» Sponsors
» Sponsors
Old 03-15-07, 04:26 PM   #1 (permalink)
Tristate Committee Member
aww-shiet's Avatar
Car 1: 94 Acura Legend L Sedan
Car 2: 93 CB7 Turbo
Car 3: 1988 Acura Legend L
Send a message via AIM to aww-shiet
Every Legend Performance Part on the Market.
I made this thread for everyone to check and see where they could find performance parts for their legend. The last thread is gone. So this is the current things you could buy for a Legend.
- SWAPS
-- 3.5l motor from the Rl. Some custom work to be done.
---WHERE CAN I FIND THESE MOTORS?
-- Carpart.com (??)
-- TigerDirect.com ($800 + shipping) (30-50k miles)
-- Ebaymotors.com (??)
-- Asapmotors.com
-Internal Performance
-- Head Work
-- Cams
-- Web Camshafts ( you have to send in your own cam, they regrind it.) ($200ish)
-- Crower (also factory regrind) ($200ish)
-- Type 2 cams are a must upgrade for Type 1 Owners (??)
-- 3.5 RL Cams have less overlap for forced induction applications. (??)
-- Cam Gears
-- Contact Buzzard (??)
-- Valves
-- TYPE II Valvetrain
-- Valve Springs
-- TYPE II Valve train
-- Port and Polish & 3 angle Valve Job
-- a local auto machine shop near you (200-300ish)
-- KMS ($450)
-- Intake Manifold
-- Type 2 upgrade for Type 1 Owners. (??)
-- Custom Gutted Manifold for Ram Air Induction
-- Bottom End
-- Rods
-- Conrods - C32A ($1,500)
-- C35A have forged rods (??)
-- Pistons - Under Construction - Will update as soon as we get a word.
-- C35A have forged pistons (??) - cant fit in c32a
-- Crankshaft
-- nothing right now
-- Sleeves
-- Swift says you could take them out and put custom ones in. But there is no need to.
- External Performance:
-- Inhale
-- Weapon R Cold Air Box ($200ish), Injen Short Ram ($150ish), and others.
-- Exhaust
-- Remus Axle Back(2.25) or Universal Remus(2.5) ($600-650). Autoaccesorystore.com
-- Stromung Axle Back ($500), Custom.
-- OBX Headers and Y-Pipe ($250-300)
-- Stromung B-Pipe (contact Fut) ($150-200)
-- SMS Custom made y-pipe (Contact Kenso) (??)
-- Custom Headers and Y-Pipe (I will tell you who to contact as soon as we get a word.
-- Spark (we got ignition coils, so no need to worry about them)
-- HKS DLI
-- Bosch Platinum 2 & 4, NGK, others. ($6-8 ea.)
-- Pulleys - Light Weight
-- Contact sr79labrat(400+)
-- Crank Pulley
-- The 91-92 Type I automatic crank pulley is a stock "lightweight" pulley. Upgrade for all 91-95 M/T cars and 93-95 Automatic cars. (??)
-- EGR Block Plate
-- DV8($10) or Custom
-- Bigger (Bored Out) Throttle Body
-- KMS Enginering ($200)
-- Contact Swift ($170)
-- Engine Mounts
-- Custom Polyurethane Them ($10)
-- Engine Damper
-- MADE! Contact Blackend
-- Nitrous Oxide System
-- Custom Installed
-- Turbo Kit
-- Custom Fabricated - Custom Header or Rear End Fabricated
-- Contact sr79labrat - (?? and not sure if it will hit market yet)
- Stoppers
--Rotors and Brakes
-- Brembo Big Brake Kit ($3000+ whole kit)
-- Brembo Rotors and Pads ($500+ whole kit)
-- OEM Sized Cross/Drilled Rotors (contact emaculate91ls)
-- Wilwoods Brake Kit ($3000+ for fronts and backs, 17" rims required)
-- Type 2 Upgrade (calipers, rotors and brakes)
-- NSX Swapped Brake Rotors & Calipers
-- 99-04 RL Slotted w/ Curved Vanes Rotors (same spec as type2)
- Handling
-- Suspention
-- Koni Reds or Yellows ($500-600 whole)
-- Ebaich, Tein Springs ($300-350)
-- Ksport Full Coilovers ($760 shipped), JIC Coilovers (??)
-- Bars
-- KMS Strut Bar (LEGEND logo on it) ($250)
-- MLS Strut Tower Bar ($250)
-- Addco Front and Rear Sway Bar ($250 both)
-- IDS Strut Tower bar (??)
-- Tie Bars
-- Contact Fut (also check out GB section) (??)
- Transmission
-- Clutch
-- Spec Stage 1, 2, 3, 4, and 5. (??)
Centerforce and Exedy (??)
--- Where could I get them? Heres the LINK.
-- Shifter
-- Short Shifter - Contact Rangerjoe ($150-170)
-- Cryno Gears And LSD Install
-- Gearspeed Inc. (??)
-- Torque Converter
Level 10 Auto Transmission Kit (includes High Stall Torque Converter and Some other things inside the auto tranny) (around $300) (pm NickD for info)
-- Final Drive
-- HondaMan LSD (contact HondaMan) (??)
-- Contact Kotetu (?? not avaible yet)
- Brains
-- Stand-Alone
-- NSX AEM Standalone Engine Management ($900-used)
-- Stock ECU
-- Bayou Equivalent Chips (Contact Nuckinfuts) ($75)
-- Real-Time Modifications software with Moates Ostrich and Tunerpro RT software (??)
-- Contact Telion for his Chips ($50)
-- Bayou Type 1 & 2 Chips (??)
MODS PLEASE STICKY. Thankyou!
PLEASE PM ME OR ANY OF THE MODS FOR QUESTIONS! PLEASE NO POSTING HERE!
aww-shiet is offline
Old 03-22-07, 10:48 AM   #2 (permalink)
Legend Anti-Christ
The Crowing's Avatar
Car 1: 1991 Legend Coupe LS
Car 2: 1984 Jaguar XJ6
What about the JUICE BOX? :p
The Crowing is offline
Old 03-23-07, 02:21 AM   #3 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
500 for brembo bbk??? u sure? lol, cause i cant find it!
Johnny Kim is offline
Old 03-29-07, 01:33 AM   #4 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
he has a lot of editing to do yet and spell checking..
otherwise pretty decent
215whp+
swift is offline
Old 03-29-07, 11:23 AM   #5 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
uhmm....so ye...bbk for 500?? lol
Old 03-29-07, 01:15 PM   #6 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
thanks everyone but respect the rules
Old 05-01-07, 10:33 AM   #7 (permalink)
NoT A MyTh's Avatar
Car 1: 1992 acura legend
Send a message via AIM to NoT A MyTh Send a message via Yahoo to NoT A MyTh
yo the bbk is 3 grand and just the rotors and pads oem size are 500 i dnt think the rotors are drilled or slotted
NoT A MyTh is offline
Old 05-11-07, 10:42 PM   #8 (permalink)
swift's Avatar
ADD 99-04 RL brake rotors to that list since they are same spec as type 2.
you may ask why....??
You can order a slotted rotor with CURVED vanes which adds to the cooling effect which you cannot get for a legend except for big brake kits.
swift is offline
Old 05-11-07, 11:30 PM   #9 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
added thanks ben!
Old 05-13-07, 12:55 AM   #10 (permalink)
Car 1: 1993 Tan Sedan L
This is more of an interior performance mod? There is a company in Italy (www.redlinegoods.com) that sells leather shift boots. Price is quite reasonable. I found it while looking through the BMW forums and discovered they have the G2 Legend in their vehicle selection.
AL
Legend93 is offline
Old 05-18-07, 04:02 AM   #11 (permalink)
ATLfoKuS's Avatar
Car 1: kA8
Send a message via AIM to ATLfoKuS
Nice write up, but I have never seen a remus retail for 230-300
ATLfoKuS is offline
Old 05-18-07, 09:31 AM   #12 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
yea i have to redo that. i posted the thread during the remus gb.
Old 12-07-07, 09:29 AM   #13 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
Mods please add.
under Turbo Kit...
-- Supercharger
-- In the works by Telion and Aww-Shiet
thankyou
Old 12-07-07, 09:36 AM   #14 (permalink)
OG Kush
Blingting's Avatar
First of all...Andrey, nice fuckin' thread man.
Second, KMS bars are not quite $200...even shipped. KMS Engine Development is local to me, out in Covington, GA.
I've asked, and if I drive down there its a flat $150, however if it needs shipping to anywhere in the continental U.S. its around $170-175 tops.
Here is the standard link on eBay for purchasing, this listing/auction has been going on for years so add it to your post.
WASSSSAAAAAAAAAAAAAP.
Blingting is offline
Old 12-07-07, 09:44 AM   #15 (permalink)
aww-shiet's Avatar
Car 2: 93 CB7 Turbo
bling you will have to ask the mods to change it, i do not have any more access to the post anymore. i cant edit it.
but WAZZZZZZZZZZUPPPPP
DIY: 3.2L to 3.5L engine swap (+ Type II Swap, Hybrid, and JDM Information) Mike Diaz Engine & Performance Modifications 189 02-09-10 12:45 AM
Every BodyKit(ground effects) for G2 Legend!!! Ballistic Second Generation Legend (1991-1995) 81 09-14-06 12:06 PM
A-L.com member rip off - ACURA KING Shaylord The Lounge 42 05-17-06 04:42 PM
performance comparison 04 accord, g2 legend kstallguy Second Generation Legend (1991-1995) 19 02-11-04 07:54 AM
Legend Performance Parts? JTMoney102 Engine & Performance Modifications 4 08-31-02 02:48 PM
