6 Gears
Difference in fuel rails?
We now know the type 2 throttle body is superior, and the injectors are all the same and that type 2 FPR is best. But is there a difference in type 1 or 2 or RL fuel rails? Is one better then the other?
Just another boosted legend Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have "UNLIMITED" RL and Legend Parts PM me to discuss. NO COUPE PARTS, please stop asking For quickest reply please email me at 95LegendGS@gmail.com Thanks! |
aka desired_speeds
Just because the type II FRP is the best doesn't mean everyone should slap one on their type I's because your cars would be bogging like crazy.
Of the Telion Chip
Lets clarify this the Type I and Type II fuel rails are the same. The FPR's are different. One is not necessarily better than the other, they are mearly different in terms of the amount of fuel they flow which is based upon the cams and air/fuel ratio maps. so they should be used in unison TII cams and ECU A/F maps use a TII FPR; TI cams, ECU and A/F map use a TI FPR. now the RL is a different breed all together and seems to work best wih the TI setup unless you have done some other things in the cam department. as fo rthe RL fuel rails I find them far more pleasant to the eyes as far as flowing more fuel I doubt it probably about the same. and any of the above have said to be adequate for more Hp than many of us will ever see.
KA8 Legend Killer
how is it superior?
Mods: Short Ram Intake with K&N Air Filter, Custom Exhaust, Telion Chipped ECU, Type II Manifold (added 12 peak hp and cracked on 7-30-08), Type II Cluster,Throttle Body Coolant Bypass 15.35@91.6mphFuture Mods: OBX Headers,Custom Y-Pipe,Magnaflow hi-flow cat,Stromung B-Pipe,Remus Exhaust,Ported and polished heads and manifold,Web Cam regrinds, 6spd swap All after I Do the 3.5 Swap!! Hoping for a healthy 200whp N/A beast |
I'm the Stig!
i was gonna say, you think the TB is superior? i think they are same no? only difference's i found was the upper water passage and the TPS sensor are facing a difference direction.
i ran a type1 TB on my coupe since the rebuild b/c we broke 2 typeII TPS sensors accidentally (wasn't my fault either).
#6 (permalink) | |
It's stock, really.
Messing with the combinations just seems to be begging for check engine lights...?
Registered Libertarian
kinda curious about the FPR's who can look up part numbers for them, T1, T2 and 3.5 (97-04 RL), I wonder if there is two or three different numbers?
95L 3.5 A/T 4dr 171K • 94LS 2dr 6spd 181K project • Little Bro 93LS A/T 4dr |
I'm the Stig!
/\ FPR's have a different part#'s, as they are different
Of the Telion Chip
The air porting on the TII TB is better than that of the TI allowing more air into the intake manifold it has one more inlet port than the TI.
#10 (permalink) | |
KA8 Legend Killer
6 Gears
Thanks for clarifying telion, I knew there was a reason but I had forgot. I guess if theres no real difference in fuel rails besides looks I'm going to pick the pretty ones to be chromed
6 Gears
legend coupe we already figured that
#15 (permalink) |
AKA Carlton I3anks
FYI you dudes doin your 3.5 swaps are changing your oxygen sensors while you have the motor out, right? ESPECIALLY the 2 that go into the headers...Dont be like me, hard head takes alot of fuckin labor to get them bitches out in that tight spot they're in!
Im a legend DR. |
