#16 (permalink) | |
Cure Hunger:Soylent Green
Ok, I didn't know if your flip chip was just ignition or ignition and fuel map switchable.
Switchable map for the AFC makes sense. Must be a SAFCII or whatever they're calling 'em now. Perfectly reasonable by itself, although forgetting to switch maps could be a disaster. The point I was making about the AFC values to the nitrous map on the chip is this: The percentage correction based on throttle position on the AFC will not directly coincide with the change of values on the chip. Honestly you could only hope the chip burner has a good instinct for translating the values. Like a much less reasonable estimate than calculating 1/4 mile from 1/8th mile ET. ![]() IMO I wouldn't spend the money on a chip with guesses and hope it is right. You would be better off using the fpr vacuum line method of enrichment and tuning it from there. So you could have fueling close before you have to trust the electronics.
200 Degrees, that's why they call me Mister Fahrenheit. Quote:
#17 (permalink) | |
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, Apexi safc II, strut bar, F/R sway bars, FL tie bars, tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA |
#18 (permalink) |
6 Gears
Are you guys done yet? haha. I need to make a decision.
Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Coupe Taillights, Tinted Sedan Taillights, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have UNLIMITED RL and Legend Parts PM me to discuss. LIMITED COUPE PARTS |
#19 (permalink) |
and i quote...
"hmm so your not just an asshole you actually know your stuff" THIS SHIT IS NOTHING SHORT OF GOLDEN....! boys, i have no idea of what you speak, as i would no sooner put nitrous on my Legend as as my John Deere, But My AL.COM brothers, you give me such credibility with your deapth of knowledge, and i bask in the glow, my thanks to both of you to be able to (quasi-snidley) state your case, refer questions, dicker over the details, agree or not in a public foum and its still readable and and interesting and not a rant, and in the end agree that both seem to know WTF they're talking about, different/same, whatever,...but informed...not just the Elijah Craig talkin here either... ![]() that is just fuckin' awesome, i dont care who you are... Get Off kids...so enjoyable, keep that shit comin'' and -if- i did nitrous my tractor, i'd call ya'll first... http://www.acura-legend.com/vbulleti...1&d=1206854193 which would you nitro first??? the switchboards are now open.... FTFW! |
#20 (permalink) |
i think dv8 needs to chime in here, since he has used every form of nitrous on the legend and knows what works best and why, so ill sent him a pm about this convo so he can post some knowledge
#21 (permalink) | |||
![]() All things being equal, the ZEX kit is probably where you should start, if the price is right and wet/zex are your only two choices. Make sure those vacuum lines are secured and don't be surprised if it is terribly rich. I would suggest setting the nitrous up on a dyno with a wideband. This is the safest way to go, no matter how you look at it. If you find a dry NOS system, most (if not all) have a mechanical servo that REGULATES nitrous pressure down to about 50psi instead of just using a couple of restrictors (the restrictors allow for pressure spikes). Your fueling will be much more consistent if you go that route. Quote:
Also juice the Porsche. Putting the giggle gas on a lawnmower will be sure to disappoint. Plus if you blow up the John Deere it's gonna become a John Doe. YouTube - Mower Vs Nitrous
#22 (permalink) |
I'm an I.T. Manager...
Like grumpy said, go with a Zex kit and stick to the instructions. Nos kit 5123 was a universal 6cyl kit they had when I bought mine-Zex didn't exist yet. It works well too. No more than 75hp on the Zex and 60 shot with the NOS. Your car wont have any issues unless you deviate from the instruction manual.
I suppose thats why I call myself Dv8. I used a bayou chip back when I first sprayed, it ran pig rich, nitrous ran well and safe. Later when I started to push more nitrous I used an SAFC to increase fuel on the dyno and with a wideband, It only had one programmable map. I would change the settings between N/A and nitrous every time I wanted to do either or. The SAFC II came out with 2 programmable maps that could be switched on the fly, which made it easier. I went direct port and it never worked out the way I had planned. If you want a wet nitrous system, again stick with the Zex. Around 100-125shot timing retard was required but couldn't be altered(Telion & SR5guy weren't making chips yet) so I went for the EMS and never looked back. The 316hp/345tq I used a .55 jet, and could have gone higher as it showed no signs of a ceiling, but I wasn't about to get greedy. ~Dv8
AEM EMS Powered. 8.5 yrs and counting. Results, Where are yours? 12.953@107.865MPH 95 deg. Jun. 07' 3.5 6spd-#55 jet Nitrous 316WHP@5500RPM 345Lb-ft@4100RPM NOS 06-07'N/A 234WHP@5700RPM 229lb-ft@4600RPM 06-07' 13.782@99.135MPH N/A 95 deg. Jun 07' 01' Acura CL-S 14.8@94MPH[Sold] 03' G35c Stock Auto 14.3@96MPH [Not Stock Anymore!] 8 page spread Honda Tuning September 06' issue No Phone or Instant message, PM or Email only. Respect that! My Legends Website www.2slik4u.com |
#23 (permalink) |
lol so thats why u call your self dv8, ive always wondered why u picked that name haha. Thanks for the words of advice on this subject.
