502MotorSports.com
What you need for this:
1 - Weapon R Intake 2 - 3" diameter 90 Degree Adjustable Piping 6 - Clamps 1 - Filter 1 - Screwdriver (Philips and Flat) 1 - Section of gutter guard (mesh) Preparation: * Remove right front wheel, and use philips screwdriver to remove the wheel well liner * Your resonator box assembly is made of essentially three parts. These are intertwined, but fairly easy to take apart. There are three screws on the bottom of the resonator assy...one facing you, one in the front of the assy (you will put your hand thru the foglight hole for it) and one near the top (put your hand thru the foglight hole and reach up.) *Give a few tugs and it should all come out (provided you have removed the crap from the top side where the normal intake ends.) *Use compressed air to rid of all that crap that comes out, and clean it up real well. *Now comes the fun part... assuming that your intake is conncected to the throttle body, we will go from there... *Connect one end of the 90 degree pipes to the intake and position it so that it will clear the hole. Clamp it to the intake slightly, to make room for adjustments. *Securely clamp the filter with 2 clamps to the other 90 degree pipe and feed it up thru the bottom of the same hole. ***Now, these are gender sensitive, so secure them together, then clamp them together with 2 more clamps.*** *Now you can position the intake where it will give the filter a parallel stance to the ground, and tighten them up. *****PLEASE MAKE SURE TO DOUBLE-CHECK ALL CONNECTIONS, and make sure that before installing taht all interior surfaces of the pipes are free of debris, moisture, etc.!!****** Replace the wheel well liner (take the time to ensure this is clean too. *Pull ECU fuse for about 30 seconds. *Using your foglight hole cover as a template, cut out a section of gutter guard, slightly bigger, to replace it with. Reinstall wheel, and enjoy. Please note, you may not hear it like you do if its in the engine bay as a ram, but you DO feel the difference! It should look like this when you are done (old pic w/ Type I and no TCS) ![]() *****Special note for those of you that want to be on the safe side in case of rain, install the AEM Bypass Valve ($56.82 @ NOPI).**** Yes, I know it is cheaper at some online catalogs, but, rain was coming, and I did not feel like waiting 3-5 days for delivery. You will need the one for the Prelude - 3". Instead of clamping the two 90 degree bends together, you will attach the valve in between the two. You will need the following to make this work.... 1 - Patience 1 - WD 40 1 - about 30 minutes * Lube the outer portion of the 90 degree bends with WD 40. * Attach one end of the valve to the pipe. This may be difficult, so you will need to apply some force...but be gentle...and do not allow it to pass by the lip on the rubber. Secure it with supplied clamp, and repeat on other side. This one should be fairly easier...MAKE SURE TO SECURE IT, but do not overtighten. I also suggest to get something to hold this secure (i.e mounting brackets). Here is a picture of mine with the bypass valve on my Type II w/TCS. Please note that the same intake ws used for the motor w/ TCS and w/o TCS. I guess the TCS intake is slightly shorter, but IT WILL work if you have the non TCS intake. ![]() Close Up of AEM Bypass and other stuff
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | 502MS Project e39 | 502MotorSports MySpace Last edited by 502 MotorSports : 03-04-02 at 08:47 AM. |
Posts: n/a
What are some of the cheaper places that sell the AEM Bypass valves. I haven't been able to find any yet? I am gonna re-order my intake tomorrow when Nick gets back since they lost my order (he's sick today). I'll go get one of these too if the price is right.... definitely a good thing for me since I live in Seattle
In Cabo
In Cabo
In Cabo
the smoother the plain the better the airflow, that setup you have is adequate but there's beter you just need to look harder
502MotorSports.com
that's funny, I was thinking of going and getting some madrel bent pipe made so it would be one piece between the ram and the extension. This is just fo those starting off. Still, I can feel a difference. Reason I made this is because I see TOO many folks with dryer hose and other ghetto styles on there cars...this way you won't be embarassed to show your motor, and not just sucking in crap
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | 502MS Project e39 | 502MotorSports MySpace |
*r**h *eller
Stickied!
You may want to submit this for the G2 FAQ section.
502MotorSports.com
Thanks Dave...Good idea
LEGEND
Thanks leon! i was just about to ask for this, hehe, and as i was reading i was thinking, 'maybe this should be a sticky' and bam i scrolled down and it was, lol, thanks Dave C.
http://img47.photobucket.com/albums/...se_resized.jpg 1997 Mitsubishi Eclipse GS-T Spyder 5spd Apex-i FMIC, Apex-i Intercooler piping, Apex-i Twin Chamber BOV, full 3" turbo-back Exhaust, 5300k McCulloch HIDs... Want something for free? Choose a link! Free Ipod or Iriver? http://www.mp3players4free.com/default.aspx?r=6890 Free Digital Camera? http://www.cameras4free.com/default.aspx?r=45645 Free Personal Video Player? http://www.pvps4free.com/default.aspx?r=45648 |
#11 (permalink) | |
502MotorSports.com
sorry, I am sure you can use another intake, but if it is too long, you would just need to make slight modifications to make it work. For the most part, I am sure you would be fine
Hey Leon, I don't think this will work with 94-95 sedan, since we don't have that fog light hole on either side of the lower grille
94 Milano Red LS coupe 6 speed 94 Pearl White LS Sedan (sold )http://www.msu.edu/~weizhou/Mylegend/sig5.jpg |
#14 (permalink) | |
502MotorSports.com
Speeddemon, I can help you if you want. Email me and I will give you my number...I can walk you thru it
