Old 08-24-07, 09:54 PM   #61 (permalink)
Blackend Motorsports
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
Originally Posted by LegendGT1 View Post
Wow its about 4 bills and it doesn't look much different than ours.
Exactly...more than likely the same type of damper I'm sourcing and custom brackets. I see one of their brackets is pretty beefy...welded bracing, but that still should only push up the price so much.
Originally Posted by MountainLegend View Post
and just my .02, you may be good, and you probalby have some skill, but you do come off as an total assneck...better to say nothing, goto NALM '09 and rock the hut on the autocross and shut them up and let eveyone tell you how good you are, not vice versa...and around here, they build them, race them, wreck them, and then post the story, share the vid, then trade the parts around of what still works... this is not like any other car forum...
Blackend is offline
Old 08-25-07, 07:47 AM   #62 (permalink)
EDM KA8 owner
lgnd's Avatar
Car 1: EDM KA8 '91
Car 2: EDM KA8 '91 RIP
http://www.gt-rom.net/gtrom/gtone/en...rquedamper.htm
the "special washers" under and above the heim joints are lookin' good, I think those washers prevents the the heim joint eyelets to touch the brackets.
lgnd is offline
Old 08-25-07, 01:26 PM   #63 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
Agreed but the problem is sourcing those. I've just been using Dynamat on the bracket surface along with o-rings to insulate the Heim joint from the bracket.
"King of Kleen"
stevieray is offline
Old 08-25-07, 01:31 PM   #64 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
Tru, tru but the big difference I see is that the NSX brackets have the mounting bolt and some type of insulator built in. That has got to help has far as stability & vibration.
"King of Kleen"
Old 08-26-07, 08:05 PM   #65 (permalink)
Blackend's Avatar
We have access to some similar washers that let the heim joint articulate around it...it's shaped like a cone on one side, but they're about 8 bux a piece and they don't do anything to reduce the vibrations. We tested all the configurations of what they had and the way the kits were sent out were just about the best of performance vs. additional noise and vibrations.
The only thing I think we'll change this time out is the orientation of the damper...meaning we'll have the adjustable end on the firewall side as opposed to the engine side like the first set we sent out.
I'm also going to build a jig so when we set them up the length is exactly where it needs to be to stop the rattling that some people were experencing since there wasn't enough tension on the heim joints.
Blackend is offline
Old 08-28-07, 12:23 AM   #66 (permalink)
Blackend's Avatar
Up to the top. Couple more people and we'll kick this thing off for real.
Blackend is offline
Old 08-28-07, 07:46 PM   #67 (permalink)
FromaQ's Avatar
Car 1: 94 Acura Legend sedan
Send a message via Yahoo to FromaQ
do you have a pic of them on a legend? what's involved with installation? (i so hate that lag from gas pedal down till i feel the thrust forward) thanks
FromaQ is online now
Old 08-29-07, 06:13 PM   #68 (permalink)
Blackend's Avatar
There are lots of pictures of them on this forum and detailed install instructions are sent out with every kit.
Here is a picture of it installed on EarlThePearl's car:
Blackend is offline
Old 08-29-07, 09:46 PM   #69 (permalink)
Youre wrong...
Double Glow's Avatar
Car 1: 94 Legend L Sedan
Car 2: 94 Honda Civic Dx
Send a message via AIM to Double Glow
well...you can add me in, as long as payment for the Gb is after sept 29th!
Double Glow is offline
Old 08-30-07, 11:42 AM   #70 (permalink)
Blackend's Avatar
Gotcha added!
Blackend is offline
Old 08-30-07, 11:45 AM   #71 (permalink)
The Great White North
tw1st's Avatar
Car 1: 95 Black on Black LS 6-speed
i think you should start the group buy within a month of posting (i.e. in the next couple days) so that interest doesnt fizzle, as well as this not dragging out longer than it has to..
Lets get it going
Installed:
JDM Headlights with HID Retrofit,
Weapon-R Secret Weapon, Remus Exhaust,
Metal Substrate High Flow Cat,
MLS Copy Bar, Addco Rear Sway Bar,
Eibach Springs on Koni Reds,
Blackend Engine Damper, 17" RSX A-spec Rims
tw1st is offline
Old 08-31-07, 08:20 AM   #72 (permalink)
mods: yes PLEASE!!!!
bboarder711's Avatar
Car 1: 1995 SE white/silver
Car 2: Flexdex Pro 36
Car 3: Nikon D70
2 more people!!!! come one
My Mission:
-To create the hottest OEM "looking" legend.
http://www.legendaryphotos.net <-- Recently updated!!!
A-L.com T-shirts + Hoodies for sale! <-- Click
Thanksgiving Tristate Meet Nov 22 '08
bboarder711 is offline
Old 08-31-07, 04:15 PM   #73 (permalink)
tw1st's Avatar
you mean come two
Installed:
tw1st is offline
Old 08-31-07, 05:10 PM   #74 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
Originally Posted by tw1st View Post
you mean come two
Some one maybe?
blkonblkcpe is offline
Old 08-31-07, 06:48 PM   #75 (permalink)
Ladies Love the Legend
Car 1: White '93 6 speed LS Coupe
Send a message via AIM to Antares
Ok, Im in. Ive heard good things so now you only need one more.
Chuck - "...Yea I know rain then snow, you guys are killing me." Ethan - "Chuck, you still have sparkles in your PAINT!" - NALM
MODS
Weapon R Secret Weapon - MLS Copy Bar - Ranger Joe Short Shifter - Cross Drilled/Slotted Rotors - Labrat Pullies - Black Housed Retrofitted JDM one Peices - 4300K Bi Xenon HIDs - Blackend Engine Damper - Fut Rear Tie Bars - Stromung Cat-Back
SOON
NRG Custom Grounding Kit - 5 Speed Clutch and Flywheel Stage 2 - Telion Chip
Antares is offline
