WHAAAAAH!
Gutting interior, removing excess metal, fuel cell, and things I can remove
I'm going over a list of things I'll be removing on my coupe. I need a little bit of help to remember how many things I forgot.
So far the list looks like this: 2 Airbags w/steering wheel (will replace with racing wheel) ABS module under center console Dash top Dash bottom Glove box Center console with radio trim Climate control unit 2 front seats (will be replaced with 1 racing seat) rear seat 2 visors Headliner with A,B,and C pillar panels 2 door panels 2 rear side panels rear deck door sills floor carpet sound deadening material on floor (I have a trick for removing it, dry ice) Trunk carpet with pockets a/c compressor with lines a/c condenser spare tire and jack both front and rear fender liners factory airbox and resonator (using my old Akimoto SR intake for now) windshield washer resevior windshield wipers and motor cruise control servo Exhaust heat shields (will be running glass pack right after the Y pipe) fuel tank (installing a 4.5 gallon fuel cell in spare tire well) Ok, here's where I need help. I bought a pack of 20 cut-off wheels for my grinder, I plan on removing the rear deck and installing a strut brace, I'm wondering what kind of strut brack will fit best. Another prelude front brace? As far as the fuel cell goes, how deep will it need to be to fit the fuel sending unit into it? I've never had to remove mine, so I don't know the size. Are there any fuel cells that are better than the other? Here's where it gets complicated, I plan on running with Lexan windows and no window regulators, because I plan on removing a good amount of metal from the inner part of the door panel. Does anybody know of a way to turn this thing into a manual crank window? Just on the driver side. Any ideas would be great. You guys don't realize how much extra metal is not needed for this car to perform. I went all through the car on Sunday and I'll bet on the fact that I can lose over 200 pounds with that cut off wheel. The only thing I'm concerned about is installing the roll cage and how heavy that will be (est. 200 pounds) Last but not least, any ideas on making an inner door handle work without a door panel? I don't want to separate the inner door handle when selling the door panel. The goal is to get the car to a safe 2500 pounds. Any suggestions are appreciated.
Hi! I'm Ryan.
Is this going to be a strip/track car? Streetable? If not streetable then:
-no catalytic convertor -front and rear windows replace with lexan -make a sliding panel on the driver's window or just use netting. -carbon fiber hood. -rear seatbelts/tensioners -replace sunroof with solid lexan and maybe even cut more of the roof out and replace with bars - Lighter wheels - entire carpet etc. |
hey mike it think you can get it under 3000, but 2500 sounds very hard bro, i know you know what your doing so have fun. i know that the driver seat is like at least 100lbs or more, i remember moving mines and they are heavy as all hell, it took me and my brother to carry it safely, passenger seat is also heavy but not that much cause i have an L model. Aftermarket seats are like 30 lbs, so thats the mod im doing, then ill think about other stuff. have fun bro, i really wana see the result of this mod, if u can get the weigth down without making the interrior look like dog poop, mad props bro, im gonna be following ur foot steps soon,
http://www.imagestation.com/picture/...a/f3eda75b.jpg Ram Intake Remus exhaust Bayou Stage2 TB Coolant bypass Blue Ground kit DV8 y-pipes & high flow cat. |
I can't think of anything, other than plastic covers in the engine bay, the power steering pump, and starving yourself.
![]() As far as getting the door open, you would have to anchor the cable to the door, in the same way it is normally anchored to the back of the door handle, and then tug on it (pretty hard too) to open the door. I think you could rig a handle to it pretty easily. I could send you my broken door handle if you could use it, the piece that anchors the door cable has broken off (common problem).
Looking to Buy: Legend-Specific Remus http://home.wideopenwest.com/~lcorte...signature5.jpg » Latest pictures of my Coupe -- Leon's G2 FAQ -- G2 Stereo FAQ -- Forum Rules « |
power steering, ac condensor and stuff related to the ac, you can take out the heater, take out all the smog check stuff, carbon fiber bumper,hood,fenders...(the toyota soarer in D1GP has this done)
#12 (permalink) | |
WHAAAAAH!
I forgot about mentioning the heater core, and all the piping behind the dash. Seeb, the interior will probably look like crap, but I'll tint the lexan. The exterior will look pretty much identical to what it is now. Unless, of course, I do that fiberglass front end. Dethred, it's going to be an Auto-x car to start with, but once I start really getting into the performance side of it, it probably will turn into a drag car. I'll definitely be running the car with a bone stock engine when the weight reduction is done. Tyler, maybe I could paint it orange and put the 01 on the side. Speaking of that, can anyone photoshop that onto this pic? ![]() If somebody has the time, can you black and white checkerboard the car in photoshop?
#13 (permalink) | |
Legend no more
'93 Legend Coupe LS - 6-speed (fast, pimp) SOLD ![]() '96 BMW M3 (faster, but less pimp) '95 BMW M3 (fastest, not pimp, track car) '88 Nissan 200sx - 5-speed (ice race, winter beater) '06 Subaru Impreza - 5-speed (grocery getter, winter fun) 2nd Generation FAQ...Click here http://www.macrocosm.on.ca/images/m3_sig.jpg |
#14 (permalink) | |
Legend no more
Aftermarket seats can be about 12lbs. I agree the most savings is going to be in the interior and sound deadening, but I think you're being highly optimistic to get it down to 2500. Even a fully race prepped M3 is hard to bring down to 2300, and this is with hood, trunk, fenders, doors, all in CF. An M3 starts at 3050lbs. Loosing 1000lbs form a car is almost impossible unless you tube frame it.
All that siad, even if you lose 500lbs, you will have a car with basically the same performance as a stock M3 ... do some suspension work, and you're good to go! Ps... the proper sequence is: Drag --> AutoX --> Solo I --> Wheel to Wheel! Quote:
#15 (permalink) | |
WHAAAAAH!
Why drag first? I'd love to get into wheel to wheel at Mid-Ohio next year. I don't think I could hang with the other V6's until I get serious into the engine modification.
