ECU problem!!! HELP?!?!? Dmenn??
I just got my ECU back tonite w/the upgraded chip (stage II), put it in, and my car is doing all kinds of crazy stuff now. Check engine light stays on as well as the TCS light (I figure this is probably the same problem). It's idling funny...kinda surging...like it doesn't know how much air to pull in. I drove it around the block to see if all this was due to it sitting for 2 weeks and then I noticed when the car hits 4000 RPMs, it starts jerking. This happens in ALL gears. It won't go past 4000!?!?!?
Anyone else had any similar problems? I know David (Dmenn) mentioned his check engine light stayed on after getting his back and he had to ship it back to PPP. David, what's the word? Did you get it back yet? |
aka EYE SORE
Man, you guys are freaking me out as I live in Canada and it cost like $50.00 shipping each way. I would hate for this to happen and with my luck I know it will.
Let me know if you guys find out a fix. Good Luck ![]() |
Shad - The problems you describe are EXACTLY the same that I had. The idle was surging all over the place, and then eventually started to settle down. I didn't bring it out on the roads, but I drove it through my parking garage, and when I hit around 4000 rpm, it felt like I hit fuel cut, and the car would just come to a stop almost.
I don't have TCS so I can't relate to that one, but my check engine light stayed on all the time. I tried to pull the code from the ECU by shorting the testing plug and the light still stayed solid (which I think means bad ECU). I sent mine in like a week and a half ago and I'm still waiting to hear back. They were supposed to have it fixed by Mon. or Tues. and then shipping it back out to me. Here is what was wrong with mine, and if you could check yours, I would really appreciate it, because they said what happened to mine wasn't caused by the work they did with the chip. Open up the top of the ECU - There should be 5 phillips screws there and they shouldn't be on too tight. Once you pull off the cover, you'll see the Bayou Stage II chip in one corner of the circuit board. Look VERY closely around the chip and let me know if you see anything that looks burnt or if there are any traces on the circuit board that look like they're not connected to anything. After I saw my check engine light I pulled the ECU and the cover, and I noticed that one of the traces on the circuit board was not connected to anything, and it was lifted up off the board, almost as if too much current was going through it. They said whatever they did wouldn't have caused it, and all I did was plug the stupid thing in and start the car up, so I know I didn't cause it either. Either way, they're not charging me to make the fix. They're fixing the wire, but they don't guarantee that this is going to be the solution to the problem (IT better be!) Call them up ASAP today and explain to them your problem and then get back to me and let me know what they say and what your ECU chip looks like .. I'm interested to see if you had the same problem I did .. Sounds like it could be the installer or the actual chip, but who knows! Mostly everyone else hasn't had any problems. Good luck .. -Dave |
I haven't tried plugging the original chip back in yet as I decided to wait for some daylight before messing with it further. I think Dave did though and his check engine light stayed on.
Dave, first thing after work today, I'll open mine up and look for anything that looks similar to what you described. I'll let you know... |
Mike - Yes, I pulled out the performance chip and replaced it with the Stock chip, and I still got the check engine light. I can almost guarantee it had nothing to do with the chip, but the job soldering the socket in. It looked to me like a wire shorted and fried a connection on the circuit board. Still waiting to hear back from PPP about the stauts.
*r**h *eller
Guys. I'm going to sticky this for a while. If Bayou is having quality control problems, people should be aware of it.
I just put my stock chip back in the ECU, started up my car, and she is back to normal! What a relief!!!
Now I just have to send the Bayou chip back for them to re-program. Hopefully, I won't have to send my entire ECU back. If so, PPP is paying for overnight delivery both ways cuz I can't do without my car for another week or two.I know others have had this chip upgraded with no problems, so that's the only consoling factor in all this. What's the longest anyone has had the chip? Any problems at all? Or are Dave and I the first to go through this? |
LeGeNdS NeVeR DiE!
This is NOT Good!!!
Why does **** like this always happen when you least expect it. The Stage 2 upgrade was something I always wanted to do (since you guys made it sound like it was the best thing since sliced bread) but now that I bought the chip and installed it, I start reading all these horror stories! I better take my car for a spin and see if it acts up or not. The last thing I need is to loose my summer ride because of some half-ass company trying to screw people over...
an older member
Shad & dmenn -
Don't know if you guys ever got any satisfaction with Bayou but, now that the Gen II FAQ are back on line, I was perusing the Bayou postings and remembered why I had tried a Powerchip instead. What I didn't remember is that the problems/symptoms I experienced with Powerchip were exactly the same as your problems with the Bayou. FYI what I wrote on this subject, below, appears in the thread "The Powerchip Group: +23bhp". Guess maybe we weren't meant to re-chip our Legends. - geez Lee (and the rest of you guys who might be interested) - I finally did try the Powerchip Gold in my '94 Legend LS Coupe with auto tranny, RM Racing intake and 2 1/2" Stromung catback exhaust, ecu code 37820-PX9-L67 (originally a California car). Pulled out my ecu and sent it to Powerchip in Santa Monica while I was out of town on business. Reinstalled it when I returned. Unfortunately, it didn't work. The "check engine" light came on immediately and stayed on as did the "TCS" light. The TCS "Active" light would no longer light momentarily when starting and the TCS switch and indicator light on the dash would no longer function. At about 4100 RPM, power would cut out like it had a rev limiter and the "D4" tranny indicator light would start to flash until I'd shut the engine off and re-start it. I understand this is all part of a "limp home" mode when things go bat sh*t with your engine management. Fortunately, Powerchip had sent along my "original" chip which I plugged in and everything returned to normal. Powerchip went back to the drawing board, comparing my original program to theirs and enlisting the help of their experts down under with their experience on Honda Legends. They then sent me a second chip which, unfortunately, behaved just like the first. They say they've successfully chipped a Legend or two out in California that did work, but mine doesn't. I must admit that through it all they were professional and pleasant to deal with and, except for my time spent crawling around on the passenger side floor, the experience ended up costing me nothing. (I had originally gone to them based on both their US and Australian web sites, and some bad vibes I had picked up on this forum about Bayou's customer service.) Only one thing still confuses me. They maintained that the TCS system had nothing to do with their chip. Yet it acted as described, above, with both their chips and worked just fine with mine. With all three chips, I'd hook up all four plugs to the ecu and operate the car without hooking up whatever the box is that's on the bottom of the floor plate that covers the whole shebang. (I did find out the air conditioner won't work with that box unplugged, but it was just one more thing to have to mess with while seeing how the chips worked. And, besides, the original chip worked just fine with that box disconnected. Now, however, everything is hooked back up and the carpet is back in place.) They say they'll contact me down the road if they discover what the problem might be. Meanwhile, I'm just as happy not having to disembowel the passenger side floor to get to the ecu. I must admit the tips in this forum were invaluable in helping me get the ecu out in the first place. Thanks, guys! - geez |
Legend Almn
The d4 flashing and the check engien light coming on was happeneing to me also, but I had fixed that problem with the speed sensor, and reset the ECU and now everything's normal, but it seems as though my car isnt moving like its suppose to though as far as it was. Maybe I should give them a call tomorrow. The check engien is not coming on and the D4 is not flashing anymore. It seems as though its fixed.
1993 JDM Hybrid (Sold) 3/29/04 '04 350Z Chrome Silver Touring Package (Brand New) 3/29/04 |
#15 (permalink) |
K L E A N M O D™
I have an auto 95 L and my idle is sorta wierd since I put the chip in. Like if you first start the car and let it sit to "warm up" the engine slightly revs by itself.
I never had the check engine light or anyother red flags thrown at me from the ECU, but it seems as if the RPM's when @ 80 MPH just slowly move from the 4000 mark. i's like the 4000 RPM mark is all the power she has. Granted that I really dont need to be going faster than 75 MPH anywhere but can this be a problem?IMO the Chip in conjunction w/ CAI & Exhaust are the BEST preformance mods you can do the the Legend.
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
