Old 08-17-08, 03:42 AM   #1 (permalink)
6 Gears
95LegendGS's Avatar
Car 1: 95 Legend GS
Difference in fuel rails?
We now know the type 2 throttle body is superior, and the injectors are all the same and that type 2 FPR is best. But is there a difference in type 1 or 2 or RL fuel rails? Is one better then the other?
Just another boosted legend
Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have "UNLIMITED" RL and Legend Parts PM me to discuss. NO COUPE PARTS, please stop asking
For quickest reply please email me at 95LegendGS@gmail.com Thanks!
95LegendGS is offline
Old 08-19-08, 02:37 AM   #2 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Car 2: 91 Legend L - parts
Car 3: 96 Honda Saber 32v
Send a message via AIM to Ken
Just because the type II FRP is the best doesn't mean everyone should slap one on their type I's because your cars would be bogging like crazy.
. k e n
Ken is offline
Old 08-19-08, 02:58 AM   #3 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
Lets clarify this the Type I and Type II fuel rails are the same. The FPR's are different. One is not necessarily better than the other, they are mearly different in terms of the amount of fuel they flow which is based upon the cams and air/fuel ratio maps. so they should be used in unison TII cams and ECU A/F maps use a TII FPR; TI cams, ECU and A/F map use a TI FPR. now the RL is a different breed all together and seems to work best wih the TI setup unless you have done some other things in the cam department. as fo rthe RL fuel rails I find them far more pleasant to the eyes as far as flowing more fuel I doubt it probably about the same. and any of the above have said to be adequate for more Hp than many of us will ever see.
Telion is offline
Old 08-26-08, 09:01 PM   #4 (permalink)
KA8 Legend Killer
91sedan's Avatar
Car 1: 91 Acura Legend BHG
Car 2: 88 LS Sedan-SOLD
Car 3: 93 Ranger R.I.P
how is it superior?
Mods: Short Ram Intake with K&N Air Filter, Custom Exhaust, Telion Chipped ECU, Type II Manifold (added 12 peak hp and cracked on 7-30-08), Type II Cluster,Throttle Body Coolant Bypass 15.35@91.6mph
Future Mods: OBX Headers,Custom Y-Pipe,Magnaflow hi-flow cat,Stromung B-Pipe,Remus Exhaust,Ported and polished heads and manifold,Web Cam regrinds, 6spd swap All after I Do the 3.5 Swap!! Hoping for a healthy 200whp N/A beast
91sedan is offline
Old 08-26-08, 09:19 PM   #5 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
i was gonna say, you think the TB is superior? i think they are same no? only difference's i found was the upper water passage and the TPS sensor are facing a difference direction.
i ran a type1 TB on my coupe since the rebuild b/c we broke 2 typeII TPS sensors accidentally (wasn't my fault either).
~Alex
94 GS
Alperovich is offline
Old 08-26-08, 11:31 PM   #6 (permalink)
It's stock, really.
FF Drifter's Avatar
For reference, my mechanic also figured that keeping the Type I fuel rails/FPR when I did my 3.5RL swap was also the only way to still let it pass smog. In this same logic, I 'assume' that one would have to keep the Type II fuel rails/FPR when doing the same swap if, in fact, the car was a Type II to begin with.
Messing with the combinations just seems to be begging for check engine lights...?
FF Drifter is offline
Old 08-27-08, 12:36 AM   #7 (permalink)
Registered Libertarian
jkurl's Avatar
Car 1: 95L sedan grn
Car 2: 94LS 6spd cpe grn
Car 3: 67econoline 63nova
kinda curious about the FPR's who can look up part numbers for them, T1, T2 and 3.5 (97-04 RL), I wonder if there is two or three different numbers?
jkurl is offline
Old 08-27-08, 12:40 AM   #8 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
/\ FPR's have a different part#'s, as they are different
~Alex
94 GS
Old 08-27-08, 10:29 PM   #9 (permalink)
Of the Telion Chip
Telion's Avatar
The air porting on the TII TB is better than that of the TI allowing more air into the intake manifold it has one more inlet port than the TI.
Telion is offline
Old 09-04-08, 02:34 AM   #10 (permalink)
KA8 Legend Killer
91sedan's Avatar
That's good to know.
91sedan is offline
Old 09-04-08, 02:43 AM   #11 (permalink)
6 Gears
95LegendGS's Avatar
Car 1: 95 Legend GS
Thanks for clarifying telion, I knew there was a reason but I had forgot. I guess if theres no real difference in fuel rails besides looks I'm going to pick the pretty ones to be chromed
Old 09-04-08, 02:48 AM   #12 (permalink)
legend coupe's Avatar
Car 1: Honda Accord Coupe 92
Car 2: Mitsubishi Eclipse95
Car 3: Acura legend coupe
and what about the t2 tb and the rl tb? i would think the t2 is better as well.
3coils $35 shipped.
legend coupe is offline
Old 09-04-08, 02:54 AM   #13 (permalink)
6 Gears
95LegendGS's Avatar
Car 1: 95 Legend GS
legend coupe we already figured that
Old 09-04-08, 03:03 AM   #14 (permalink)
i was actually guessing. but thanks for confirming it.
3coils $35 shipped.
Old 09-04-08, 03:06 AM   #15 (permalink)
AKA Carlton I3anks
91LS 3.5's Avatar
Car 1: "92 Acura Legend L Grey/Black
Car 2: 91LS Sedan 3.5'd!
Send a message via AIM to 91LS 3.5 Send a message via Yahoo to 91LS 3.5
FYI you dudes doin your 3.5 swaps are changing your oxygen sensors while you have the motor out, right? ESPECIALLY the 2 that go into the headers...Dont be like me, hard head takes alot of fuckin labor to get them bitches out in that tight spot they're in!
Im a legend DR.
91LS 3.5 is offline
