#481 (permalink) |
Of the Telion Chip
Good point and agreed, here's my curiosity, the map sensor detects 0 to 5v (within Beavedit or Tuner Pro 0.47 to 2.97 v) in order to see what pressure the manifold is under and simultaniously combines that data with the RPM level in order to deliver the appropriate amount of fuel for the engine (all speculative to when it is actually looking entirely at the ECU map which is another issue for another day).
So if I can change the values that it looks for to accomodate closer to 5v within the bin file and adjust the maps accordingly would it be suffient to accomodate that much more psi? Now here is the second part of that (where the vacuum switch theory comes in. If I were to T in a vacuum switch that has some type of air restriction on it that would show say 2.97volts (or what ever psi that converts from) as 0.47v and 4.9v (converted from psi as 2.97v would it accomdate more boost in that 2nd map? Here is a completely ficticious analogy with numbers. 0.47v = 15psi (atmospheric pressure + engine at idle or for this example 0 boost) 2.97v = 18psi (the amount of psi the engine puts out at WOT say 3 psi over atm pres.) Then lets say the vacuum switch is set at 3 psi triggering the 2nd set of maps which would have the same voltage values on the map but with data that is configured for a boost level that starts at 3 psi over WOT and goes up from there. Ok now that I have completely confused myself and everyone else I really think I will need to see what happens when I get there.
\/Provider of The Telion Chip click here\/ http://telionsite.com or search Telion Chip 3.5, TII cams,pnp mani & springs,Telion Chip,HID's,H&R's/Koni's,Addco Sway bars,TII calipers,RH C2's,R.J. shifter,DV8 EGR plate,CAI,OBX headers,2.5" exhaust,hi-flow cat,K2 muffler,Stage III clutch,S&D rotors, KVR pads, blackend damper, a CF hood, AFC NEO, 3.5 Aluminum pulley, & Web cams. C&R Racing radiator and more to come. Last edited by Telion : 10-08-08 at 01:16 AM. |
#482 (permalink) |
This was why i was wondering about the pressure switch. I should have specified. Thats an expensive project to blow up because a filter got clogged or a pump failed. I guess my real question was/is do you think the blockforged internals can withstand it running lean in event of failure since its relatively low boost?
Fixing legends is easier than fixing lolcats, but the parts are way more expensive.. My Wiring Nightmare..http://www.acura-legend.com/vbulleti...59/index3.html |
#483 (permalink) |
Of the Telion Chip
I am guessing that in my analogy the ECU would recognize this and thow what I call a severe CEL. (one that limits the RPM's of the car to 4k) because it would still be looking for set parameters defined in the map in terms of fuel and if that's not present you get a fuel delivery CEL.
And in steps DV8 with a "That's why you should just get an EMS, lol, there's no guessing "
#484 (permalink) |
I was just talking about a simple inline fuel pressure switch wired to kill power to the coils if fuel pressure drops to zero from the pump going out or a clogged filter. I saw an NHRA funny car run dry once and it detonated and shot one of its pistons through the oil pan and about 25 feet into the ground. Now im pretty sure your Legend isn't going to be pushing 2000 horses, but still I just wanted to throw it out there if a $20 switch could insure you against catastrophic failure. Again, I have no idea if its necesary with your setup.
#485 (permalink) | |
You strike me as the type of person that wouldn't use a phillips screwdriver to undo a 8mm nut.
So stop pissing about and get the proper ecu for the job. Chris Quote:
Constant Innovation from Down Under. 530BHP. Call me whan you have more from a C32A. |
#486 (permalink) | |
~Dv8
#487 (permalink) |
6 Gears
Telion I don't know if you have your mod list posted yet. So what fuel injectors are you planning to run the venom (any size) or dsm or pte? Just trying to give some help and if you need a suggestion we could help you out on the mod list.
Oh how is the power steering bottle working out?
Just another boosted legend Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have "UNLIMITED" RL and Legend Parts PM me to discuss. NO COUPE PARTS, please stop asking For quickest reply please email me at 95LegendGS@gmail.com Thanks! |
#488 (permalink) |
Of the Telion Chip
Power steering bottle is working great and if I could get a phillips to do that I would be all for it, just kidding and youare correct I am not but I have to work with what I have and there is an alterior motive to it too, but they are cheaper
lol thanks Chris.Mod list for the build some on some not yet TI cams Ported exhaust side of the manifold Walbro 255lph fuel pump NOS fpr and Megan FPR (undecided) DSM 450cc injectors water injection cooling (still working on this have all the parts) C&R racing radiator dual oil cooler custom aluminum oil reservoir for turbos water temp, oil pressure, boost gauges turbo timer. Top fuel blow off valve 2 in 1 out intercooler 3" piping, barrel spun cat and N1 style exhaust Innovate LM-1 and RPM converter box Neo safc and possibly a few other things I am forgetting.
\/Provider of The Telion Chip click here\/ http://telionsite.com or search Telion Chip 3.5, TII cams,pnp mani & springs,Telion Chip,HID's,H&R's/Koni's,Addco Sway bars,TII calipers,RH C2's,R.J. shifter,DV8 EGR plate,CAI,OBX headers,2.5" exhaust,hi-flow cat,K2 muffler,Stage III clutch,S&D rotors, KVR pads, blackend damper, a CF hood, AFC NEO, 3.5 Aluminum pulley, & Web cams. C&R Racing radiator and more to come. Last edited by Telion : 10-10-08 at 01:02 AM. |
#489 (permalink) | |
Of the Telion Chip
So Joe my welding angel was kind enough to weld the drivers side header correction and I made sure I got the angle right this time ![]() ![]() ![]() ![]() Seeing the hood close was a joy. ![]() And yes that there in this pic would be my power steering in it's stock location ![]() ![]()
#490 (permalink) |
FRISCO LEGEND BABY!!!!
______________ 18" Limited 341 Chrome Rims/\Matador Red Paint/\Weapon R - Secret Weapon Intake/\LED Bright White Dash Lights/Floor/\Kenwood KDC-X590 Excelon Mp3 Deck/\Ford Taurus Coin/Cup Holder/\2 12" Kickers/\1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp/\2 Rockford Fosgate Capacitors/\Power Acoustic Capacitor/\Clear Rear Turn Signal/\Reverse Glow Gauges/\Swapped 88' Headlights to 89'-90'/\JDM Rear Chrome Trim/\Stromung Muffler/ Soon To Come: Rebuild Motor and 5-MT Swap
#491 (permalink) |
Looking very good!!
sidenote: i got to thinking earlier (its a filthy habit i know) and i realized that you can remove those generic 3" intake hose clamps with either a 10mm or a philips..
#492 (permalink) |
so in that pic above it actually kinda looks like there might be enough room for nsx heads.....(bring on the flamin)
cashmere silver metallic 94 L coupe type2 6spd -New two tone type F interior/ CF trim(in the mail, we'll see how it ends up...) -5spd clutch and flywheel swap -diy weapon-r cai -zfclubsport.com optimized throttle body -2.5 inch Magnaflow cat-back -koni red's. -1" front, -.75" rear -quick left, heavy right |
#494 (permalink) | |
Telion is looking really good!
http://www.acura-legend.com/vbulleti...end-sx-124851/ In memory of my son Isai "car2n" |
#495 (permalink) |
Of the Telion Chip
^ I agree 100% and thank you I can't wait for the next stage of your build which I am also watching
Legendfire my engine bay is deceptive; before thinking that there is an abundance of space in the engine bay please pop your hood and then if you decide to proceed you will know what you are getting into.
