Speas Meo En Deo Est
Ignition Light Ring / Security Light ? LED Bulbs
I didnt see anything specific to these questions so with that, i'll fire away....
1. The light around my ignition went out. Any way to replace with a LED bulb? 2. The security light (by the door lock/red light) is out on my legend, while i know it isn't the end all be all in security, does anyone know how to get the light flashing about as a visual deterrent?
"got that medicine, for everybody sick, and i rep New York, like i play for the KNICKS!" The first step is to admit you have a "problem"....... http://www.acura-legend.com/vbulleti...lt-day-130286/ |
#4 (permalink) | |
burning dinosaur bones
If that's the case then, in the handful of legends I've been in, I've never seen one working. I guess I wouldn't be too anxious to replace it if it burned out. |
Yes they all constantly blinked with the doors locked. Its not the LED itself but it may be the little switch the LED sits on. Mine is out as well and i took it out when i was cleaning my door panels. Tried to test the LED for resistance and the tiny amount of current from my ohmmeter lit the light.
Fixing legends is easier than fixing lolcats, but the parts are way more expensive.. My Wiring Nightmare..http://www.acura-legend.com/vbulleti...59/index3.html |
L E G E N D
You can definately change the light around the ignition, unfortunately I did it so long ago I've forgetten which # it is. I'm pretty the one I got for the Sedan (Blue) was from SUPER BRIGHT LEDS home
It comes off pretty easy. I'm looking to get one for the coupe in the future, a red one...
Thanks for the help. when i bought my g2 i knew it was kinda sorta a fix er upper. just didnt know if those light stayed on. will try and get a manual and see what i can find out. will pass on info!
#9 (permalink) | |
i didnt end up using the stock bulb socket, i just rewired it to a led bulb or two. Took a dremel and drilled some slots for the leds to sit in and it was good. |
what size LEDS?
any size will work if you're willing to do some drilling and modifications. I dont know what the led size you would need if you wanted it to just slide into the oem socket. i know the oem bulb is extremely small. just take it apart and you'll see what you have to work with.
gotcha
