#1 (permalink) | |
Kia Killa
My 3.5 Semi-Hybrid Swap... Progress and Information NO 56K
I picked up a complete 1998 Acura RL motor with 37,000 Miles on it.... for $350!!! I'll let the pictures do the talking!
What 37,000 miles looks like!!!!! Stripped down
RALPHS HANDS ARE CLEAN!
Car 1: 91 LS Black window trim EDM/Hids Remus 2 1/2 cat back Headers stage 3 ecu Car 2: ,Red tails, Type 2 Car 3: 6 speed, EDM spoiler iTrader: (35)
SWEET, find me one! Pleeeeeze..................
It's obvious they're both BAD for America! DEMOCRACY IS TWO WOLVES AND A LAMB VOTING ON WHAT TO HAVE FOR LUNCH. LIBERTY IS A WELL ARMED LAMB CONTESTING THE VOTE. |
#3 (permalink) | |
Kia Killa
Type II Manifold Fitted
Type II manifold dropped right in. This was just a test fit. Nothing ever works out this easy for me.
Entire Type I manifold fitted just to make sure everything lined up, clearance, etc.
#5 (permalink) | |
Kia Killa
Intake manifold comparison
Here are the intake manifolds, if you ask me the 3.5 RL manifold is pretty much identical to the Type I it has slightly longer runners. I am definetly going with the type II.
TYPE II, 3.5 RL, TYPE I TYPE II 3.5RL TYPE I
#7 (permalink) | |
Kia Killa
Throttle Body and VIS system comparison
The mounting for the throttle body plenum is identical. Type I on left, 3.5RL on Right.
The throttle bodies are identical except for a vacuum tube. The fuel purge vacuum nipple is relocated from the front of the throttle body to a 90degree elbow on top of the throttle body. The throttle body plenum is obviously different, fast idle valve is re-located and the vacuum nipples are completely different. The sensors on the water passage are swapped. Type I on left, 3.5RL on Right. The throttle bodies are the same size. Type I on left, 3.5RL on Right. The VIS system flaps are 100% Identical. Type I on left, 3.5RL on Right. The lower part of the plenum mounts up identical, but has a extra plate to block the EGR flow, I like this design much better. Instead of distributing the carbon throughout the manifold, it just stays right in that spot. Type I on left, 3.5RL on Right.
#8 (permalink) | |
Kia Killa
Water Passage Differences.... Questions
The fast idle valve is relocated to the front of the intake manifold on the 3.5. Should I install the type I water passage on the and nipple on back of drivers side head onto the 3.5 motor, or should I use the 3.5 throttle body plenum?
Type I 3.5 RL -Matt
#9 (permalink) | |
Kia Killa
www.car-part.com
There is a 3.5 in Rhode Island for $250.00 with 65,000 Miles on it. The salvage yard in Connecticut where I picked this motor up has another one for $350.00, but it has 116K on it.
damn thats alot of good info, good luck with everything man
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, safc II, strut bar, F/R sway bars, FL tie bars, ksports,tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA |
#15 (permalink) |
K L E A N M O D™
So technically a Type II intake mani would swap onto a RL block? What would be lost doing the swap (any Sensors, Emissions stuff, ect).
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
