Old 02-13-08, 01:18 AM   #136 (permalink)
KA8 Legend Killer
91sedan's Avatar
Car 1: 91 Acura Legend BHG
Car 2: 88 LS Sedan-SOLD
Car 3: 93 Ranger R.I.P
Talking
just reading this makes me wanna do the 3.5 swap instead of fixing the BHG cause I actually think it would be cheaper. 3.5 FTW!
Mods: Short Ram Intake with K&N Air Filter, Custom Exhaust, Telion Chipped ECU, Type II Manifold (added 12 peak hp and cracked on 7-30-08), Type II Cluster,Throttle Body Coolant Bypass 15.35@91.6mph
Future Mods: OBX Headers,Custom Y-Pipe,Magnaflow hi-flow cat,Stromung B-Pipe,Remus Exhaust,Ported and polished heads and manifold,Web Cam regrinds, 6spd swap All after I Do the 3.5 Swap!! Hoping for a healthy 200whp N/A beast
Last edited by 91sedan : 02-13-08 at 04:35 AM. Reason: Cause I'm actually gonna do the 3.5 swap
91sedan is offline
Old 02-26-08, 05:13 PM   #137 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
Updated and fixed a few errors.
Mike Diaz is offline
Old 02-26-08, 11:27 PM   #138 (permalink)
The Crowing's Avatar
Car 1: 1991 Legend Coupe LS
Car 2: 1968 Jaguar XK-E
Car 3: 1990 L Sedan
^You mean the first page? What were the errors?
The Crowing is offline
Old 04-25-08, 02:34 AM   #139 (permalink)
engineering fanatic
Car 1: 95 L sedan
gutting necessary?
It's all about the torque. Read my dyno sheet compared to most other Type II's.
Nobody has come close to 218 ft lbs torque at the wheels without major mods. All I have is an intake and some exhaust work. I have an EGR valve block, and throttle body coolant bypass, but that doesn't count for much. That's running on a stock Type I ECU.
Mike Diaz
I am having the 3.5L swap done on my 95 L Automatic sedan next weekend, or the following week, depending on the arrival of the hybrid mount from jkurl. My mechanic will be using the DIY instructions on the first page, and will be using the complete RL long block.
My question is do I have to port and polish the intake manifold? Or will I be alright if we just get the long block and follow the DIY. I realize that improving the airlflow will be beneficial, and I will do that later on. Right now I just need to get the car running, and I wonder if stock-everything will hurt the the engine or transmission.
Thanx for the DIY, by the way.
IMDKING is offline
Old 04-25-08, 03:45 AM   #140 (permalink)
Registered Libertarian
jkurl's Avatar
Car 1: 95L sedan grn
Car 2: 94LS 6spd cpe grn
Car 3: 67econoline 63nova
Originally Posted by IMDKING View Post
Mike Diaz
A stock 3.5 will be just fine not all the 3.5 swaps done have been as performance minded as others. my sedan has a stock 3.5, and I love it. btw, I've got my end of the mount situation covered, could have used more lead time but I'm willing to do what I can to get it out fast
jkurl is offline
Old 04-30-08, 01:23 AM   #141 (permalink)
engineering fanatic
Car 1: 95 L sedan
How does it do on gas mileage? I wonder if I wil have to get a '93 civic hatch back for daily driving and save the legend for the weekend and out of state drives. A trip to NYC used to cost me 3 full tanks round trip. I wonder if it's gonna be much worse with the 3.5, or even feasible.
IMDKING is offline
Old 05-04-08, 11:12 PM   #142 (permalink)
engineering fanatic
Car 1: 95 L sedan
Can somebody comment elaborately on the difference in gas mileage and what may be short comings, or gains, if any, of going with the 3.5 as far as economy is concerned. This is for the all stock swap, of course.
Thanx.
IMDKING is offline
Old 05-05-08, 02:42 AM   #143 (permalink)
jkurl's Avatar
Thanx.
for the short while I had the 3.5 before putting in a modified ecu chip it seemed to get about the same mileage but its hard to say with the way I drive plus I was probably driving a bit harder than usual testing it out. I cant think of a short coming and the torque gains are nice.
jkurl is offline
Old 08-16-08, 11:06 AM   #144 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Car 2: Lincoln LS8 RIP
My car is up on the lift and I'm trying to get the upper most bolt/nut off the joint pipe. Its connected to the oem header and its not going anywhere? Any ideas? I've PB blasted, waited, and I have all air tools but its at an angle just out of reach for an extension. PLEASE HELP, again its on the lift and in the middle of dropping the motor out of the bottom. Tips or tricks???
92drls is offline
Old 08-16-08, 01:34 PM   #145 (permalink)
Kia Killa
sr5guy's Avatar
Car 1: 95 BMW 740I
Car 2: 91 L Sedan Rosewood
Car 3: 91 LS Cpe 3.5 *sold*
You have to use a 3/8 drive, MAC Brand, 6 Point, 14mm, shallow impact swivel socket.
It should look exactly like this one but in 14mm size.
-Matt
Originally Posted by nino418
Heath, u should calm down go back to work and apologize to the co-worker u just punched out
sr5guy is offline
Old 08-16-08, 03:47 PM   #146 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Tried it and didnt work, its cool tho the motor is out and I'm swapping everything to the jdm motor. I've got an pretty easy angle on it now lol.. I've got sooo many pictures
92drls is offline
94 legend GS type II Engine Swap NO Start HELP! PearlGS Second Generation Legend (1991-1995) 15 08-18-05 12:22 AM
94 legend GS type II Engine Swap NO Start HELP! PearlGS Second Generation Legend (1991-1995) 0 08-15-05 08:25 PM
Engine Swap DTMM4Legend Engine & Performance Modifications 3 01-11-05 02:13 PM
Engine swap, head gasket, Philly area Herb Second Generation Legend (1991-1995) 13 10-19-04 05:27 AM
g1 to g2 engine swap? awj30 Engine & Performance Modifications 14 06-29-04 03:09 PM
