#16 (permalink) |
"the Don"
I thinik we have an alluminum block.
G
#17 (permalink) |
so nick what was it? are the headgasket the culprits?
~Hybrid
#18 (permalink) |
B**k F***er
We do have aluminum blocks.
DV8, I'll find out tomorrow. I had to do some Christmas shopping today and only got about 2 hours to work on my car. I got it mostly apart. I have to pull the exhaust pipes off still and then I can pull the heads. I will be doing that Sunday morning. |
#19 (permalink) |
Head Gasket Kit
My car is in the Garage right now having the Head Gaskets done, I couldnt afford the genuine Honda Gaskets (£760.00 !!) so I went for an aftermarket Kits - still cost a whopping £380.00 !. But the Head Gasket isnt just the Head Gasket, they are loads of other little Gaskets and seals with it - did you fit all those, or just the 2 Head Gaskets? Personally I would never have gone with Copper Gaskets that have been made up by someone. Honda make engines to real fine tolerances, and the Gaskets need to be to the same high tolerances, you can't just look at them and say they are identical, were talking real exact fine tolerances here! But the big thing is you say this is the third time your HG has gone ! You have a serious problem somewhere else, maybe a cracked head caused by overheating.
I feel for you my friend - but I'm afraid your gonna have to do it all over again, and it is a big job, get an original or a good quality after market HG set with all the right bits and pieces, get the head checked for a crack, and get the block checked by an engineer for straightness, get everything checked out ! 1 Head Gasket failure is a nightmare, 2 is a near suicide job - but 3 !!! Man I admire you for still being here and loving your Legend!! Good luck ! |
#20 (permalink) |
B**k F***er
Well, I tore the whole engine down on Sunday. I took a few pics as well. What appears to be the problem is every cylinder was leaking compression. The gaskets did not seal against the head. I checked again for flatness with a straightedge and a feeler guage and everything is fine.
I contacted KMS about the problem and we are going to look into using a different copper alloy. We'll see what happens. ![]() More here |
#21 (permalink) |
Use a standard Gasket !!
Nick
Wow ! That is some leakage Nick. This is my advice Nick, Don't go for Copper Gaskets again, it's too much of a risk - you are doing the Research and Development work for these guys - they are the ones who should be testing the Gasket, not you. Ask for a refund (at the least! really they should be charged for the cost of rebuilding the engine again). Just get a Standard Head Gasket set, then you know it is going to work. You are not going to see or feel any real benefit out of Copper HG's Nick, despite what people say. Speak to a real Automobile Engineeer for advice, and I guarantee he will stay 'Stick with the original specification Gaskets'. You should only fit the Copper ones if they have been thouroghly tested and proven in real life, over hundreds of thousands if miles in a lot of cars - and they haven't! Remember Nick, Honda know what they are doing, if Copper was best then they would use copper. |
#23 (permalink) | |
"the Don"
Re: Use a standard Gasket !!
We're hoping that Honda at least would have re-designed the replacement headgaskets that are available to us when we run into this problem. Copper gaskets are good if you want to run any heavy F.I. or major shots of NOS, or if you are constantly ripping your engine apart and do not want a new head gasket everytime you put it back together. I wish you luck Nick on resolving this issue with KMS. In a way my poor financial situation helped me by not allowing me to purchase the HG from KMS and expereincing the same problems. G
#25 (permalink) | |
L E G E N D
Re: Re: Use a standard Gasket !!
#27 (permalink) |
Nick, checking the block with a strait edge and feeler gauge will not give you the precision you need to check for the flatness it takes to seal w/copper. I have built many engines in my day and that check just wont cut it. I know you didn't want to take the motor out of the car but to seal copper both mateing surfaces must be machined flat. Not just look flat!There are a couple of ways to flaten it in the car if it's not too far out. If anti-freeze got into the bearings you must pull it all apart now anyway or it won't last long. Anti-freeze and the material bearings are made of don't mix!
#28 (permalink) | |
B**k F***er
Re: Head Gaskets dudes!
As far as the anti-freeze in the bearings... There wasn't an excessive amount in the oil but enough to see it in the oil. I can't inspect the main bearings but the cam bearings were fine when I pulled the heads. Then again, I may not have ran the engine long enough to get the bad oil up into the rocker arm assembly. I am still debating on putting stock gaskets back on Simply because I can't afford to keep tearing down the engine. |
#29 (permalink) |
hey guys on the stock head gaskets, it's not an enginereing problem. they were not assembled correct at the factory, they get lazy and don't torque the heads down right. ford has the same problem every engine they build now, a head gasket blows within 70,000 miles. i have worked as a tech for Ford and honda dealers. i would use the stock head gaskets, just torque them right.
1988 silver legend coupe L 5-speed 110,000 miles custom Cold air intake ZEX nitrous oxide kit (65hp shot) 16" motegi Mr7 wheels with dunlop FM901 tires NOW DEAD because of stupid women drivers in big ass cars! 92 LS coupe Magniflow muffler with custom cat back piping custom cold air intake and K&N filter 90 L coupe 5-speed stock 88 coupe project (autocross racing) 77 Ford F-150 4x4 beast 400ci V8 with 425hp |
#30 (permalink) |
*r**h *eller
As many times as those heads have been off I'd consider replaceing all the bolts/studs with new.
