#136 (permalink) |
Type II King
wow that seems really far off from where you should be with your mods.. can you explain more what you did? did you go to a dynojet and dynopack and run your car with the same mods?
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, safc II, strut bar, F/R sway bars, FL tie bars, ksports,tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA |
#137 (permalink) | |
Gimme a cookie.
not sure what seems off - I am exactly where I expected to be. Dynojet runs were done earlier this year - everything stock except for stromung cat back, (191/181), everything stock, except for stromung cat back and OBX header, (204/191), and now on a dynapack, I've gained around 25whp and 25wtq by adding a CAI, chip, pulleys, and flywheel.
Seems spot on to me. My guestimate of the dynajet readings is based on the thread I linked. I subtracted 11 hp and 5 tq to get the dynajet equivalent to my dynapack readings of 241/220. What I have not yet done but am basically started on are the following: Cams Intake manifold throttle body final drive
#138 (permalink) | |
Type II King
#139 (permalink) |
I'm the Stig!
/\ i think they are pretty spot on too, if u look at it closely, he got similar numbers as kenso with cams, which makes sense since the pulley's provide a similar gain as the cams did.
aaron, just think how much more power you'll get with those cams! I expect similar numbers when i dyno my coupe running similar mods. hopefully after telion fixes my ecu.
#140 (permalink) | |
Gimme a cookie.
Yeah I noticed that lots of folks are coming up short on torque with the 3.2. Not sure why though, I never have. On the dynojet I was at 204whp and 191 tq. I was using a stock intake, stock 6 speed flywheel, type 1 crank pulley, and stock chip.
One thing to note though, I'm using a JDM motor now, so perhaps there is some difference. I wouldn't really think so, but maybe that's it? Then again, the ratio of HP to TQ on the usdm motor was about 1.07. On the JDM, with the new mods, it's about 1.095. Seems consistent, considering the synergistic effect of each part on the other.
#141 (permalink) |
Finally a dyno from you!
But again whats with the dynapack. Not to say its not as good or anything but to remain consistant with the rest of Legend dynos we should all strive to remain on the same power measure standard. Second guessing is the name of the game with different dyno systems. Every dyno measures differently especially dynapacks. They're all calibrated different some have more loss than dynojets and some see as much as a 20% gain. Eitherway, if you go and dynojet the car i think youll be dissapointed. That TQ number is still way high even after your dynojet conversion. Maybe the JDM motor has higher compression who knows. Last I checked Kenso has 203tq w/cams. I would suggest some 1/4 mile times, that would tell me if your dynos are fact or fiction. Eitherway, great job ~Dv8
#142 (permalink) |
Of the Telion Chip
Damn, Ko those are some sweet numbers you put up congrats man
#143 (permalink) | |
Type II King
#144 (permalink) | |
Gimme a cookie.
tried to gather up as many dynos as I could
Code:
#145 (permalink) |
"the Don"
Correction to your chart:
208 WHP and 189 ft.lbs --->> MUSTANG DYNO 211 WHP and 182 ft.lbs --->> DYNAPAK I did the DYNAPAK run about a year before the MUSTANG run and the only difference in mods between the two was removing my "home depot" intake and installing a Weapon-R Secret Weapon intake with cold-air box. Since the MUSTANG dyno I installed pullies and replaed my Bayou Stage II chip with SR5GUY's Stage II chip. I would like to dyno now with those 2 mods and see the results. I still have yet to install headers and still am running the heavy 6-speed flywheel. If I run again, I will run again on the Mustang dyno to really measure the benefit of the pullies + chip.
#146 (permalink) | |
Type II King
#147 (permalink) | |
Wheres my 316WHP and 345lbft nitrous????
![]() ~Dv8 Quote:
#148 (permalink) |
Type II King
mmm that is sooo sexy dv8, i need to get my hands on some nitrous, do you think you can let me know what to get and stuff? im not a nitrous expert
#149 (permalink) |
dealer-opted track pack
Aaron also has a reworked y-pipe which is surely a huge improvement over the OBX junk. Congrats., man! The effort always pays off
#150 (permalink) | |
I'm the Stig!
my latest numbering
3-angle-valve job; slightly shaved heads; rebalanced motor Labrat pulley's OBX headers, ypipe, test pipe; 2.5 cat back; Vibrant performance muffler 2.5in duel3 out these were done on a mustang dyno
__________________ ~Alex |
