» Sponsors
» Sponsors
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 12-16-08, 10:48 PM   #91 (permalink)
spcgloc13's Avatar
Car 1: Acura Legend 94 GS
Car 2: Acura TSX 05
Anyone who decides to do this flush will be amazed!! It took me almost 4 hrs to do this, but it was well worth the work. My car feels like a brand spanking new legend!! By the way while your at this you might as well change the filter. My car has 97k miles and when I took out the filter it was freaken black as hell. So yeah you might as well replace it.
sittin sideways!
spcgloc13 is offline
Old 12-16-08, 11:20 PM   #92 (permalink)
Renaissance.
whats77inaname's Avatar
Car 1: 91 5MT LS, 310k
Car 2: 91 5MT LS, 208k
Car 3: 03 G35 sdn (wife's)
iTrader Score: 33 reviews
Manor! All right, another person nearby! The next Tx meet should *rock*!
whats77inaname is offline
Old 01-12-09, 09:05 AM   #93 (permalink)
Car 1: 91 Legend Coupe - Solaris Silver
Car 2: 95 Legend Coupe - BB
Originally Posted by maytagman View Post
alternate tranny flush method:
my mechanic just suggested this method...
disconnect the two tranny cooler lines from the rad.
fill a bucket with atf and stick the return line into the bucket.
get an empty bucket and put the send line into it.
run the car and watch until the fluid that comes out is clear.
apparently his old shop had a machine that did basically this.
im sure a bucket of dexron would suffice. walmart sells it for about $35 for a bucket i think? (canadian dollars)
then i guess you would drain and fill with honda and lubegard/smart blend.
anyone want to try this?
maytag
Bocsta is offline
Old 02-06-09, 10:01 AM   #94 (permalink)
Car 1: 1996 Acura Integra LS
Car 2: 1990 Acura Legend
After talking with the Acura dealership, they suggessted against using Ford tranny oil. In their opinion, they have seen too many people burn their trannys up, even after several miles using the wrong type of fluid. After inquiring about a filter, the guy says he hasn't sold a tranny filter for a legend in the 4 years he's been there, and advised not to change it. After asking somebody else, they said that the tranny flush might work, but that it could clog the filter up real bad, causing serious harm.
So, what's the chances of my tranny burning up using the Ford tranny oil? Or what's the chances of the filter getting super clogged, or will that not happen? I just want to make sure I don't tear my car up. How many people have been successful?
tegowner is offline
Old 02-06-09, 04:04 PM   #95 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
I would definitely not use Ford transmission fluid. Use Dexron III or VI and add a bottle of black Lubegard.
Mike Diaz is offline
Old 02-07-09, 12:34 PM   #96 (permalink)
Car 1: 1990 Gold Acura Legend
will this work for the G1 as well?
Jahseed is offline
Old 02-11-09, 12:47 PM   #97 (permalink)
Fity's Avatar
Car 1: 93 acura legend/coupe
Car 2: 95 hondaAccord/coupe
ok, here is my question. im going to be replacing my trans fluid, i know how to drain it i just dont know how to fill it up. where do i put the new AFT in? does anyone have pics? do i have to drop the pan to replace the filter?
Fity is offline
Old 02-11-09, 04:46 PM   #98 (permalink)
Leaving the lights on
Car 1: 1988 Acura Legend L Automatic
Remove dipstick from transmission (NOT ENGINE OIL DIPSTICK!!!).
Insert funnel.
Pour transmission fluid into funnel.
Check fluid level before driving.
To replace the filter, you will have to drop the pan as far as I know.
Dexron 3 over Ford. Dexron 3 is far more similar to Honda ATF.
As far as what the mechanic said about flushes clogging things, that's a no. He's thinking of what some ripoff mechanics and places like Jiffy Lube or EZLube try to scam you into, where they hook up a machine to your transmission fluid cooling lines, and either suck the fluid out with a vaccum or else blast some kind of cleaner all through your transmission. It costs like $200 and it DOES destroy transmissions.
Psalm 19:14
May the words of my mouth and the meditation of my heart
be pleasing in your sight, O LORD, my Rock and my Redeemer.
Goatman is offline
Old 03-04-09, 05:12 PM   #99 (permalink)
BC-BUD-420's Avatar
Car 1: acura legend 93
I just called my local Acura dealership and they told me that
91308-pa9-003 for the o-ring gasket
25420-py4-000 for the transmission screen
21813-PY4-000 for the oil pan gasket
would cost me 160 along with the 4L of Honda ATF which is 40 bucks so its 200+... is there a cheaper way to do this for us Canadians out there? please help... I do want it to be OEM though
Thanks in advance
One Love
BC-BUD-420 is offline
Old 03-04-09, 06:41 PM   #100 (permalink)
One guy told me to pull the ATF cooler tubes, turn on the car, let it drain some fluid, turn it off before it sucked air, fill the transmission with fluid again, and repeat. He said to do that until it ran clear (e.g. all the dirty fluid was out). He said that'd use approximately 20% less fluid than this process.
Probably not the safest method, but it's a bit cheaper.
Psalm 19:14
Goatman is offline
Old 03-04-09, 10:49 PM   #101 (permalink)
BC-BUD-420's Avatar
ya... but no... you would have to be really cheap and desperate to do that..
One Love
Old 05-03-09, 11:21 PM   #102 (permalink)
Uber Lurker
I got a question.
I just change my transmition filter and gasket. but i forgot about the O-ring. i am going to go to kragen to get some more tranny fluids tomorrow while intalling my O-ring. will there be a problem with my tranny and filter when i drive to kragen and back ? or i can drive without the O-ring for a while? and is the gasket still good even after take out the fluid pan, gasket and strainer? or i got to get a new gasket? should just use my sister car to go buy the fluids?
11454 is offline
Old 05-03-09, 11:36 PM   #103 (permalink)
***ned
I wouldn't drive it till the O-ring is in there. It will suck air. As long as the car is not started and warmed up the gasket should be ok to reuse.
1_Hot_Legend_LS is offline
Old 05-03-09, 11:44 PM   #104 (permalink)
Uber Lurker
ok. what happens if it sucks air?
11454 is offline
Old 05-03-09, 11:46 PM   #105 (permalink)
***ned
It's going to shift harsh and if driven long enough, burn up the clutch packs.
