» Sponsors
» Sponsors
Old 02-25-04, 05:13 AM   #1 (permalink)
K L E A N M O D™
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: 2004 GTO
DYNO NUMBERS: For the G2 Cpe/Sdn Modded/Unmodded
DYNOJET IS ACURA-LEGEND.COM STANDARD
KA7
DV8's Dyno Numbers 91 KA7 3.5 Hybrid 6 SPD
12.9@107MPH Jun 07'
3.5 6spd-125HP NOS 316WHP 345Lb-ft Nitrous
N/A 234WHP 229lb-ft
Tnelson's Dyno # 94 AT KA7
Mods:
Short ram with dryer hose cai adaper(soon to be cai that phil had done)
No cat, 2.5 piping after the Y
Bayou stage II for type I
Numbers:
183.2 HP
194.8 TQ
E K's Dyno # 91 KA7 AT
Mods:
RM Intake
Stage 2 Chip
KMS Throttle body
Numbers:
HP: 173.3 at 5600 RPM
Torque: 180.3 at about 4500
If any errors or you want to be added, pls PM me formatted stats like this and i'll update the post.
I think this could be useful to the community.
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000.2 Millenia S- Blown & SOLD
-1996.8 S14a-SOWED
-1995.8 S14a- SOLD
-2004 GTO
-Holy Rollerz CCC Member-
Thai.95LCoupe is offline
Old 02-25-04, 05:14 AM   #2 (permalink)
K L E A N M O D™
Car 3: 2004 GTO
KA8
Ranger Joe's Dyno # 92 KA8 5spd MT
Numbers:
My CAI peak power is 167.3 @ 5300rpm
My CAI peak torque is 177.1 @ 4300rpm
Stock airbox peak power is 166.6 @ 5300rpm
Stock airbox peak torque is 173.2 @ 4500rpm
ScotcH's Dyno # 93 KA8 6-spd MT
Mods:
Stage II chip
Home Depot CAI with a K&N cone
Numbers:
199.9 HP
180.4 TQ
wTnLeGeNd's Dyno # 91 KA8 AT
Mods:
CAI
Exhaust
Numbers:
(First run)
168.8 HP
171.8 ft/lb TQ
(Second run)
169.1 HP
173.2 ft/lb TQ
LeolegendATL's Dyno # 91 KA8 5spd MT
Mods:
Custom CAI
Numbers:
MAX POWER 173.7
MAX TORQUE 186.4
MAX POWER 172.8
MAX TORQUE 186.0
Alexander's Dyno # 93 KA8 6spd MT
Mods:
140k miles
RM Racing Intake
Greddy Exhaust
19x8 RacingHart Type C5
235/35R19 BF Goodrich Scorcher T/A
50-60 degrees ambiance temperature
Dynojet 248C
Numbers:?????
95Legend6spd Dyno # 95 KA8 6spd
Mods:
Numbers:
194 whp
178 ft lbs tq
(Numbers were taken in 4th gear)
Hasbro's Dyno # 91 KA8 AT
Mods:
Stock
Numbers:
Max power- 169.3 @ 5250rpm
Max torque-174.1 @4900rpm
Thai.95LCoupe's Dyno Numbers 95 L KA8 AT
Mods:
Custom Cold Air Intake
Dinan Stage II Chip
Legend Spec. Remus Exhaust
Numbers:
Max Power-182.7 @5300rpm
Max Torque- 168.5 @5300rpm
94Lcoupe's Dyno 1994 L KA8AT
Mods:
Intake
2.5 inch Magnaflow Catback with Hiflow cat
Numbers:
179.5 HP
168.2 TQ
Swift's Dyno Numbers 91 L KA8 5 SPD
Type 1
128k
Mods: custom air intake
short shifter
NGK-R's
Shaved and cleaned heads(not pp)
Cleaned injectors,throttle body, ,manifold.
183hp
189lbs in 3rd.
Joey "Smokingfastlegend" 95 L KA8 AT
Type II
Mods:
"eBay" Intake
Stromung Cat-Back exhaust
179.6hp
166.2lbs
-1997 S14a-SOLD
-1996.8 S14a-SOWED
-1995.8 S14a- SOLD
-2004 GTO
Old 02-27-04, 03:26 AM   #3 (permalink)
Car 1: ACURA LEGEND
1994 L Coupe Type II AT
STOCK 179.9WHP and 153.7 Ft Lbs
Magnaflow Exhaust (Hi-Flow Cat resonator 2.5" Mandrel bent piping magnaflow muffler)
ASP Underdrive Pulley
JEM CAI
190.7WHP and 177.9 Ft Lbs
CLICK HERE FOR PICS AND DYNO
Same as above on about a 40 shot of nitrous. (empty bottle)
227.4WHP and 221.1 Ft Lbs
Bad Boyz is offline
Old 03-04-04, 01:56 PM   #4 (permalink)
Car 1: 1993 Legend LS Coupe 6-speed and 1988 RX7 10th AE
Send a message via ICQ to Alexander
I think I have to update my numbers:
198.5 Hp at about 6200 rpm
180.0 lb/ft at about 5100 rpm
All done at those condition above.
Alexander is offline
Old 03-05-04, 07:39 AM   #5 (permalink)
Dv8
Life Ruiner
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
~TRu Hybrid
Dv8 is offline
Old 03-05-04, 10:21 AM   #6 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 2: e60 530i | e46 330i
Car 3: S430
Here is mine. I am disappointed that it does not have the Torque reading
Type II - Exhaust, Intake, Type I ECU, unchipped. (Still redlines at 6200)
EDIT:
Stage III clutch, 5 speed manual
Maxpower = 190.02 whp
67.37 F, 29.42 in-HG, 13% Humidity
This tells me I may have to get the other ECU to extract the full potential. Dv8, you mentioned an S-AFC will fix that. Is that enough, or should I get the other ECU? On the dyno, it felt like it had more to go, I let off *right* as it touched the tip of the red (Type I gauges)
This may be my first set of mods for power
502 MotorSports is offline
Old 07-12-04, 02:32 AM   #7 (permalink)
Dv8
Life Ruiner
Dv8's Avatar
As soon as i get access to my website i'll post the dyno graph.
50 shot dry tuned with the SAFC 237WHP 250Lb-ft.
Im still having issues with the direct port. i have to step down the fuel jets, since my walbro is pushing out about 55psi and i dont have a regualtor yet. An FMU is in the works.
The jetting may just be too big for fuel.
the two 1/4 dynos i did while squeezing the direct port (fuel solenoid disconnected)before it went lean was already showing 250lbft and 200whp at 2800rpm.
I concluded that the simulation of real world air movement to the front intake on the dyno is very poor. i posted a 194whp and 204lbft on the first n/a run. we turned on another fan in the front, maybe pushing total between the two, 5mph wind torwards the intake and its second run posted 200whp 209lbft. its too bad they dont have a high velocity fan.
N/A
50 shot
80 shot
~TRu Hybrid
Dv8 is offline
Old 07-16-04, 03:24 AM   #8 (permalink)
A**ra-Legend.*om's POS
D0NNY's Avatar
Car 1: Green 89 L Legend Coupe
Send a message via AIM to D0NNY
Originally posted by 95LSTypeII
No, definately was not.
Factory specs are 230 at the fly wheel and 206 torque also at the flywheel.
I got 215hp & 221 torque at the wheels. Definately not under factory specs.
Dyno'd on April 20th, 2002. Dyno used was a Mustang Dyno.
Fuel cut, missing gears, stuck hood.
0-60 in 10 seconds of fun
1989 Acura Legend L Coupe 107,XXX
1997 Honda Accord EX V6 47,XXX
D0NNY is offline
Old 07-25-04, 06:49 AM   #9 (permalink)
"the Don"
theGodfather's Avatar
Finaly My Dyno!
Well guys, I finaly dynoed my car for the first time. I used this time to tune my S-AFC as well.
Here is where I stand (after S-AFC tuned by myself):
Max HP: 211.4 @ 6276 rpm
Max TQ: 182.2 @ 5469 rpm
Ran in 4th gear, ambient temperature of 22 degrees Celcius.
This if the first time I've tuned an S-AFC but tried to get the AF ratio in the high 13s. Actually the BEST run I did showed a 213whp but it was a wierd spike on that graph. Overall I was satisfied with the results, just thought the torque would have been a bit higher. I wonder why?
BEFORE SAFC tuning I ran these #s:
Max HP: 203.3 @ 6240 rpm
Max TQ: 177.5 @ 5457 rpm
This is with my current mods, but more mods are sure to come
What's a stock WHP on the 6-speed about?
Now need to find time to run a 1/4 mile
My friend with me took some pics and video of the car running, I will get them posted once he uploads them to me.
G
1995 Legend Coupe 6-speed
208 WHP @ 6250 RPM
189 FT/LB @ 5250 RPM
MUSTANG Dyno
260,000mi and counting
theGodfather is offline
Old 07-25-04, 07:14 AM   #10 (permalink)
Dv8
Life Ruiner
Dv8's Avatar
great WHP #'s! 11 more to the wheels than i have and i can seem to get anymore unless i swap out the flywheel. Is your the stock flywheel or modified?
cant belive that 300cc genterates 30lbft more, amazing.
The dyno you used was the dyna packs? you think those are better to dyno on?
You ought to see if you can level out that dip at 4500k in the TQ graph with the safc.
~TRu Hybrid
Dv8 is offline
Old 07-25-04, 07:31 AM   #11 (permalink)
"the Don"
Thanks.. yeah.. I was thinking the same about the slightly larger displacement.. making me think..
My flywheel is original, never changed from factory. I have had it machined 2 times so far (proves to you that with a good machine shop, our flywheels ARE ABLE to be machined), you think it took off enough weight to make a difference? THey only shave a couple fractions of a mm each time you think. My crank pully is from a Type-I though which is half the weight of the Type-II.
I wonder if bumping up 1 or 2 % at 4000 and 5000 would fix that "dip"? Probably will be a while before i'm on one again.
With respect to the dyno, I never knew the "dyna packs" style dyno existed! I always thought they were just rollers. It's pretty cool the way this works and the technician claims it's more accurate as it bolts directly to your hub. I'm sure there's alot of discussion on the web about advantage and disadvantages.
I'll post pics soon so you can see the setup.
BTW.. this proves to you what a Legend motor with 180,000 miles can still do.
208 WHP @ 6250 RPM
MUSTANG Dyno
Old 08-23-04, 12:37 PM   #12 (permalink)
Follow Me
Car 1: 1991 Charcoal Sedan L
Send a message via AIM to dap0901 Send a message via Yahoo to dap0901
As of Aug. 22, 2004
Dynoed
175 whp
182 tq
up by 4whp and 5 tq!
Pic to come!
In God We Trust!
dap0901 is offline
Old 10-10-04, 03:39 AM   #13 (permalink)
Car 1: 1995 Gold Legend Coupe LS Six-speed
Car 2: 1994 Honda Accord
My first dyno - rather disappointed
the results of my first dyno are a little disappointing, considering I have a six-speed type II with the stage 2 chip and a Remus mufffler. But nonetheless here goes:
Peak WHP: 182.9 @ 6200
max torque: 171.3 lbft, pretty consistently between 3100 rpm to 5600 rpm.
AF dips from 13.8 to 11 between 2600 and 2800 rpm, evening out to around 13.2 until it starts dropping off evenly from 4500 to 11.5 at 6500 rpm
Dyno was done on a Dynojet, and a high-Velocity fan was placed in front of the car.
btw torque and hp intersect at 5600 on mine. does that sound right?
The guy said my car is running too lean, considering the slight mods, and I need to open up breathing for the engine.
My next steps are to put on a short ram intake, and replace the cat with a more open one (magnaflow). Those two mods alone should hopefully restore whp considerably. My only concern is that it would probably only bring it back up to stock hp or slightly over. Right now, my Legend does feel a little lethargic.
Cheers,
Pascal
Dutchman is offline
Old 12-01-04, 11:15 AM   #14 (permalink)
SR79 Labrat
sr79labrat's Avatar
Car 1: Acura Legend
I got the Turbo Legend Dynoed!!!
Kinda depressing actually, but not horrid. I maxed at 200hp and 205 ftlbs.
Not too bad considering all of the problems. My uncorrected were 165hp and 170ftlbs roughly for Parker, CO. I will send the dyno sheets to some one to post, but not to bad for starters. The bumper is also actually formed and on the car= Bad Ass! I already ordered a new .5BAR spring which is about 7.5psi.
Once the mods I am planning are done we should see 300+ hp/tq. The numbers were up about 35 from near stock na setup. I still feel the car dosnt give accurate #ers, but this is as good as it gets for now.
Let me know your thoughts.
Thx, Kyle
Turbo Legend Parts & Project Updates!!!
Myspace-
http://profile.myspace.com/index.cfm...ndid=246854652
sr79labrat is offline
Old 12-14-04, 02:42 PM   #15 (permalink)
Kenso's Avatar
Car 1: ITR 00-106
Car 2: 95 FZJ 80
Here's my dyno results. Best run 183.3hp, 197.4tq. Mods are custom CAI, testpipe, Bayou stage II chip and Type I auto crank pulley.
ITR 00-106
95 FZJ-80
Kenso is offline
