slave cyl and move from there. start with the cheapest and move forward.
Dv8 is offline
no clutch pressure!!!!!! swift Second Generation Legend (1991-1995) 24 10-04-06 02:00 AM
spec stage 3 installed problems Kevin Engine & Performance Modifications 4 09-21-04 04:25 PM
clutch master/slave cylinder in helms RangerJoe Second Generation Legend (1991-1995) 3 12-30-03 01:58 AM
Clutch Prob/Clutchmasters Stage III Question GregB Second Generation Legend (1991-1995) 6 08-14-03 08:45 PM
Stage 1 Exhaust/Headers system is here. Dv8 Engine & Performance Modifications 42 02-06-03 05:46 PM
