LinkBack | Thread Tools |
Rating:
Display Modes |
#752 (permalink) | |
#753 (permalink) | |
#755 (permalink) | |
Domesticated Redneck
Thanks for checking that out for the forum... ![]() |
#756 (permalink) | |
#757 (permalink) | |
Mr. Hard to Find!
DV8, if you could just measure the length of the mount or is it the same Length as the Legend mount?
Thank You, L. Downes O-Town Legends C.C. Winter Haven, FL _______________________ Forum Rules Tapped (Term used mainly in New England) = Crazy + Stupid Contact me at: otown_legends_cc@yahoo.com |
#758 (permalink) | |
#759 (permalink) | |
Mr. Hard to Find!
#760 (permalink) | |
There is more to it than just the length. There is the angle that the mount slopes from the engine to the chassis as well, I'm, pretty sure it's not a straight across shot, but I can check. You also have to take into consideration that the 93 - 95 Legends have different front mounts all together. Only the 91 - 92s can use the DV8 mount. Also, the motor has to be level (same height as the other mount, sorry best way to describe I guess) or it will go through CV joints like a hooker on condoms because of the extra angle on the inner jounts. |
#761 (permalink) | ||
Fre OG
even tho the mounts are different, cant u still use them, they bolt up to the engine in t he same place, u dont need to change mounts when swapping to type 1 to type 2 engines, so wouldn t it mean the difference in the mount is where it conects to the subframe but still mounts to the engine the same spot? so we (93+) ppl could still use are stock front mounts? or is it one of the front mounts that was the one that did not line up?
i think i just answered my own question, could u swap the sub frame from a 91-92 into a 93-95?
Legend VS. CL/TL Quote:
94 LS Coupe 6 Speed (208k) 92 L Sedan Auto (76k) ATM replaced with 06 RL Rental 92 LS Sedan Auto (156k) parts 92 LS Sedan Auto (177k) project/restoring to factory 00 RL (87k) Traded in for 06 RL 95 NSX-T 5 Speed (75k) |
#762 (permalink) | |
Mr. Hard to Find!
DV8, I know it would be a big hassle but is there any way possible that you could remove that mount and make measurements. I will first have to do what you did and make one mount from the 3.2 and 3.5 mounts. Then I will have to do the same for the 93-95. From there I can make all the proper measurements and then modify it to see if I can make the mount even stronger than stock.
#763 (permalink) | ||
Fre OG
the only reason i was talking bout subframe swapping because it didnt sound like there was anyone with the 93-95 wanting to do what it is obivous 4 of us seem to plan to do and i figured who ever made the custom mount would not want to make a totally different one for one person or something
#764 (permalink) | |
#765 (permalink) |
While we are on the subject of mounts, this is a little off topic (my appologies DV8) but what I did on my 93 sedan when I installed my Type II is replace the rear mounts with the ones from a 91 - 2 Legend. They are solid rubber not the origional oil filled hydraullic mounts. They do transmit vibrations a little more at idle, but the car seems to have a firmer shift that I like very much. i did this in hopes of keeping engine/tranny movement to a minimum to preserve the short life of the rear tranny mount (hopefully, but probably won't). It will probably last a while anyways as it's my wife's daily driver and she drives like my 80 year old grandmother.
