LinkBack Thread Tools Rating: Thread Rating: 20 votes, 4.95 average. Display Modes
Old 05-15-06, 03:22 PM   #886 (permalink)
Dv8
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Originally Posted by 1_Hot_Legend_L
Hmmm, seems the only three things the NSX has that the Legend don't is the Front/Rear spool selonoids and the Chamber volume control Selenoind valve. That diagram ou put up is a lil hard to read. The one I'm reading has a lil more space between wires so it's easier to trace.
The main relay and fuel pump relay setup is a lil different but it looks like it still takes the same positive signal from the ECU to power them up, so that should be fine!
Have you powered up the EMS? can you with out installing it? Do you know what the EMS lets you disable as way of stock sensors and such?
Dv8 is offline
Old 05-15-06, 03:24 PM   #887 (permalink)
Dv8
Dv8's Avatar
Yes, thank you I overlooked those. so that makes five that the Legend don't use. But I think the Legend uses those slots for something else. I think that will just be a minor issue.
The crank/cyl sensor is termed differently with the Legend. the NSX uses letters (cyl A crank A) while the Legend uses numbers(crank 1 cyl 1) wonder why.
Dv8 is offline
Old 05-15-06, 03:24 PM   #888 (permalink)
Mr. Hard to Find!
1_Hot_Legend_LS's Avatar
Car 1: 1991 LS Sedan Auto
Car 2: 1990 Chevy S10 SB V8
Yes I have hooked it up to my computer already and you can mess with everything. I haven't saved anything cause I need the base tuning to fire up the Legend. But you can turn off V-TEC, EGR, VIS, etc....
WHOA! I just noticed this....it seams that the Legend ECU used the same plugs for it's VIS selonoids as the NSX ECU uses for the Spool selonoids
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
_______________________
Forum Rules
1_Hot_Legend_LS is offline
Old 05-15-06, 03:26 PM   #889 (permalink)
Mr. Hard to Find!
Not sure but it's just like me saying Toe-may-toe and you saying toe-ma-toe. It should still work fine as the wiring is still the same. As long as it's a negative trigger hall effect sensor.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-15-06, 03:27 PM   #890 (permalink)
Dv8
Dv8's Avatar
how about the accel pedal angle sensor? Theres already a TPS on there. TCS maybe?
Dv8 is offline
Old 05-15-06, 03:27 PM   #891 (permalink)
Mr. Hard to Find!
how about the accel pedal angle sensor? TPS?
Pedal angle sensor is the same as the TPS, just moved to the gas pedal.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-15-06, 03:28 PM   #892 (permalink)
Dv8
Dv8's Avatar
But theres already a TPS next to it. Im guessing TCS?
Dv8 is offline
Old 05-15-06, 03:28 PM   #893 (permalink)
Mr. Hard to Find!
I'm really learning something here, the Legend VIS system is just an early version of the V-TEC setup.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-15-06, 03:30 PM   #894 (permalink)
Mr. Hard to Find!
Hmmmm, must be. I wouldn't worry too much about the small stuff. We jus need to get it running first and then we can turn off different terminals and reconfigure sensors as needed using the AEM USB interface.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-15-06, 03:33 PM   #895 (permalink)
LS92Sedan's Avatar
Car 1: 94 L Sedan Canterbury Green
Car 2: 94 L Sedan White
Car 3: (RIP) 92 L Sedan
Originally Posted by BUZZARD
I could turn it around in 20 days, faster if you give me notice or you are willing to pay the overnight freight.
Chris
damn I was figuring longer than that, any idea on current shipping rates?
LS92Sedan is offline
Old 05-15-06, 03:33 PM   #896 (permalink)
swift's Avatar
Car 1: 92' legend coupe 5spd
Car 2: 94' coupe auto
Car 3: 91' Smacura
$10 on the first guy to blow his motor trying to do a tune with the NSX AEM.
good luck you'll need it.
swift is offline
Old 05-15-06, 03:35 PM   #897 (permalink)
LS92Sedan's Avatar
exactly, cept for they used manifold flaps to control air flow instead of a different lump on the cams, timing should be pretty similar as far as the spark and fuel
Old 05-15-06, 03:35 PM   #898 (permalink)
Mr. Hard to Find!
Actually if you look at the computer interface any ape could do it. As long as you know the basics of how an engine works and how to read fuel/ignition maps.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-15-06, 03:37 PM   #899 (permalink)
LS92Sedan's Avatar
na its a slow process, you gotta tune given rpm ranges first then you'll get these crossover points that you go back and fine tune, if you'd put up the $ for a new motor Id def push the envelope lol
Old 05-15-06, 03:37 PM   #900 (permalink)
Mr. Hard to Find!
Actually the timing on the NSX tune changes depending on weather or not the V-TEC is active or not. But then again the Legend does the same depending on if the VIS is active or not. Makes you think, doesn't it?
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Digg this Post!Add Post to del.icio.usBookmark Post in Technorati
