Old 05-16-07, 12:05 PM   #46 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Originally Posted by Blackend View Post
Corrections for you:
Acura's Factory Lower Rear Control Arms are weak in design and are usually the first suspension piece to bend. They are also hard to adjust and have no indication marks for resetting any adjustments.
SPC makes a ball joint replacement camber kit that adds height to the control arms and give us extra dents in the engine bay I'm talking about real camber plates that mount on top of the struts and articulate the strut directly...
Not trying to reinvent the wheel, just trying to make it better
Okay--that makes sense to me. I didn't realize the factory arms were a weak spot. If you could make them lighter, I think they'd be more appealing from a performance standpoint because I have never read of anybody busting or bending a lower arm that wasn't rusted, crashed, or both.
I also thought SPC made plates these days; I am fairly certain that Ingalls does. You shouldn't have any trouble with SPC's ball joint kits, by the way. Ingalls' ball joint kit caused the problems because it added damn near 3" of height to the arm.
What about tie rods?
k.
mrkeith is offline
Old 05-16-07, 12:06 PM   #47 (permalink)
DSL
Car 1: '93 white coupe 3.5 type II 6sp
Send a message via AIM to DSL
YO! camber plates arent going to do anything on our cars b/c of sus. design.
if you want to make different camber adjuster, you will have to modify on the ingals design. or just slot the holes where the stock pieces fit.
'01 3.5l rl engine- 6 speed swap done!, type2- cams, valve springs/retainers, and intake manifold.
ground control, koni, addco-front & rear, mls copy, 18" volk III
rm racing intake, gasket match ported exhaust manifold, light weight pulleys, telion chip, tranny cooler
and a bunch of door dings ~from haters
DSL is offline
Old 05-16-07, 12:14 PM   #48 (permalink)
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
We could make sliding plates, but the design would be funky because of the arm's curvature (I think that's what you're referring to). McPherson is so much easier ;P Please correct me if I'm wrong.
mrkeith is offline
Old 05-16-07, 12:26 PM   #49 (permalink)
Blackend Motorsports
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
I think I may have an application that might work (lot of maybe's!) but I'll know for sure in a couple months when we really dig into it.
NALM NAZI
We Brought Them
We Broke Them
We WILL Rebuild Them Better!
Blackend is offline
Old 05-16-07, 12:31 PM   #50 (permalink)
DSL
sure. but make sure you dont make camber plates. they WILL NOT WORK. go look at wikipedia.. mcpherson strut and double wishbone suspension.
DSL is offline
Old 05-16-07, 12:52 PM   #51 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
k.
its not that the rear lower arms are weak. although they can bend. its that the adjuablity for is VERY limited. my toe is adjusted as much as possible and its not way off and shreading tires. What Brian is working will solve that.
as Brian said, its not about reinventing the wheel but making it better.
~Alex
Alperovich is offline
Old 05-16-07, 01:00 PM   #52 (permalink)
Car 1: C32A race engines
I would like to see accurate camshafts. 110 centers for my N/A customers and
115 centers for the turbo engines.
Chris
BUZZARD is offline
Old 05-16-07, 01:10 PM   #53 (permalink)
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
The best solution would be to fix the chassis damage or worn suspension components causing your toe to be so far off. By the way, your new signature is uber sexy. If you have a high-resolution shot, I'd set it as my desktop background
k.
mrkeith is offline
Old 05-16-07, 02:24 PM   #54 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
k.
THANX! i do have a high-rez.
whats ur email addy i'll send u the pic
the toe is caused by the uber-drop i have!
~Alex
Old 05-16-07, 08:34 PM   #55 (permalink)
swift's Avatar
Car 1: 92' legend coupe 5spd
Car 2: 94' coupe auto
Car 3: 91' Smacura
black portion is similar to our upper a-arm already. the threaded pieces are what bolt to the A-arm to the chassis. The blue part is a design taken off an OEM ford(i think).
The blue part then bolts to the black part. Where it bolts it uses elongated holes to move the blue arm forward or back allowing you to adjust caster. This coupled with a caster/camber plate for the struts we can have complete control of the entire suspension. And then blue arm with can have SPC balljoint(camber plate) ....you have 3+ points of adjustment.
good luck brian.
swift is offline
Old 05-16-07, 09:11 PM   #56 (permalink)
UGA VII
93LegendSedan's Avatar
Car 1: 1993 Legend Sedan
Car 2: 2002 LS430
Car 3: 2008 Highlander
Sorry if this has been discussed, I did keep up with the turbo thread from Kyle, but I thought it had died out.
Is there something now going on with more production possibilites?
I want my car to go vroooommm ptssssssss
93LegendSedan is offline
Old 05-16-07, 09:31 PM   #57 (permalink)
Blackend's Avatar
We are not working on FI just yet. My philosophy is that our cars need to have the chassis sorted out first, because with basic bolt on engine mods, it's more than able to keep up with the suspension. Through my personal testing, once I feel like the suspension is ahead of the engine, we'll probably start looking at serious power adders. Tyler has some great ideas to try out whenever I get around to buying a spare engine to build. Our goal is to make this car good at anything you want to do with it. A lofty goal I know, but we believe this is the platform to achieve it. Plus Legends are just badass
Can you imagine a 3500 lb luxury car capable of running 12's and lapping teg's and civics on a road course? I can
NALM NAZI
We Brought Them
We Broke Them
Blackend is offline
Old 05-16-07, 11:04 PM   #58 (permalink)
Pedobear is watching you
tnelson's Avatar
Car 1: 2002 TL-S, white
Ideas is one way to put it. Its going to need tuning big time, but I have a whole plan set aside, with 2 cars and a test motor to work with (for now, maybe more) and we will see how it goes. Should have a motor built by oct for brians car, after doing some prep work and some testing, and using phils as a bastard tester, we should be ready to go. Then we will have a drop in engine to replace brians and then I will see what to do with that one. After we get one put together and running for a while, we will work on FI. Maybe even on 3.5s.
Real Life Trolling FTW....
http://www.youtube.com/watch?v=feLqz1udhtY
tnelson is offline
Old 05-17-07, 01:56 PM   #59 (permalink)
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Legends were designed for pimps.
mrkeith is offline
Old 05-17-07, 02:31 PM   #60 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
and pimpin ain't easy.
Mike Diaz is offline
