#106 (permalink) | |
Of the Telion Chip
#107 (permalink) |
Hi! I'm Ryan.
Well, at least consider selling piping and stuff that is custom made, leave the rest up to buyers to pick and then there is little to blame on you (unless there is a boost leak from bad welding
#108 (permalink) |
Of the Telion Chip
lol that works,
On a side note an astute eye noticed this would never work because my example was of a sedan and I have a coupe so I fixed it ![]() ![]()
#110 (permalink) | |
Of the Telion Chip
pipe A starts at the OBX header routes upward at an angle over the backside of the tranny along the fire wall just above the heater core house the out to the point where the MAP box was then toward the front of the car pipe b starts on the passenger side of the OBX headers and comes across the trannys kick plate then up near the steering shaft and then under the OBX headers, up and over the drivers side axle then up into the engine bay where the ac was. pipe c starts under the OBX headers then follows the same path as the headers into the engine bay (the rest is just exhaust).
#111 (permalink) |
Hi! I'm Ryan.
Please consider having them each on their own side of the engine bay with minimal distance between the heads and turbo. It'll make it easier and more effective. If you're worried about looks, just look at Gary DePriest's setup and realize that with everything crammed to one side, it will be a bit messy.
#112 (permalink) |
Of the Telion Chip
I am still considering it especially if these 350z headers pan out.
#113 (permalink) | |
cashmere silver metallic 94 L coupe type2 6spd -5spd clutch and flywheel swap -weapon r sri -zfclubsport.com optimized throttle body |
#114 (permalink) |
Project Infiniti G35 Twin Turbo | G35TURBO.COM Heres another possibility. the manifolds on this kit look like they tuck in pretty neat.
#115 (permalink) |
Well, a straight six is always going to have the exhaust ports on the same side though, right? Or is it different for you import guys and your crazy multi camshafts
I like the look of 1 turbo on either side of the engine bay, but thats just personal preference.Question. I realize that on a racetrack, having both turbos as close to the ports of each head would be the best for optimal performance. In this case though, assuming he was going to drive it on the street, couldn't it actually be helpful to have one turbo further from the exhaust than the other? When i think of it, I see one turbo spooling earlier in the RPMs than the other. Wouldn't that actually help to increase the hp throughout the powerband, instead of kicking it all on at once? I used to drive my 7.0L on the street, and that much torque can get frustrating. Or have i got this figured wrong?
Fixing legends is easier than fixing lolcats, but the parts are way more expensive.. |
#116 (permalink) | |
Hi! I'm Ryan.
#117 (permalink) |
Of the Telion Chip
Ok I picked up a gasket from an 05' 350z and it looks fairly promising the shape and size of the holes are virtually identical to our cars. The difference as we pretty much knew was in the spacing between each port. in order to best determine the spacing I centered the two center holes which line up nicely and measured the variance on the outer holes. Each outer hole on the 350z is a hair over 1/2" wider than the Legends gasket. So I am thinking this could be worth a shot. At the price these are available for it would cost more than that just to buy the material for a custom set to be made not including labor, and even better I will not have to hack up my OBX headers. One thing I do need to consider though is the amount of stress that 1/2 would cause. I think it would be best to heat them up and correct the variance. here's the pics.
#119 (permalink) |
Of the Telion Chip
Absolutely, which led me to my next thought which was that I better not get the ceramic coated ones and just get the stainless steel ones where the flange is welded on this way the flange would be easier to remove and I don't have to contend with or ruin the ceramic coating when bending them to fit.
