» Sponsors
» Sponsors
Old 11-20-06, 09:23 AM   #31 (permalink)
Alperovich's Avatar
Originally Posted by whats77inaname View Post
Mike, RL axles?
i've been wondering the same thing? maybe kenso can help answer this also, will RL axles work? will they work even with a typeII (or typeI for that matter?) I recal back when we did the Diff stuff, that someone said that the diffs were similar, so can we use RL axles with a 3.2 (and manual diff?), if we can are they worth using?
Alperovich is offline
Old 11-20-06, 10:38 AM   #32 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
Nope, Legend axles + Legend differential. Both of my axles were rebuilt by a local shop. They claim I should be able to put down 400 horsepower to these axles without a problem. Basically, I'll probably never have to replace them.
Mike Diaz is offline
Old 11-20-06, 10:40 AM   #33 (permalink)
Alperovich's Avatar
interesting, how much did that run? i need new axles.
Old 11-20-06, 11:09 AM   #34 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
Nice job Ken!!! Brilliant.
215whp+
swift is offline
Old 11-20-06, 11:41 AM   #35 (permalink)
$100 per axle, balanced and everything. Most cities have shops that will custom build or rebuild driveshafts and CV shafts. Call a local performance shop and find out who does their axles and driveshafts.
Old 12-14-06, 12:04 PM   #36 (permalink)
Updated with new picture links (now permanent), and hyperlinked dyno pics and graphs.
Old 12-14-06, 12:08 PM   #37 (permalink)
a figure in the shadow...
midknight_legend's Avatar
Car 1: 1994 Red 2-dr Automatic
Send a message via MSN to midknight_legend
cool...thanks!!
midknight_legend is offline
Old 12-21-06, 03:57 AM   #38 (permalink)
Registered Speed Freak
badboyr66's Avatar
Car 1: 1991 Sedan
Car 2: 96 Kia Beater
Car 3: 90 DX hatch 4mpg
Send a message via Yahoo to badboyr66
First let me say thanks to everyone involved in this. It is nice to see some go into unchartered area and come out good.
I have a few questions as I am thinking of this.
1. What is the HP rating on the 3.5?
2. SO the afc is not a must to have it running right?
badboyr66 is offline
Old 12-21-06, 10:48 AM   #39 (permalink)
The horsepower rating 225 and the torque is 236 ft lb on the 2002-2004 RL's. The only reason for the increase was from a different exhaust setup and computer changes. The 1996 to 2001 RL's were rated at 210 horsepower and 224 ft lb torque, which is more like what you're gonna get with Legend electronics.
At the wheels, I pushed 187 hp, and 218 ft lb torque with just a few bolt on mods. I can't wait to see what this thing will do with headers and a y pipe.
The AFC is not a requirement for a properly running 3.5L.
Old 12-21-06, 07:24 PM   #40 (permalink)
Alperovich's Avatar
mike, i'm not sure if u covered this or not but what kind of rebuild did u do to the motor before installing it? if any...
Old 12-21-06, 09:50 PM   #41 (permalink)
I had the heads machined and pressure checked. He checked all the valves and everything for me. I swapped the valve seals while I had them off. I did a light polish and gasket match on both the intake and exhaust side of the heads. I installed OEM head gaskets, and intake manifold gaskets. I also ported and polished the inside of the exhaust manifolds, as well as porting the crap out of the exit side of the exhaust manifold. My goal was to have a custom Y-Pipe made, but with OBX and possibly Stromung making headers, I never had the Y-Pipe produced. I gutted the intake manifold of all the VIS parts, as well as the unneeded walls that kept air out when the VIS butterflies were closed. My intake manifold is like a hollow shell now, no restrictions.
My block had something like 30k on it, while the heads had about 20k on them. It's basically a new engine.
Old 12-30-06, 06:47 PM   #42 (permalink)
DemonWolf
jimmer's Avatar
Car 1: mazda 2600i sort of
Car 2: Legend coming!
found me a motor here local...they asking $800 for the engine.......not sure what all it includes but will be finding out here real soon.
Im going for it though I think.
still wanna add a 6 speeder to mine with a 5 speed flywheel
jimmer is offline
Old 01-02-07, 03:41 PM   #43 (permalink)
NoT A MyTh's Avatar
Car 1: 1992 acura legend
Send a message via AIM to NoT A MyTh Send a message via Yahoo to NoT A MyTh
rl motor
can you turbo charge a rl motor
NoT A MyTh is offline
Old 01-02-07, 03:57 PM   #44 (permalink)
Dv8
Life Ruiner
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Can you turbo charge an EVO?
~Dv8
Dv8 is offline
Old 01-03-07, 01:19 PM   #45 (permalink)
You can turbocharge any engine with the correct amount of time, labor, and money. Yes, you can turbocharge the RL engine, but engine management is the key factor in pushing horsepower.
94 legend GS type II Engine Swap NO Start HELP! PearlGS Second Generation Legend (1991-1995) 15 08-18-05 01:22 AM
94 legend GS type II Engine Swap NO Start HELP! PearlGS Second Generation Legend (1991-1995) 0 08-15-05 09:25 PM
Engine Swap DTMM4Legend Engine & Performance Modifications 3 01-11-05 03:13 PM
Engine swap, head gasket, Philly area Herb Second Generation Legend (1991-1995) 13 10-19-04 06:27 AM
g1 to g2 engine swap? awj30 Engine & Performance Modifications 14 06-29-04 04:09 PM
