LinkBack | Thread Tools |
Rating:
Display Modes |
#211 (permalink) | |
~TRu Hybrid
#213 (permalink) | |
"Sneek-E Honda DA6" "2001 Infiniti QX4 AWD+LSD" http://www.imagestation.com/picture/...1/f617b751.jpg Transition to the Darkside |
#214 (permalink) |
E*koden
DV8, what time of differential oil did you use? I'm debating whether I should use regular gear oil (80w-90), Mobil 1 syn gear oil (75w-90), or 100% Lucas oil stabilizer. what do you recommend??
http://img.photobucket.com/albums/v3...8/oaktree3.jpg 95 M3<>3.46LSD<> 00 SUZUKI GSX-R 750<>TOO MUCH TO LIST<> |
#215 (permalink) | |
#216 (permalink) |
DV8, so is it a direct replacement for the internals? I am very interested in this and planning to get it and have my mechanic install it for me. What do I need to know when getting this installed? Any custom mounting or work need to be done? Or is it straight forward? Thanks man. You make me proud to be a Legend owner.
Please respond back.
Aegean Blue KA7 w/ an Evolution Exclusive body kit Custom crystalized JDM one piece headlight Carbon fiber hood Type II engine 2 1/4 mandrel bent cat back exhaust. Type I Bayou stage II ECU - A'PEXi S-AFC II Walbro 255lph Fuel Pump 17" Enkei CDR9 on Fuzion ZRi Eibach Pro-Kit/Koni Special Struts, front & rear KMS Front Tower Bar Addco Rear Sway Bar Front STS Cross drilled/Slotted rotors Goodridge Steel Braided Brake Lines |
#217 (permalink) | |
read reno's take on it. ~TRu Hybrid
#218 (permalink) | |
Old S*hool Member
Sorry if that is a dumb question, but I am just not following what you wrote. I'm unbelievably impressed with your work and ingenuity!! ![]()
#220 (permalink) |
Looks like I'll be calling PSA to install this baby for me =)
[img] My 1991 Legend (SOLD) http://users.erols.com/annsu/newleg.jpg[/img] Contact me if you need the following: HELM Factory Shop/Electrical Manual Sedan Type-F floor mats Driver Side seat (free) OE + Denso Filters for cheap Throttle Body TL Engine Cover |
#221 (permalink) |
Thanks. I will definately be getting this when I am done with my side job. =)
#222 (permalink) |
RL block, TYPE II heads, 6spd Tans, 5spd ECU
I had both type I and II auto chipped ecus, besides rev limit there were no differences between the two. I actually felt more punch on the chipped type I ecu. Besides a better fuel mapping on the 6spd ecu to take advantage of the 6th gear, i dont think that the 5 or 6 spd ecu's chipped are going to be any different especially when tuned with the apexi safc, not to mention i cant take advantage of the higher revlimit because i shouldnt over rev a 3.5 liter anyway. Why do you think its better Tnelson? TRu Hybrid
#223 (permalink) |
Pedobear is watching you
well, if you look at the type I and type II motors respectively, the only advantages a type II has are:
valves, intake manifold, cam, ecu. the ecu it optimized to use these advantages for max power. i dont know if it will give you anymore than 5 or so peak hp, but i think it will be around that. in a business where we try anything to squeeze a few more ponies, i think this is something you could take advantage of. although i do agree with you that you do not need higher revs. |
#224 (permalink) | |
~TRu Hybrid
#225 (permalink) |
i was just thinking that the cam could possibly be affected, or not maximized at least, guess it should be fine, seeing that the air fuel curves are similar, the tuning will be the trick. should get quite a bit of power out of that(5-6 hp)
Linear Mode | |
