Old 11-13-07, 09:44 PM   #166 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
Car 1: 95 LS Coupe 6spd
Car 2: 94 L Cpe 6spd - sold
Car 3: 98 Prelude - sold
Perhaps I will go back to MD and test the car on the 248. FYI guys, here's an article where they tested Dynos on a stock 350z:
http://www.turbomagazine.com/tech/03...ash/index.html
Code:
Turbo Magazine Dyno Dash Comparison Chart Dyno HP TQ Dynapack 249.4 242.8 DTS 257.6 556.5* Dynojet (Win) 235.8 227.8 Dynojet (DOS) 243.7 237.2 Clayton 265.7 240.6 Super Flow 228.9 226.6
You'll notice that both dynojet 248s were within 15whp and 15wtq of the dynapack. If I take 15 off of the 240/220 reading I'm looking at 225/205. i guess that lines up more with what you guys were saying about torque at least.
Originally Posted by kotetu
3 out of 4 Legend owners recommend buying a second Legend.
Welcome to the Game. Enjoy your time here.
kotetu is offline
Old 11-13-07, 11:15 PM   #167 (permalink)
Forevralegend's Avatar
Car 1: 94 Legend gs type II
Code:
agree to disagree but you cant just say you have 225 hp and 205 torque without a real dyno of that, its like me saying i should be at my red crayola line and call that my new numbers.. im not trying to be mean or anything.. but anyways great numbers none the less.
mods-
2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, Apexi safc II, strut bar, F/R sway bars, FL tie bars, tune
Forevralegend is offline
Old 11-14-07, 12:00 AM   #168 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
since you really think so, lets start a dyno fund, we all could run on the same exact dyno.
You making a crayola line and the guy who dyno's cars for living are two very different things. He is making a basis on something that has shown to be otherwise,
WHILE, we cannot say for sure that aaron is putting down 225/205 we CAN however estimate this. Just like we can make a fair assumption that my car doesn't only have 184hp/173tq but probably closer to 204+/193+ based on what we already know these motors to put down.
i have $5 ready to donate to aaron to run on the same dyno as you and DV8.
~Alex
Alperovich is offline
Old 11-14-07, 12:58 AM   #169 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
The problem is I dynoed on 3 different dynos that produce 3 different results. That's the long and short of it.
dynojet 248 != dynojet 248x != dynapak
I'm doing my best to get what the dynojet 248 numbers are from what I have. I think the two experts and the magazine article makes a pretty strong case. It was really my bad for not finding out the 248x would produce different numbers in the first place. Anyway, having now spent over $200 on dynos I think I will have to lay off for a while.
kotetu is offline
Old 11-14-07, 01:02 AM   #170 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
lol alex - then I have to drive up to the bay... XD
kotetu is offline
Old 11-14-07, 01:18 AM   #171 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Talking
Nice numbers! I don't think it really matters, either way; you've got plenty of power. Let's hook up this weekend, install some dampeners, drive to S.F. for the meet, hit The California Speedway, or whatever... I'd be cool to get videos of our cars running tandem so people can see how much faster your mods. are.
k.
mrkeith is offline
Old 11-14-07, 02:36 AM   #172 (permalink)
Dv8
Get sucked in...
Dv8's Avatar
Car 2: 03' G35c Blk on Blk
Car 3: 92'Yukon/06'Trailer
Thanks.
Bottom line, you need to stick to one dyno if your tring to compare previous and new.
The flywheel swap surprised me too, I thought by dropping 38lbs to 19 I would see a huge power gain. I saw some but not much.
Pullies. Very seldomly have I seen gains over 5 peak from these. I dont trust kyles dyno process. His before and after dynos were flawed and had way to many variables. Will they gain, yes-10whp, I dont think so.
Theres no stand out mod on your car that would yield the numbers your claiming-regardless what the tuners say. We know Legends not them. Higher compression could be one variable but I hardly doubt you have enough to bump it. If anyone can document more Legend dyno experience than me, by all means.
Now you have two dynos, a dynopak and dynojet. One is higher and thats a *Fact*(dynapack)
The other is a dynojet which gives real world legend numbers. You may not like the numbers, but I can honestly say from my experience its close to accurate with your mods.
Send me money and I'll get a dynapack dyno.
The best example is Kenso, review history. Keep in mind its not about peak but rather differences in the powerband:
http://www.acura-legend.com/vbulleti...g_searchinfo=1
These *tuners* are giving you false hope and your taking it because you want those higher numbers. If the numbers arent to your liking, dont post them, because we will point out flaws. If these number were with cams, then I would say somethings wrong.
Look at your powerband, I see over 8whp & TQ throughout compared to the last dyno. Believe it or not, thats huge. This is no V8 as it pertains to massive gains from a mod or two. Our mods yeild little to nothing.
Im not tring to come off harsh, I just think your tring to find a shade of gray in black or white.
Let it go, choose one shop and get cams.
~Dv8
Christian - I screwed up my post: the new dynojet read 212.5/198.4. Here's the unadjusted graph. I think it's pretty clear that this new dynojet reads lower than the old dynojet. I guess I should send off an email to the manufacturer to ask them about it.
foreva - Are you telling me that you think lightened pullies (kyle dynoed at 10whp gain), a 5 speed flywheel/clutch (18-19 pounds lighter?), the CAI (from the bone stock intake with resonator) AND a bayou stage 2 (thanks sr5guy) together should only produce 8whp? Sorry, i don't agree. The OBX picked up 13whp without any of the above. If anything, synergy tells us each of the items I added should help eachother out a little, so even if they individually were only 2 hp items, working together they should produce MORE than 8hp, not just 8 or less than 8.
The dynapack place I went to is highly respected. He's posted a detailed explanation of the differences between dynojets and dynapacks. His methodology (link) puts whp number for my car somewhere between 225 and 230, and wtq somewhere between 210 and 215. Now I've gone to a dynojet dyno where the operator tells me that based on his experience, on the earlier models I probably would have read somewhere along the lines of 222/208.
I think I am safe in saying the whp is in the ballpark of 220-225 and the wtq in the ballpark of 210-215. I could go drive down to MD Automotive and get a 3rd dyno done on the old dynojet. Then again, maybe you guys should get your cars dynoed on a new dynojet too.
Dv8 is offline
Old 11-14-07, 12:39 PM   #173 (permalink)
Originally Posted by Dv8 View Post
Thanks.
~Dv8
wow i couldnt have said it better myself, well put.
mods-
Old 11-14-07, 03:27 PM   #174 (permalink)
West Coast needs to get together for a Dyno sessioin and put it all to rest, LOL...
大LO is offline
Old 11-14-07, 09:35 PM   #175 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
I'm going to withdraw any objection related to gains. I must have had a total brain fart - this is the JDM engine, so there's no relation to the old engine and dyno results.
However, I do stand by my belief that two separate dyno professionals giving their opinions based on their experience (+ the magazine article), put me in the ballpark I mentioned. I will still go at some point and test the car on the dynojet 248. Also, I am waiting to hear back from dynojet regarding the differences between the two models.
kotetu is offline
