Old 01-04-05, 04:53 PM   #1 (permalink)
Car 1: acura vigor
Engine swap question
hi guys
YES i did read through the forums and Iam pretty sure no one has answered this before. When you do a motor swap.. How on earth do u manage to get the motor + tranny out? I have done numerous civic swaps, piece of cake, but never done something like this before where the tranny sits underneath the passanger compartment.. Do you guys take the tranny off?
By the way, iam planning to do the swap on my Vigor ( 5 speed). My alternator belt snapped, which in turn took the other two belts.. One of the belts got stuck inbetween the crankshaft pulley and lower engine cover. Timing belt skipped several teeth, and the pin that aligns the crankshaft pulley onto the cranackshaft was bent! Iam posting this here cuz the legend swap seems pretty similar to the vigor swap ( I checked the vigor forum, nothing there).
I have taken out the radiator and AC condesnor so that gives me a foot of extra space in the engine compartment. was wondering if there is a special tecnique of taking the motor out with the tranny attached. Hopefully it isn't too hard, i have to do this on my driveway and it's freezing cold here in toronto.. Worse case i guess i'll swap out the head.. but i rather do a complete swap. If any of you guys who did swaps can post of a pic of the motor going into the bay, that will be great, thanks in advance.
By the way, what about the differntial? can i leave it there ( although the service manual asks to take it off). Reason why i ask this is, u need some special tool to pull out some shaft that goes into the differntial from the tranny. Was wondering if i can leave it there while pulling out the motor
PS. my cherry picker doesn't have that tilt handle witch which u can tilt the engine.. it just has a hook to which i attach the chain .
soulman is offline
Old 01-05-05, 01:23 PM   #2 (permalink)
Car 1: acura vigor
Anyone here??
soulman is offline
Old 01-05-05, 01:50 PM   #3 (permalink)
Car 1: Legend
PM DV8, and MikeD and Mike Diaz and a dew oher may know too.
ZIPP is offline
Old 01-06-05, 05:41 PM   #4 (permalink)
Car 1: 1993 Vinyard Gray Acura Vigor; 1992 Plum Pearl Acura Vigor GS
When you say you checked the Vigor Forum, did you go to the yahoo groups forum?
http://autos.groups.yahoo.com/group/...andlegendclub/
There have been several engine removals there, and a few people have pulled trannies, so you should be able to get some good info there. I think you have to pull not only the tranny, but the differential as well. Not 100%, though.
Toronto, eh? Me too! What are you doing with that old engine?
Vineyard Gray (MR at the yahoo club)
'If everyone's thinking alike, then
somebody isn't thinking.'
~General Patton.
vineyardgray is offline
Old 01-06-05, 06:35 PM   #5 (permalink)
Car 1: 93' Black/Tan L Sedan
Send a message via ICQ to Re:Vibe Send a message via AIM to Re:Vibe Send a message via MSN to Re:Vibe Send a message via Yahoo to Re:Vibe
Are you aware that you posted in the 2nd Gen Legend forum?
-92' L Coupe 5spd/Red (totalled-d*mn freeway walls! )
-93' L Sedan/Green (She's gone! Don't ask!!! )
-93' L Sedan/Black
http://myspace-242.vo.llnwd.net/0115...56915242_l.jpghttp://www.admiration.ne.jp/car_cont...legend_f01.jpg
Admiration Body Kit
Amistad Wheels
Re:Vibe is offline
Old 01-07-05, 05:30 AM   #6 (permalink)
Car 1: acura vigor
yes iam aware, did u not read my original posting?
Similar swap for legend and vigors, i just need to know if i have to take the tranny and diff apart before pulling out the motor or if i can do that withouth taking them off , which would be so much easier. And no luck on the vigor forum, i tried
soulman is offline
Old 01-07-05, 05:44 AM   #7 (permalink)
TSX pupils
Car 1: 1995 Legend GS
Send a message via AIM to Daddymac117 Send a message via Yahoo to Daddymac117
on the G2, ive seen them removed with the tranny still attached, but yea the whole thing was tilted on the lift to slide the tranny out from under everything
FS: Weapon R Secret Weapon intake (NON TCS/Type I) in box, never used. $140 shipped.
I'll make a thread once i figure out the best way to ship it, but PM if interested.
Daddymac117 is offline
Old 01-07-05, 04:36 PM   #8 (permalink)
Car 1: 1997 Acura TL 3.2 Premium
Car 2: 2002 Acura 3.5 RL
Car 3: 1991 Honda Prelude
Well, in the TL forums, the 2.5 guys removed the transmission first.
The 2.5 TL's use the same G25 block as the Vigor.
Ken1997tl is offline
Old 01-07-05, 06:04 PM   #9 (permalink)
Pain Machine
95Legend6Spd's Avatar
Car 1: Godzilla:
Car 2: Tokyo
Car 3: Attack!
Send a message via AIM to 95Legend6Spd
Don't remove the trans - you're wasting your time. Pull the axles, then yank the motor/trans together as one unit, while laying the wiring harness on top of the motor (pull it through the firewall, away from the ECU). Use a Load Leveler to balance the weight of the trans/motor together, and hoist that junk out.
| Chris M | 1997 Toyota Supra 6-Speed | 78GTS | 17X10s NT-01s All 4 Corners |
| Old: 1994 "BoostLogic Catalog" TH400/Single 71GTQ | Advan | TRUST | HKS | RPS |
|Previous: 1995 Legend Coupe, 6-Speed 1998-2002|
95Legend6Spd is offline
Engine Swap DTMM4Legend Engine & Performance Modifications 3 01-11-05 03:13 PM
engine swap Florida_Legend Engine & Performance Modifications 11 04-08-04 03:56 AM
Engine Swap Zeppelin264 First Generation Legend (1986-1990) 3 02-07-04 08:40 AM
question about engine ticking ImportGrl Second Generation Legend (1991-1995) 6 01-14-04 11:25 AM
Need recommedation for JDM engine swap in North NJ stoporder First Generation Legend (1986-1990) 3 10-16-03 01:54 PM
