#16 (permalink) | |
I guess u guys have a good point, a properly maintained car has no reason to get a BHG.. And when mine does go eventually, I'll get aftermarket ones ( i found a place that sells them for $45 each) and slightly overtorque the head bolts as mike D suggested. I wouldnt mind trying the copper ones DV8 mentioned, 85 bucks per side? |
#17 (permalink) |
I have a '95 and my HG went.
But then again i have 195k on it and some old lady drove it before me.... I belive the radiator went at 75k according to the acura service records... Any way, like i said before, I wish i owned this car from day one, I suffer from OCD when it comes to preventitive maintenance. --=Keith
Some of the most beautiful things in nature have been shaped by the wind - The Acura Legend Coupe |
#18 (permalink) | |
Chris |
#19 (permalink) |
SR79 Labrat
Maybe if I get a rebuild I will do that.....dont I need to pull the engine for that though?
Thx, KTW
Turbo Legend Parts & Project Updates!!! Myspace- http://profile.myspace.com/index.cfm...id=246 854652 |
#20 (permalink) | |
Chris |
#21 (permalink) |
Fre OG
Isnt the RL c35a and c32a us the same head gaskets? I found this online : http://www.scegaskets.com/pdf/pg%2047-51.pdf by SCE Gaskets they have a copper head gasket for the RL this might be an option
#23 (permalink) |
I've been working with cometic gaskets to get a set of Multi Layer Steel gaskets made, I know several people that have had gaskets made by them with great results. I am replacing a buddies HG on his coupe, I have his car sittin in my driveway, as soon as I get these gaskets I will be posting pictures. I also tried getting some headstuds from ARP, I tried 3 different studs, the threads fit, but the length was too short, so with any luck maybe ARP will make a set that will fit.
http://www.cometic.com/ |
#24 (permalink) |
'hood Garage
I didn't realize we were back on the aftermarket head gasket issue. It'll be interesting to see how it pans out this time.
AEM powered Twin Turbo KA7 since Feb'07 |
#25 (permalink) |
Domesticated Redneck
Multi Layer Steel (or MLS) gaskets will work. Most of the Honda 4 cyl use them and they do not blow like the composit gaskets, so I know they will work with the deck design. Just got to have someone to make them. The Mitsubishi Eclipse has torque specs for a standard composit or MLS gasket. the MLS gaskets specs are like 20 to 30 lbs tighter, so if we do have a set made then they will need to be installed with a torque spec similar to the honda 4 cyl w/ an MLS gasket.
Another route that can be taken is to find out where Jasper Engines gets their graphite head gasket that they use when they rebuild a C32A. That company does an amazing job at researching an engines fault and find a way to fix them and make their rebuilds better than OEM. Research their site. What make them a few steps above the rest is that they give you a 75k 3 year no questions asked nation wide parts and labor warranty. Usually when something happens to one of their motors they just send you a new one.
No Mods |
#26 (permalink) | ||
Fre OG
ls92sedan anything ever happen with the MLS head gaskets?
Legend VS. CL/TL Quote:
94 LS Coupe 6 Speed (208k) 92 L Sedan Auto (76k) ATM replaced with 06 RL Rental 92 LS Sedan Auto (156k) parts 92 LS Sedan Auto (177k) project/restoring to factory 00 RL (87k) Traded in for 06 RL 95 NSX-T 5 Speed (75k) |
#27 (permalink) |
guys,
C35 gasket looks exactly the same(everything), but the part #s are different..even if they were the same..then they WOULD have same part number through Honda. So i would say the makeup of the gasket has slightly different materials. I used C35 gaskets and over torqued studs by 2lbs each. PS_ do the 93-95 coupes have a different diff cooler etc....my lines run to the lower part of radiator...just curious. Havent really looked into it. |
#28 (permalink) | |
Mr. Hard to Find!
Soulman: $85 per side is about right for copper HGs. That's what my friend would charge outsiders for them. He only charged me waht it cost for the copper sheets. He used 3 sheets for each side. I guess if you were to use the same kinda term for these gaskets as the Multi Layered Steel gaskets, these would be MLC gaskets. I'd rather use copper than steel because copper disipates heat a lot faster than steel does. Later! Lenny
Thank You, L. Downes O-Town Legends C.C. Winter Haven, FL _______________________ Forum Rules Tapped (Term used mainly in New England) = Crazy + Stupid Contact me at: otown_legends_cc@yahoo.com Last edited by 1_Hot_Legend_LS : 01-15-06 at 11:25 PM. |
#29 (permalink) | ||
Fre OG
where did u get ur headgasket from?
#30 (permalink) | |
Mr. Hard to Find!
Thank You, L. Downes O-Town Legends C.C. Winter Haven, FL _______________________ Forum Rules Tapped (Term used mainly in New England) = Crazy + Stupid Contact me at: otown_legends_cc@yahoo.com |
| Failed 'functional' Ca. emission test (EGR) ??? | Sean L | Second Generation Legend (1991-1995) | 67 | 07-02-05 04:28 PM |
| SOS – Failed Emissions Test – CO to high | Acura4Brent | Second Generation Legend (1991-1995) | 15 | 08-03-03 12:17 AM |
