LinkBack | Thread Tools |
Rating:
Display Modes |
#17 (permalink) |
the upper Intake manifold, is rough, very rough. is it worth spending 395 to have extrude hone polish it up? Does it seem like a bottle neck? For the moment forget about the exhaust manifold, pretent they are optimal.
~Hybrid
#18 (permalink) |
*r**h *eller
If you want to get maximum possible performance: Yes.
#19 (permalink) | |
The Mac vs. The Mack
you'd be suprised at how little amount of roughness can hurt power... its worth the the money...might even take (speculation of course) a tenth, maybe less off your time.
"Untainted by Concept of Limitation" -BozzSpeed ![]() -Reiko my baby -The MAIN person Thank you Leon. Your words help God said it, and it was so. Forum Rules flossin, breakin off the intersection crossin
RL'in, ackin a iz-ass on them bosses |
#20 (permalink) |
From Experience...
I you decide to D.I.Y. you might want to invest in the highest RPM drill you can find, buy the proper grinding bits and polishing wire brushes. You can spend a good 3 days (5 straight hours each day) and do a very good job. If you want to know the whole process just ask me, but its very long. Gains are minimal. a good (.1) can be dropped. If you decide to send it to Extrude Hone you probably wont gain much more. I put my life into that intake manifold and I was just happy that I did feel the slightest gain. Good Luck
Its all MENTAL. The KEY to sucess is Strength in knowledge. Last edited by Just some guy : 01-26-03 at 11:56 PM. |
#21 (permalink) |
502MotorSports.com
I think I like your sig [some guy]...that's a good start...now make it work for you bro...just be cool, and remember what I said
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | Final e39 Pics | 502MotorSports MySpace |
#22 (permalink) |
B**k F***er
If you don't send it to Extrude Hone go to a body shop and have them hot tank it. That will get rid of all oil deposits, grime buildup and lef over gasket peices. Making it much easier for you to start porting and polishing it. Additioanlly you can have it bead blasted for asthetics. It comes out that dull, pure aluminum color, I then clearcoated and baked mine for a nice look. But you can paint it any color you wish at that point.
After you port and polish anything have it sent back to the machine shop to be hot tanked to assure all metal filings and any residue left over from the polishing process have been removed. Hot tanking is cheap, I was charged ~$15/peice and it's worth it for cleaning. Saves endless hours of sitting there with wire brushes, carbuerator cleaner and laquer thinner scrubbing away. |
#23 (permalink) | |
*r**h *eller
#25 (permalink) |
*r**h *eller
Unlocked. Contentious posts deleted.
#26 (permalink) |
Fast & Furry-ous
Variable Intake Systems
I'm familiar with several engines that use a variable intake charge system. Toyota calls it TVIS; For Mazda it's VICS....regardless of the name or manufacturer, the priciple is the same: The heads are optimized for breathing the large amounts of air needed at high RPMs, but this causes a problem....at low RPM's the smaller volume of air is moving too slowly to mix well and give you the torque you so desperately want and desire. A valving system is introduced into the intake manifold to reduce the flow rate, in turn speeding up the smaller intake charge, causing it to mix better and burn more fully and evenly. As for removal--- that's a highly charged(pun intended) debate in any engine forum that has any type of VIC system, and there's theory, evidence, and dyno sheets to back up any side. But for the most part, a stock engine generally needs it;badly in some cases. A mild to moderately modded engine= arguements. It's a balance of what you have, what you want, and what you want to give up. Most cases of "productive" removal involve cams and/or cam timing. For instance, my little MR2 had the TVIS removed, but the exhaust cam has been adjusted to bring back the low end. Heavily modded and big forced induction-- yeah, you'd probably want it out of the way....but that's not for me to say, every project is different. Porting and Polishing In the head, porting and polishing is often done, though modern day engines don't respond as well to this as much as the old days without there already being other mods which the ports in the head are becoming a bottleneck for. Here's the key though-- Porting is for moving a larger volume of air. Polishing is for increasing speed of the air flow. Here's the kicker though....most old school engines are ported on both intake and exhaust, but only the exhaust ports are polished! The reason being is that the small amount of surface "rough", though not as bad as what you're describing in the manifold DV8- just not shiny, is good for tumbling the air a bit to help mix that air/fuel some more. But the exhaust side you want moving out as fast as possible, and a nice polished port helps create the laminar flow that really gets those gases moving, and improves scavenging. And lastly(mostly directed to DV8), the oil in the manifold can be pretty normal, especially since I'm guessing you like staying high in the revs? Where that oil is from is most likely from the PCV line. Pick up(or make) a catch can, and install it to prevent it from getting that bad again.
JD http://home.comcast.net/~spastic_muse/cres_sig.jpg Black '93 Legend L 6spd Coupe Black '87 Toyota MR2 T-bar |
#27 (permalink) |
502MotorSports.com
unsticking and adding to the FAQ.
Thanks Chris ![]()
#28 (permalink) |
don't make it that smooth
will give you a hot tip for max power. (1) the Legend is too heavy and the suspension to fragile to be a real racer so we should all give up on trying to do this and enjoy the comfort and ride of a wonderful touring type car. There is no finer.
(2) If you must race and want to have it ported, don't make the porting so smooth that it is like a mirror or you will create a laminar flow and get less air through than if it was a little rough. If the flow becomes a laminar flow, you will lose perhaps more flow than a stock manifold at high rpm. (3) pay equal attention to the back side of the valves. Consider swirl cutting and polishing them. 3 angle minimum. Flow each valve. (4) My guess, and it is only a guess, is that the throttle body and exhaust manifolds are more limiting to HP on our engines than the manifold and heads. Someone willing to spend some time on a dyno tuning these items into a better flowing air intake and set of headers would probably benefit more from it then they realize. It isn't just about size, harmonics have a lot to do with getting air through an engine. Air + fuel = hp. More air, more HP. Last - I don't differ with the prior post as to laminar flow down a straight exhaust pipe because it probably doesn't happen except at the outside edges of the flow. Laminar flow in an intake manifold on the downside of a turn can significantly cut the size of the flow.
Best Wishes Steve Last edited by Merlin the Wrench : 07-15-08 at 01:18 AM. |
#29 (permalink) |
Wow, I think that's a record ressurection.
5 years 3 months. A lot has changes since those posts merlin. Thanks for the input though. The legend is heavy, but weight reduction is a must. I have managed 380lbs in track form. 340 lbs in DD form. About the suspension. Independent rear and wishbone front? Thats a pretty nice set up if you ask me. Stock springs and struts need to go though if you plan on racing, K sports are the answer. |
#30 (permalink) |
front sus
Beautiful design but light. Found that out when a gal in a rabbit tapped my right front when she changed lanes about 10 years ago into my 1992, it completely collapsed with the tire under the wheelwell. Her rabbit was barely dented on her fender. My whole right front suspension was trashed and the car ended up totaled from the damage it did.
Best Wishes Steve |
