Old 09-21-07, 11:00 PM   #1 (permalink)
Car 1: 92 LS
Car 2: 91 SE-R
Car 3: 1955 jeep willys
Front Engine mount question
Hello all,
Recently purchased 2 part polyurethane 60a hardness.
The plan is to redo the mid and transmission mount for my 92 automatic.
The question is the front mounts, upon removal, driver side front was torn.
What to do?
at the moment i have filled the broken mount and inverted it while it cures. Im sure the mount can handle downward pressure, but am unsure if it will separate if the engine pulls upwards. I cleaned the inside of the mount very well hoping for good adhesion, but im just not sure polyurethane works that way
What is everyone else doing for their front mounts? Did a search but did not find any final ideas.
92 4DR LS, 145k
Type II rotors/calipers, brembo/hawk hps
Stainless steel lines, ATE blue
17" OZ rims
Addco rear sway bar
Ksport coilovers
Telion Chip
kotaro is offline
Old 09-21-07, 11:07 PM   #2 (permalink)
Type II King
Forevralegend's Avatar
Car 1: 94 Legend Gs type II
Originally Posted by kotaro View Post
Hello all,
What to do?
i used polyurethane on my front mounts and the centers were torn, its holding up perfectly with no problems.
mods-
Forevralegend is offline
Old 09-21-07, 11:24 PM   #3 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
91-92 used 2 hydraulic front mounts
93-95s used 3 front mounts the sides are rubber.
and the hydralic mounts were moved to the mid mounts.
**Anti Alpine Type-R Thread**
bl420 is offline
Old 09-22-07, 10:33 PM   #4 (permalink)
Car 1: 92 LS
Car 2: 91 SE-R
Am i the only one who has filled a hyrdaulic mount with poly?
well once i do the centers and rear I will post whether it holds or not. I am a bit skeptical.
I think the combination of ksports and NYC driving finished off the mounts.
92 4DR LS, 145k
17" OZ rims
Addco rear sway bar
Ksport coilovers
Telion Chip
kotaro is offline
Old 09-22-07, 11:11 PM   #5 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
let me know how it goes...
im contemplating filling the fronts too.
bl420 is offline
Old 09-22-07, 11:19 PM   #6 (permalink)
'hood Garage
hotlavaflow's Avatar
Car 2: KA24DE-T S13
I just bought new ones and installed them cause I was lazy but if you get it done update so I can see.
hotlavaflow is offline
Old 10-13-07, 12:17 AM   #7 (permalink)
Car 1: 92 LS
Car 2: 91 SE-R
well, filling the front engine mounts didnt really do much. The mount controls downward pressure well, but doesnt hold the engine down well, allowing the engine to lift. I get increased vibration when the engine position lifts a bit. I am thinking of fabricating a new engine mount the prevents engine lift. Anybody have any tips for doing this?
92 4DR LS, 145k
17" OZ rims
Addco rear sway bar
Ksport coilovers
Telion Chip
kotaro is offline
Old 10-13-07, 01:06 AM   #8 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
Hot really but I am using poly front mounts to drained all teh fluid filled them then ran about a 1/4" layer around the outside and it is SUPER stiff lol.
Telion is online now
Old 10-13-07, 01:26 AM   #9 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
4 words. Blackend Motorsports Engine Damper. works wonder i hear.................
~Alex
94 GS
Alperovich is offline
Old 10-13-07, 11:40 PM   #10 (permalink)
Car 1: 92 LS
Car 2: 91 SE-R
telion, i will try pouring poly on the outside of the mount. Did you do anything special for good adhesion? Sounds like a good idea.
92 4DR LS, 145k
17" OZ rims
Addco rear sway bar
Ksport coilovers
Telion Chip
kotaro is offline
Old 10-15-07, 02:33 AM   #11 (permalink)
Of the Telion Chip
Telion's Avatar
Not really, just cleaned them really well and made sure they were dry and free of any hydraulic fluid. I saw somewhere that it is a good idea to rough the surface a bit though so the poly has a rough surface to adhere to; which is similar to nearly any other type of bondig procedure.
Old 10-15-07, 02:34 AM   #12 (permalink)
Of the Telion Chip
Telion's Avatar
I certainly hope so it's on the list
Old 10-31-07, 09:20 PM   #13 (permalink)
Car 1: 94 white L coupe 6spd
Car 2: GS400
Car 3: ae86
Send a message via AIM to toyotas4life86
i have a 94 coupe 6spd i bought sum 3m window weld two tubes is that enough and is it right its also super fast window weld hopefully it will hold up??
toyotas4life86 is offline
Engine Mount Question Realtor Second Generation Legend (1991-1995) 0 06-11-07 05:09 PM
Should I sell?worth? Got quote: axles, transmission mount (sort of) and engine mount 92Legendsedan Second Generation Legend (1991-1995) 1 03-26-05 01:52 AM
Engine Mount question... RangerJoe Second Generation Legend (1991-1995) 0 01-21-05 04:16 PM
question on how to replace engine mount will_b First Generation Legend (1986-1990) 5 07-22-04 01:35 AM
Question about Tranny mount and engine with blow HG Van. Legend Second Generation Legend (1991-1995) 1 10-08-02 06:57 AM
