#106 (permalink) | |
The y pipe difference was so minimal I hand pulled the y and it fit. ~Dv8
#107 (permalink) |
I have them all, just have to dig them out. I eyeballed them back in the day and never noticed any difference, but can only assume there must be. I can't think of any other reason why the Legend y-pipe would be able to fit. I know when I test fit my stock type 1 y-pipe on my mockup 3.5, it fit ok and I had the RL manifolds on it at the time. Still don't know why Diaz had problems, unless he had his heads milled down or something. IIRC he used the RL exhaust manifolds too.
#108 (permalink) | |
The sad thing is that I've thrown away tons of useful stuff because I was running out of space. I say we just trade jobs, I'm tired of mine. Then again, I have no idea how to do yours so I'm screwed. ![]() |
#109 (permalink) |
From my rough guess-timates, it's under .020" to change the cam timing 1 degree. So, if the geometry's off between the left cam and crank AND the left cam to water pump and water pump to right cam (can you see where this is going? it's adding up fast...) there could be cam timing issues. Cam timing does make a difference; there's no two ways about that. That's why they make degree wheels and adjustable cam sprockets so that we may degree in our cams correctly and precisely.
![]() That's mentally estimating the tooth-tooth centerline distance on the belt as 5/16" (5/32" tooth width). If I had an actual timing belt measurement/profile, I could accurately do the math. For what it's worth... Mike |
#110 (permalink) | |
Legend Agent
Per BUZZARD, even on a stock motor the cams are retarded. The powerband can be shifted around a bit with cam gears - I'm not sure additional power can be made though. Either way $350 is a lot of money to spend on adjustable cam gears, but worth it for the right person. Too bad the driver's side cam gear has the sensor pickups for the crank/cam sensor. -Matt
The dude with a chip on his shoulder. Stop asking me to compare my chip with Telion's damnit. Mines better. No, really, stop asking ![]() The Legend Garage |
#111 (permalink) | |
Renaissance.
I have Type II heads sitting in the garage, and plan to swap the cams and springs. I'm seriously considering the NSX springs, but I have to do a bit more research. With your info on the manifolds, I'm probably going to be using my Type II mani. I'm glad you're chipping ECUs, as I'll be hitting you up when I complete my swap ![]() Your thread has a lot of useful information, as well as opening up a lot of things for discussion. Speaking of that, did anyone find out if the NSX fuel rails flow better than the Legend rails, and if they're swappable? Keep up the good work.
"Game recognize game and you looking kinda unfamiliar right now".... Last edited by whats77inaname : 03-02-07 at 01:39 AM. |
#112 (permalink) | |
Chris |
#113 (permalink) | |
Legend Agent
.-Matt
#114 (permalink) |
I'll never stop thinking how funny that sounds everytime i see it.
![]() ![]() ~Dv8
#115 (permalink) | |
Legend Agent
You lost me on the first paragraph. What kind of work does portflow do? Install larger valves? Or just P&P? I was discussing installing the Type II intake valve into the RL head with Christian a few months back. While it's definetly a possibility, why install just a 1mm larger intake valve? Why not find and install even larger valves? It probably wouldn't cost more money and you would be opening up even more power. -Matt
#116 (permalink) | |
Legend Agent
-Matt
The dude with a chip on his shoulder. Stop asking me to compare my chip with Telion's damnit. Mines better. No, really, stop asking ![]() The Legend Garage Last edited by sr5guy : 03-02-07 at 12:34 PM. |
#117 (permalink) | |
![]() ![]() ~Dv8
#118 (permalink) | |
Legend Agent
![]() EDIT: You better knock on wood Mr. DIY tune EMS ![]() -Matt
#119 (permalink) | |
I'm the Stig!
