Old 02-18-03, 01:31 PM   #1 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Car 2: 92' Acura Legend 4DR
Double Tube intake?
THis is going to sound stupid but does anyone know if an intake with two pipes and two filters is going to make any difference in power? I heard it would lower hp unless I was using FI.
Thanks,
Ry
Dethred is online now
Old 02-18-03, 02:07 PM   #2 (permalink)
Pain Machine
95Legend6Spd's Avatar
Car 1: Godzilla:
Car 2: Tokyo
Car 3: Attack!
Send a message via AIM to 95Legend6Spd
Dethred-
It's honestly not going to do anything, because we're not using a MAF sensor setup on our cars... on some FI vehicles, like the Supra, some people that can't afford a MAF elimination kit (HKS VPC, GCC or AEM EMS) are taking two MAF sensors on two individual intakes, and splicing two of them into the factory wiring harness, thereby technically doubling the airflow that the motor can injest (that the MAF can read - they're only good to around 18psi)... but having two intake pipes on a Legend wouldn't do anything... except take up space.
| Chris M | 1997 Toyota Supra 6-Speed | 78GTS | 17X10s NT-01s All 4 Corners |
| Old: 1994 "BoostLogic Catalog" TH400/Single 71GTQ | Advan | TRUST | HKS | RPS |
|Previous: 1995 Legend Coupe, 6-Speed 1998-2002|
95Legend6Spd is offline
Old 02-18-03, 05:41 PM   #3 (permalink)
0000$$$$0000####0000
Car 1: Acura
On my friends 92 Legend Coupe, he had a dual intake system. How it worked was there was a slip or V like tube that went to the stock airbox and to a short ram. Blocking off the short ram side was a plate that was opporated by a vaccum actuator. The intake path was stock until it reached 4K RPM where the short ram would open. What was obtained from this was a stock feeling car down low with no loss in torque and after 4K RPM it felt like your ordinary intake with goot top end gain.
ChrisK is offline
Old 02-19-03, 01:41 AM   #4 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Chris, did he feel any difference between a normal CAI? I figured in theory it would be less air restriction because there was that much more surface area of filter to let air in... probably makes no difference though..
Old 02-19-03, 01:47 AM   #5 (permalink)
Car 1: Acura
I don't know how it compared to a CAI, but basically the short ram filter section performed just like the regular underhood untakes that you see around. The difference was under 4K RPM it was closed off and the air came from the stock air box. This was developed because often the under hood intakes loose a little but of torque and HP on the low range. This obiously solved the problem. Also, it was quiet as stock for normal driving and only wailed over 4K RPM.
ChrisK is offline
Old 02-19-03, 01:49 AM   #6 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
oh I dont have the inginuity to make something like that so... yeah
