LinkBack | Thread Tools |
Rating:
Display Modes |
Thought I blew the Head gasket.
I thought I blew my head gasket tonight. I was driving down the road and I noticed the Temp gauge creeping up. I have not had radiator fans on the car fr 4 weeks now, due to he fact I am finding some thinner fans to make more room for the turbo kit. As long as I dont get stuck in traffic and keep air flowing through i should be fine, but a couple times this past week I got stuck in traffic and it would start to over heat, but before it hit the red or even go close I would pull over and turn the car off. So tonight I figured maybe it just ran out of fluid, but boy was I wrong, I opened up the hood and everything was soaked. I saw steam comming up from down low and I thought to my self, sheit, no turbo, I gotta go a damn head gasket job now. But I filled up some fluid and tried to make it to a gas station that was just down the road. So I did after 2 stops, the temp was really moving up quick, so I finally made it after 2 breaks and I let everything cool. I found out, the belts rubbed against the lower radiator hose and thats where it was leaking and steaming from. So I bought a repair kit and patched it up. I started back down the road after being at the gas station for 20 minutes. And after about 45 seconds it was getting hot again, so I pulled into a 24hr auto zone that was 2 lights down. I went it and was going nute, b/c I didnt know what the deal was, maybe the radiator went too, b/c I still saw leaking from under the car. I filled the radiator up with coolant and water and I was good to go. I didnt buy the new hose b/c I think I am going to get a Steel Braided Hose ($60
) instead of $16.99 for rubber. But I made it home after filling her back up and she didnt have a problem. I am just hoping I didnt cause a near future head gasket problem. Do you think the high temps that it has been to the last week is going to cause the head gaskets to go soon?Does anyone know some thin race fans we could use? |
#2 (permalink) | |
Get sucked in...
Re: Thought I blew the Head gasket.
I'm tring to understand, by your description you dont have a turbo yet, and yet your sig implies you do, it also implies you have a 6spd, care to show photos? If your worried about the head gasket just change it should be easy since you turboed you car and all........... ~TRu Hybrid
werd.....
I think it was a bad idea in the first place to take the fan out until you had something to replace it with. You should NEVER be driving without a radiator fan of SOME sort. Even if it is cold outside. (you live in FL, so its never very cold)
I recommend you put your radiator fan back on, get some new radiator hoses, make sure the belts are not rubbing, and have your radiator leak tested. |
#4 (permalink) | |
Get sucked in...
Taking off your radiator fans, sounds like something typeRkon would do. Kinda like removing your VIS from the intake manifold. .... ~TRu Hybrid
Would anyone know which Part Number, which one I need. I am really tired and cant figure it out. Night/
http://store.summitracing.com/produc...earchtype=ecat |
#6 (permalink) | |
Get sucked in...
You can answer my questions above at anytime.... ~Tru Hybrid
Man, did TypeR get banned again?!?!?!?!?
OH, I just read that post, man, that was a dumb thing to do. I knew this guy would/will find a *reason* to not do his *turbo*. Anyway, how can someone "capable" (most unlikely assumption) of actually engineering a Turbo setup be put off by something so simple as a blown HG?? OBVIOUSLY TypeR was not so dedicated that a BHG will stop his project. ![]()
"Sneek-E Honda DA6" "2001 Infiniti QX4 AWD+LSD" http://www.imagestation.com/picture/...1/f617b751.jpg Transition to the Darkside Last edited by takemorepills : 11-17-03 at 09:58 AM. |
FIXER
Car 1: 1992 Legend L 265k Black(sold) 1994 Legend LS 175K Green 1967 NOVA SS Bolero Red iTrader: (0)
Most BHG's start with a minor overheating event, but usually not self-induced. You probably just turned down the headgasket highway. |
#11 (permalink) | |
werd.....
#12 (permalink) | |
HowStuffWorks |
Want another Legend
Bleed your coolant system or it will continue overheating
In case you missed out on the group buy, I have a full set of pullies from the group buy for sale - $440 1991 Automatic Frost White coupe - Sold 1993 6-speed Granada Black Pearl Metallic coupe - Sold 2004 RSX-S Artic Blue Pearl - Traded 2007 Mazdaspeed6 |
#14 (permalink) | |
94 Milano Red LS coupe 6 speed 94 Pearl White LS Sedan (sold )http://www.msu.edu/~weizhou/Mylegend/sig5.jpg |
#15 (permalink) |
Wha*ever ** *akes
ummmmmmmmm...if i was dumb enough to drive around with no radiator fans, and my car started overheating, i dont think i would worry about a blown headgasket. although, if you are dumb enough to go with no fans, im sure you would think your HG was blown.
