LinkBack | Thread Tools |
Rating:
Display Modes |
#781 (permalink) |
Legend owner
sounds like that guy TypeRKorn that keeps coming back with different names trying to talk like he's done a lot...
again, if you did do it though props to you, and i look forward to seeing it. not trying to put you down... yet... but i am VERY interested in these pics
mods: - Auto to manual tranny conversion - intake - exhaust setup - Bayou stage 2 - Throttle body coolant bypass - 17" wheels - Tint - Pillar gauges - lowering - clear bumper lights - Jdm headlights - Short shifter mods to come: - y-pipe and hi-flo cat - engine rebuild with performance parts - SAFC-II - Turbo if it comes out... - Koni struts - LSD - Stage II clutch - carbon fiber hood and spoiler - Slotted/cross drilled rotors |
#782 (permalink) |
Stop crapping in my thread!
~TRu Hybrid
#783 (permalink) | |
WHAAAAAH!
Dude, c'mon, Any shop? Now you're just talking crazy. If you're just going to ruin threads, you're going to get banned again. Please don't post your opinions in the performance section anymore, especially without solid proof. You know what they say opinions are like, don't you?
#784 (permalink) |
I will discuss Headers with my guy at the end of March or sometime in April. At that time i will sit down and we will run the numbers to see if its worth a limited production. Headers are not easy. They dont build easy, they dont mount easy, and the Type I vs Type II have a pair pipe connection that needs to addressed. Hell, i have never peered under a coupe and cant say that the sedan mid to long tube headers will fit on a coupe the same way they fit the sedan, and i sure as hell wont build two different types.
We will see. ~TRu Hybrid
#785 (permalink) | |
Pedobear is watching you
#786 (permalink) |
Superthread:Fastest/Most Powerful Confirmed Legend(DV8) All Mods,DYNO&1/4mile
In here you will eventually see my results of the cams. I should be scheduling a time next week to get the dynoed results. Stay tuned.
The Dv8ED Legend Idles good and revs good, no problems I cant currently detect any problems except for the engine shakes more than it did. I havent driven it around yet. Kenso mentioned to me that his cam lobes didnt seem to be that close to the head castings, so we dont know if i recieved a higher lift cam or if its because mine was hardwelded by accident (good for me). These are my web cams hardweld/regrind. Notice the fractions of clearance to the casting. ![]() ![]() ![]() ![]() ~Dv8
AEM EMS Powered. 9 yrs and counting. Results, Where are yours? 12.953@107.865MPH 95 deg. Jun. 07' 3.5 6spd-#55 jet Nitrous 316WHP@5500RPM 345Lb-ft@4100RPM NOS 06-07'N/A 234WHP@5700RPM 229lb-ft@4600RPM 06-07' 13.782@99.135MPH N/A 95 deg. Jun 07' 03' G35c Auto Vortech Supercharged pshhhh 311WHP 274WTQ13.1@102MPH-on the brakes(108MPH) Hand fabbed Go-Kart 18whp 24wtq 8 page spread Honda Tuning 09-06' issue PM or Email only. Respect that! My Legends Website www.2slik4u.com Last edited by Dv8 : 05-05-06 at 02:18 PM. |
#787 (permalink) |
I am really keen to see if these work. I am really keen to see if Webcam can make a matched set of cams
If you get bored do me a favour Turn the engine to TDC N0 1 Firing. Flip the cambelt off. Turn the engine 60 degrees clockwise. Rotate the drivers side cam exactly 180 degrees Weld up 2 spare hydraulic lifters. Put one in CYL1 inlet rocker put the other in CYL5 inlet rocker(your choice of 2 rockers). Turn the engine 60 degrees anticlockwise. Put the cam belt back on. Place a dial indicator in the inlet spring retainer CLY1. Place a dial indicator in the inlet spring retainer CLY5. Zero both indicators. Rotate engine clockwise and note if dial indicators both move together, If so, woop with delight. If one indicator leads or lags the other place head in hands and cry. If still bored at this point, put welded lifters into exhaust rockers and reapeat. Or FEDEX me the cams and i will check them for you. Remember to rotate drivers side cam 180 degrees before starting engine. Chris |
#788 (permalink) | |
Whats all this do?
#789 (permalink) | |
If you look at the firing order of our engine. 1-4-2-5-3-6 Or if i present it like this 1-4-2 5-3-6 You can see that when 1 is on compression 5 will be on overlap.When 4 is on compression 3 will be on overlap.2 and 6 also. The reverse is true as well when 5 is on compression 1 will be on overlap.3 and 4 6 and 2. Overlap is also known as "rocking" and it is when the exhaust valve is closing and the intake opening. By rotating the drivers side cam 180 degrees when 1 is on compression 5 will also be on compression. When 1's intake valve is opening 5's intake valve is opening. Makes it very east to compare the two camshafts. Chris |
#790 (permalink) | |
So i guess its a good sign the engine runs and idles smooth then? Did you have to grind the head castings away to fit your cam in?
#791 (permalink) | |
When you go to dyno ask the operator to do a "plug chop" I usually do them at peak HP RPM on full throttle. A "plug chop" is when you hold the engine on the dyno at high load/rpm for around 15-20 seconds and then turn off the ignition and put your foot on the clutch. Then pull the spark plugs and have a look at them. If the cams are different then the plugs will look different from one bank to the other. Chris |
#792 (permalink) |
Buzzard, so you're saying this is just the quick easy way to degree the cam? It allows you to see how close of a match they are instead of just doing some math?
http://i26.photobucket.com/albums/c1...Picture076.jpg |
#793 (permalink) |
If this is any indication of the drive, im still jittery!
Man it was a blast. at 4k it starts to pull like crazy all the way to 6. 4k in 2nd hits so hard when you punch it, and never lets up. if i had real estate it would keep pulling through 6th gear. I realized i still had my subs in so i dumped those and the difference is dramatic. Im still running full interrior and full stereo(2 amps, 1 dvd headunit and 6 speakers, tons of wiring). Now i need to say that i also put in the 2.25 Y so im sure it has to do with some of the topend power. the lowend doesnt seem to be any different because im still loosing traction down low if i want to, but i do think the power has move more torwards mid-top now. I scheduled a dyno on thrusday. the car is in drag trim and waiting. ~Dv8
#794 (permalink) |
haha i thot u posted the footage of the regrind from ur webcam...newayz cant wait to see the results man!!
~t.s.
legend parts fs: stock springs/shocks, jdm fenders and more!!... http://www.acura-legend.com/vbulleti...ad.php?t=79147 wireless g adapters -- http://www.acura-legend.com/vbulleti...066#post911066 |
#795 (permalink) |
So what would your butt dyno say, if you had to guess? Sounds like it's definately a very noticeable difference just like Kenso experienced.
Hey, by any chance do you know what our piston to valve clearance is with a stock cam? Also, do you know what cc our heads are?
