Old 03-15-07, 12:54 AM   #106 (permalink)
Car 1: Honda
It's in the first post of this thread. I spent a lot of hours writing that up, please read it sometime.
I read through some of this thread. I'm new here and I didn't remember/recognize that you were the thread starter. I'll read up some more...
cuttie is offline
Old 07-19-07, 01:30 AM   #107 (permalink)
Car 1: 1992 LS Sedan - 3.5
"The last one screwed me up because I already had the engine installed. You do not need to do this, but you can if you want. On the LEGEND passenger side valve cover, there is a sensor at the rear of the valve cover. The RL valve cover has this bung closed off. You'll need to drill, tap, and thread the back of the valve cover if you want to install that sensor."
So, if the bung is left closed, what do you do with the line that led up to the sensor in the legend? Anything else to take care of?
FallenAngel is offline
Old 07-19-07, 09:32 AM   #108 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
I finally drilled and tapped the hole, but for a while, I just zip tied the sensor (plugged in) to something on the firewall.
Mike Diaz is offline
Old 07-19-07, 12:47 PM   #109 (permalink)
Huh, chicken? GET HIM!!!
AckRite's Avatar
Car 1: 1991 3.5 Ack Legend Ls Coupe 5spd
Car 2: 1997 Sunfire
Send a message via AIM to AckRite Send a message via Skype™ to AckRite
what is that sensor for?
Im getting a CEL, could that be why?
http://www.speedtest.net/result/216434638.png
AckRite is online now
Old 07-19-07, 02:15 PM   #110 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Check the code, I'm betting your code is EGR, which is the same thing I have, and I can't figure it out.
The sensor is a temp sensor, which might have been the reason I was running so rich on the dyno. If it was showing too cold, it could be increasing the amount of fuel the injectors are giving the engine. Future dyno runs will tell me more.
Old 07-19-07, 02:26 PM   #111 (permalink)
AckRite's Avatar
Car 2: 1997 Sunfire
yeah i have another thread about the CEL im getting. They told me the same thing about the EGR valve. Let me know if you find a solution for that in the future.
So do you think I should swap the right valve cover from the legend over?
Old 07-19-07, 03:24 PM   #112 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
That would probably help.
Old 07-19-07, 04:12 PM   #113 (permalink)
AckRite's Avatar
Car 2: 1997 Sunfire
quick question, do you have a vacuum diagram for the RL?
Old 07-31-07, 11:29 PM   #114 (permalink)
Didn't block the egr and switched the valve cover, no check engine light.
On another note, we need the 3.2 pullies for 3.2 accs., but is there also a noticeable weight difference?
Old 08-01-07, 09:50 AM   #115 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
PM Kenso and have him forward it to me so I can add it to the DIY. He should have access to it.
Old 08-01-07, 05:14 PM   #116 (permalink)
Mike, have you gotten a Type II ecu or a chipped Type I yet?
Or are you gonna get the Telion 3.5 chip when its ready?
Old 08-01-07, 05:24 PM   #117 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
I bought the EMS for future use. I'm daily driving the car until the end of summer, then my real project should start. I have a Type II ECU that I'm going to have chipped for another 3.5 project I'm working on.
I'll go with Telion because SR5guy says he won't do them anymore.
Old 08-15-07, 06:32 PM   #118 (permalink)
So, I know the differential handles how the wheels spin when making a turn, but whats the differences between the 3.2 and 3.5 diffs? The 3.5 will work with the Legend tranny, but it may have some drawbacks(?), at least for an AT.
I've had a kind of bogged down feeling since the swap was done, its most noticable when you're at freeway speeds and take your foot off the gas completely. Putting your foot back on lightly will give a light jolt.
D-Money, the only other 3.5 auto I know of, has confirmed he has a similar bogged down feeling and his mech used the 3.5 diff as well.
Are we hurting the tranny and/or diff?
Old 08-15-07, 10:44 PM   #119 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Probably not hurting it. Maybe it has more backlash than the 3.2 diff. I'm not 100% sure. All Legends seem to have that bit of a bog when you let out of the gas. A lot of that has to do with the condition of your mounts as well as the drivetrain setup. How's the accelleration?
Old 08-16-07, 01:10 AM   #120 (permalink)
I do remember a slight bog with the 3.2 on the freeway, but this is more noticable.
Rear tranny mount is new, others are the orig. Normal driving acceleration is fine when moving.
