WHAAAAAH!
Dyno Results for the 3.5L swap
This was done Akron Horsepower in Summit County, which is 1050 feet above sea level. 55 degrees last night when I had this done. I didn't decide to tune the AFC today since we only did 2 runs, and I'm parking the car until the rest of the mods are done. The car will be torn down, again to have a few things installed, including headers, Y pipe, Telion Chip, and camshaft regrinds. After that, I already paid for 4 more runs to tune the AFC.
Take a look at my air fuel ratio, and the relation it has on my torque curve, or should I say, torque spikes. If my A/F ratio ran flat across the powerband, I would have a lot more torque. I have a lot of work to do, but now I know where my problems are. Also notice, my car is misfiring after 110mph in the first graph (which is about 5400 RPM). The last graph shows what happened. The A/F ratio dropped below 12:1, causing the misfire. Max power = 187.64 Max torque = 218.37 ![]() ![]() ![]() ![]() I'll copy this into the dyno thread
#3 (permalink) | |
Kia Killa
Awesome, that thing is gonna be a torque monster. What are your current mods? Stock 3.5 with eliminated VIS on a stock Type I computer? Are you auto or manual/what gear did you dyno in? Are you using the 3.5 injectors or the 3.2? Is that spike a mis-fire, fuel cut, or detonation????
-Matt
Get sucked in...
I dont know what those spikes are, i wouldnt worry to much about it since its after you made peak power. Although your A/F seems to dip down, straightening it would probably yield another 3-7 TQ. However when you install headers and a bigger y you will probably lose on that peak number and gain within the powerband. I tune my A/F for 12.7-13.7.
~Dv8
#5 (permalink) | |
WHAAAAAH!
ported and gasket matched stock 3.5L with no VIS Type I 5 speed ECU (no chip) 5 speed manual transmission, I dyno'd in 4th gear I'm using the 3.2L injectors. I'm guessing the spikes are from too much fuel being dumped into the cylinders and the spark plug not being able to ignite it.
Get sucked in...
You think the guy can fax you a new printout like your first dyno but with RPM instead of MPH?
I was going to map out your dyno accross the powerband but i cant do it accuratley unless you have the RPM as the scale. All he has to do is print it again under RPM scale. Thanks. ~Dv8
#7 (permalink) | |
WHAAAAAH!
I have one of the runs that I didn't scan before. Here it is (added to the first post too): ![]()
wow! those are some nice numbers, especially the tq.
~t.s.
legend parts fs: stock springs/shocks, jdm fenders and more!!... http://www.acura-legend.com/vbulleti...ad.php?t=79147 wireless g adapters -- http://www.acura-legend.com/vbulleti...066#post911066 |
¿HöNdÄ LëGëNd¿
Damn i'm lovin those numbers man, Those TQ numbers are GREAT!
Not much yet but, Type II Swap Custom CAI 18 in enkei evo 5 rims Koni/GC Suspension Blacked Out JDM headlights Blacked out bumper sigs Brembo Xdrilled/Slotted Rotors JDM grille Telion Chipped ECU JDM h4h 6000k HID KIT |
Of the Telion Chip
Hot digidy super torque, I bet that baby feels like a monster off the line compared to the 3.2 Lookin good!
#11 (permalink) | |
WHAAAAAH!
Yes, very much so. I have the computer out of my car now that it's parked. I really need to get it out to you. I sent you a PM.
Get sucked in...
Mike,
here's the comparisions between my first 3.5 dyno and yours. I had to use the only dyno that you had RPM as a scale. WHP 2.5 RPM me:84 you:93 3.0 me:100 you:108 3.5 me:124 you:129 4.0 me:152 you:155 4.5 me:180 you: 177 5.0 me: 194 you:185 5.5 me: 199 you: no data 6.0 me: 182 you: no data WTQ 2.5 RPM me:174 you:194 3.0 me:175 you:188 3.5 me:184 you:197 4.0 me:200 you:204 4.5 me:211 you: 208 5.0 me: 203 you:194 5.5 me: 185 you: no data 6.0 me: 159 you: no data ME: intake, Y pipe, exhaust, chip, afc. You: intake, exhaust Fairly close you edge me out in lowend while i on the topend. Probably the advantage of the chip, tuning and the Y pipe. ~Dv8
Pedobear is watching you
Mike, Looks good, especially off the line. But just like in a type I legend, around 4500, the tq starts to fall off hard. Thats why your HP numbers are so low. Headers, y pipe, etc, any breathing mods are going to help you big time. You want to open it up as much as you can. Shorter runner in the manifold, longer primaries on headers(i think, i will have to double check that) The tq will get you off the line, but after that you are going to have to spray it or really open up the breathing to get more out of it.
Oh, and shouldnt you dyno that in 3rd???? |
