Engine and tranny swap
Well,
It's time. Today I drop off my baby to have a less than 45K JDM 3.2L engine and automatic tranny installed or swapped. I've mentioned b/4 that the original engine has over 311K and the tranny has a serious torque converter chatter. So purchased from a place in Miami a JDM engine and tranny for less than $1500! Doing some serious other detailing. FAL dual cooling fans with a blue shroud, more blue detailing under hood. Can't wait. More details when finished. Stephen |
WHAAAAAH!
very cool, sounds like you're planning on making that Legend last another 300k. Post pics when you're done.
Blue underhood
I've had blue underhood for several years. We have a local auyo paint supplu dealer that will put ANY paint cvolor in as spray can and make it Hi-Temp.
I've been using this guy for hyears on body col,ored brake calipers, under hood stuff, etc. So for my Legend which was already "blue" I opped for a more "royal" blue. Painted the fuel rail covers, the timing belt covers, the spark coils. Used blue hose covers on the hi temp, blue silicone on all the vaccum lines... Blue wire loom over the rest. Fuyse cover painted blue, blue battery hold down... And probably the ONLY Legend like this, narrow dual Flex a Lite puller fans in a blue frame (order FLA 210B). So, so cool. In fact the Legend has two fans. One for the A/C one for the radiator. Using the dual fans gets dual fans for both.!!! Anyway. Very excited. Adding steel braid brake lines too! Peace y'all Stephen |
Legend Almn
Hey if you're getting the jdm engien and tranny swapped, wouldn't you need the JDM ECU also for the shift points, since the two tranny are different, correct me if i'm wrong?
1993 JDM Hybrid (Sold) 3/29/04 '04 350Z Chrome Silver Touring Package (Brand New) 3/29/04 |
#7 (permalink) | |
Swollen Member
#8 (permalink) | |
B**k F***er
Re: I meant to add
Want another Legend
Wow, that looks awesome! Sprayed on or brushed on?
In case you missed out on the group buy, I have a full set of pullies from the group buy for sale - $440 1991 Automatic Frost White coupe - Sold 1993 6-speed Granada Black Pearl Metallic coupe - Sold 2004 RSX-S Artic Blue Pearl - Traded 2007 Mazdaspeed6 |
#10 (permalink) | |
A PX9(TYPE II) Tranny mixed with a PY3 ECU(TYPE I) OR A PY3 tranny(TYPE I) mixed with a PX9(TYPE II) ECU will yeild shift slopiness. JDM or not a TYPE II ecu will have this effect mixed in with the TYPE I tranny. the engine however will work fine, the ecu will be throwing a silent TCS code since its not there. The way to find out if you have a JDM TYPE II Engine is to see if there is a PX9 on the very top-back of the intake manifold, since they dont come badged with TYPE II. ~Hybrid
Type II vs Type I
So first. Type II refers to the engine in the Coupe w/the 6 speed correct?
I can only tell you that my mechanic did not mention any such issues and he "reportedly" has done this swap before. Back to the engine/tranny. The engine and tranny are a set, the way they were put in the car. Type II engines have the large intakes correct? The engine looked identical (just newer!!!) to mine. I will let everyone know what issues I run into. Stephen |
