Old 02-17-03, 04:49 PM   #1 (permalink)
Old S*hool Member
Upper ball joint - Need advice right away!!
Okay,
My car just went in the shop today to have my 3570 ingalls camber kit installed as well as some new lower ball joints. Well, it turns out my upper ball joints need to be replaced also, but Acura only sells them with the upper control arm which costs a WHOPPING $285 Canadian PER SIDE!! so I gotta dish out over $600 Canadian after tax if I don't figure something else out soon.
I wanted to know: could I buy the ingalls 3557 camber kit?? that would replace my upper ball joint, right?!?!
Apparently its hard to replace the upper ball joint in the existing upper control arm, thats why Acura only sells them together, so wouldn't that mean it may be hard/expensive to have the 3557 kit installed on my existing control arm???
Please help!! I have to get this figured out right away and order the part so I can get my car back on the road!!!!
(thank god I'm on vacation right now and don't require the car to drive to work and back for a few more days).
Octane is offline
Old 02-17-03, 05:12 PM   #2 (permalink)
Old S*hool Member
I called around and the best price I could get was a local dealership (Acura of North Toronto) for $203 per side - I'm just gonna bite the bullet and buy them - saves me the hassle of having to get shipping then pay duty and be without my car for days...
I love this car, but sometimes the cost of proper upkeep just hurts
Octane is offline
Old 02-17-03, 06:25 PM   #3 (permalink)
Legend Newb*e :)
Car 1: 92 coupe
Send a message via AIM to jedinyte120
octane
i bought the spc ball joint kit for my camber corection.if i am not mistaken,dont that replace the factory upper ball joint on the control arm?that ball joint goes on the tip of the upper arm right?like the top of the A?if that is it then its not that hard to put in.my mechanic just took the arm out,ripped off the rubber boot and compressed it out.any mechanic would have the ball joint press,but double check on that first before you order it.my mechanic also used a hammer and kinda flattened the tip of the arm for clearance just in case,and so far i havent had any problems.hope this helps bro.
rog
jedinyte120 is offline
Old 02-17-03, 10:35 PM   #4 (permalink)
Blang, Blang
B-Lo's Avatar
Car 1: 1991 Frost white sedan
Send a message via AIM to B-Lo
http://catalog.thepartsbin.com/?year...mageField.y=12
"Legends often imitated,
Never duplicated"
http://www.imagestation.com/picture/...7/fd2d47a1.jpg
Originally posted by acuralegend.com
Frequent Rim Benders club member #1.
B-Lo is offline
Old 02-17-03, 10:48 PM   #5 (permalink)
Car 1: 1993 LS Coupe, 6 Speed
The SOBs at Acura told me my Control arms were shot..... and they were perfectly fine... so I know how you feel.. and that is a pretty good price. I belieive I paid $215 each. That sux you have to repalce the balljoints though...... good luck...
Mckenzie93 is offline
Old 02-18-03, 02:53 AM   #6 (permalink)
Blang, Blang
B-Lo's Avatar
Were your ball joints making noises? How did you know they were bad?
Never duplicated"
B-Lo is offline
Old 02-18-03, 11:59 AM   #7 (permalink)
They said the control arm bushings were worn, and when me and my friend took the suspension apart, the left side was like brand new, and the right side showed a tiny bit of wear. I though it was going to fix a wandering steering feeling, which I can now attribute to just having wide tires.... no problems with suspension what so ever.
Old 02-18-03, 01:12 PM   #8 (permalink)
Old S*hool Member
I could tell for a while that something was wrong with my suspension - on poor roads the front end just felt kinda clunky, like whenever the spring/shock was in transition between compression and rebound it felt loose and uncontrolled. Thats why I bought a set of lower ball joints to install when I had my suspension adjusted as I know they have not been replaced in atleast 100,000kms and possibly never. When my mechanic took everything apart, thats when he found out that the front passenger side upper ball joint was in tough shape - he recommended getting both sides done while the car is already apart to save on labour, which I agree with.
So now I will have new lower and upper ball joints and new poly bushings thanks to the 3570 camber kit - I can't wait to see how tight and responsive the suspension and steering will feel after its all done - especially with the CL S rims on the car!!
Octane is offline
Old 02-18-03, 02:38 PM   #9 (permalink)
Car 1: 12sec E36 M3
Send a message via AIM to 92coupeon18s
yeah the 3557 replaces the whole upper ball joint. BUt i dont like mine.
92coupeon18s is offline
Old 02-18-03, 02:55 PM   #10 (permalink)
LeGeNdS NeVeR DiE!
SaGe69's Avatar
Car 1: 1992 Legend LS Sedan
Maybe this might help....
Before you go wasting money on new upper control arms, call Standard Autowreckers (416)286-8686 and see if they have any good used ones available... I hit a curb pretty bad last year and had to replace my control arms & balljoints. I managed to pick up 2 very good condition upper control arms with perfect upper ball joints for $75 per side. Maybe I was lucky because they came off a 95 Sedan. But in any case, try them first or call some other local scrap yards. They won't sell you anything that isn't in perfect physical and working condition so you have nothing to loose.
Lates,
SaGe69
SaGe69 - Reprezentin T.O. since 2000
SaGe69 is offline
Old 02-18-03, 07:17 PM   #11 (permalink)
Old S*hool Member
Re: Maybe this might help....
Lates,
SaGe69
Thanks for the advice, but unfortunately it's already done and I have the car back. It was alot of $$ but at least I can rest asured that I now have 4 brand new ball joints that will not give me any trouble for a long time to come. The other thing is that it now rides and handles amazing!! AND the stance is PERFECT!!!
(front passenger side on the lower perch and driverside on the upper perch)
Octane is offline
Old 02-18-03, 09:47 PM   #12 (permalink)
LeGeNdS NeVeR DiE!
SaGe69's Avatar
Re: Re: Maybe this might help....
Did they realign your car for free or did you have to fork out $$$ for that too?
Looking forward to seeing your ride this Spring.
SaGe69
SaGe69 is offline
Old 02-18-03, 11:53 PM   #13 (permalink)
Old S*hool Member
I put new springs on the front, so I have to wait a few weeks for them to settle before getting an alignment, but it will be my coin to get that done.
I'll be getting the wheels and cross drilled rotors installed later this week, then all I want to get done before the summer is tint, paint the moldings and skirts, and maybe an exhaust. I have the stage II ECU, HID, LS leather shifter&wheel on the way. I also just got the "A-C-U-R-A" and "3.2L" emblems (off a new 3.2TL) from SammyD that I will be installing soon.
I can't wait for warmer weather to get another meet going!!
Octane is offline
