Legend Agent
Engine Computer Hardware Research (No 56K)
My theory is that a better understanding of how the ECU is set up in hardware would lead to it being much easier to understand how the software operates it. My current project is to document all of the on-board IC components, then hopefully, with some help from other board members, make some basic schematic and block diagrams.
This is what I have figured out so far, if there is an interest I can imagemap this picture with links to download the PDF files.
The dude with a chip on his shoulder. Stop asking me to compare my chip with Telion's damnit. Mines better. No, really, stop asking ![]() The Legend Garage |
Legend Agent
Legend Agent
I need your help in identifying: IC402, IC501, IC804 & IC700 (all Matsushita)
Here are links to download individual PDF datasheets for the IC's. Hitachi 6435328CP10; H8/532 MCU: http://other.ditcorp.com/legend/datasheet.pdf Matsushita 27C256 ROM Chip: http://pdf1.alldatasheet.com/datashe...27C256-10.html There is a much better pin layout in this datasheet for the SST 27SF512 (compatible with 27C256): http://www.sst.com/downloads/datasheet/S71152.pdf IC420, IC418, IC417, IC416 Hitachi HD14051B; Single Ended Analog Multiplexer http://www.datasheets.org.uk/datashe...rticle=1612521 IC412, IC419 HD74HC14; Hex Schmidtt Trigger Inverters http://www.ortodoxism.ro/datasheets/...or/mXuwtrz.pdf IC605 Hitachi HD14069UBP; Hex Inverter http://www.datasheetarchive.com/data...rticle=1612552 IC435 Hitachi HD74HC00P; Logic Gate Quad 2 Input NAND http://www.datasheetarchive.com/data...rticle=1621483 IC431 Hitachi HD14011B; Quad 2 Input NAND http://www.datasheetarchive.com/data...rticle=1612400 IC802 Hitachi HD14025BP; Triple 3 Input NOR Gate http://www.datasheetarchive.com/data...rticle=1612475 IC803, IC603 Matsushita AN6913 Dual Comparator http://www.ortodoxism.ro/datasheets/...nic/AN6913.pdf IC407 Hitachi HD74HC139; Dual 2 to 4 Line Decoders http://www.ortodoxism.ro/datasheets/...or/mXrtqux.pdf IC101, IC601, IC804 JRC 2904DX; Dual OP-Amp http://pdf1.alldatasheet.com/datasheet-pdf/view/114306/TI/LM2904DR.html -Matt
Legend Agent
Here is a virgin picture of the above, this is a PY3-A72 ECU, by the way.
#5 (permalink) | |
AKA Smartjay28
i dont think the barometric sensor is located within the ecu bc if you look at the case design, its air tight.
#6 (permalink) | |
Legend Agent
http://www.arnach.net/service/png/pg0217im.png It says, in not so many words, that the atmospheric pressure sensor is built onto the ECU board. (which is not airtight, btw... there are plenty of gaps between the connectors and housing). I am ASSUMING that this is the barometric/atmospheric pressure sensor. It also a logical explanation as to why it has a small hole in the side of it to atmosphere. -Matt
isn't a map sensor techically also a baro sensor so therefore it would be under the hood. Just confused.
I love your plan and i have a friend going into networking that owns a GS so i will let him know whats going on. latta! |
#8 (permalink) | |
#9 (permalink) | |
Legend Agent
If I am remembering correctly, some cars (toyotas?) actually have a solenoid valve that switches the map sensor from intake vacuum to atmosphere. Does anyone know how the ECU would use the information from the baro sensor? -Matt
Agreed ^. If you drove from sea level to 10,000 ft above, the baro sensor will read this and change fuel and spark based on the amount of atmospheric pressure that is available.
There were some cars which used the MAP sensor to take a baro reading upon key on (This lead to some problems which are explained below). It doesn't matter where it's located as long as it is open to the atmosphere. For instance, when you turn your key on with the engine off, if you measure MAP sensor voltage it will be around the same voltage as you would read with the engine running at WOT. In fact, if the baro sensor went bad in our ECU, it is probably smart enough to turn to the reading it recieves from the MAP sensor during pre startup self diagnosis when you turn the key on. The whole reason for a seperate sensor is so that the car can make changes in real time while you drive down the road. There were a few older cars (I believe Chryslers), which used the engine's MAP sensor to diagnose atmospheric conditions. As you would gain altitude the car would start to run like shit. It was a TSB as a customer complaint and the fix was to tell the customer to pull over to the side of the road, turn there car off and then back on; it would then take a new barometric reading and the car would run fine. That is why they started using seperate sensors. It is located in the ECU for many reasons, such as; there is no need for it to be anywhere else, it saves wiring, it extends the life of the sensor etc. etc.
http://i26.photobucket.com/albums/c1...Picture076.jpg |
#15 (permalink) |
Legend Agent
Thanks man, I'm actually working on it right now. Trying to find a schematic program that can handle a PLCC 84 socket.. otherwise its photoshop....
-Matt
