Ganja smokes
DIY: Bleeding the air out of your coolant (Post #7)
What is suposed to be in The small clear tank that raps around the winshield solutuion tank? Mine empty and i think its needs somehting...i think it might be liquid coolant or sumthin?
See post #7 for DIY Last edited by Mike Diaz : 02-28-07 at 05:53 PM. |
Car 1: 91 Legend LS Coupe 6MT, Black on Black Car 2: 2008 Acura TL-S 6MT Car 3: 94 Legend L Coupe AT iTrader: (13)
yea, its for coolant
Modifications: Type II 6 spd, OBX headers, Cold air intake, 5spd clutch and flywheel, Type I pulley, Shaved Heads, RJ Short Shifter, Smoked taillights, Tiburon front seats 0-60 Vids: http://www.acura-legend.com/vbulleti...9/#post1293432 Repaint Progress Thread: http://www.acura-legend.com/vbulleti...d-pics-122370/ |
Two things:
If the tank is empty, you could have a problem. Legends do not do well with cooling system problems. If your coolant reservoir is empty, your cooling system may be low, or worse, may have air in it. Second, it is recommended to use Honda coolant. Better for the water pump.
92 LS Coupe 83,000 Miles & Counting Stock except -GS RIMS -Clear Bumpers |
Ganja smokes
K, well im for sure gunna use the honda solution, but how do i go about putting this fluid in and making sure its in working order? havent had ne over heating problems, its not very hot outside these days. but will get it done right after school tomorro.
When the engine is cold open the radiator cap and fill to the top, you can start ur engine once its filled to see if any air bleeds out and fill more if needed-then cap it. then open the coolat res and fill it,... I think halfway. Keep an eye on it for a while, my res kept overflowing then sucking all the extra coolant back into the radiator leaving my res empty...the fist sign of my BHG.
Theres also a small valve you can open to perge air, i forget where it is... its in plan sight, i think where the radiator hose meets the throttlebody. but first do the above. good luck |
WHAAAAAH!
First, fill the overflow jug to the MAX line.
Then when the car is cold, pop the radiator cap off and fill it to the top. Next, start the car and turn the heat on high. Then, open the bleeder valve (12mm valve on top of the engine, at the end of the upper radiator hose), and keep the coolant full. When the fan kicks on the first time, close the bleeder valve. All the while, making sure the coolant is full in the radiator. After each cycle of the radiator fan, open and close the bleeder valve within 3-4 seconds. Keep filling the radiator. After about 4-5 times doing this, you should be good. Put the radiator cap back on and make sure your overflow jug is at the MAX line.
#9 (permalink) | |
Pedobear is watching you
WHAAAAAH!
I should do a video. I've only done this about 100 times in the past 6 years.
#15 (permalink) | |
WHAAAAAH!
Look at the upper radiator hose. At the engine side of the hose, you'll see a valve with a hole at the top. Use a 12mm box ended wrench to open and close it.
| Is your 91-95 Legend overheating? Got a coolant problem? Post all questions in here. | Mike Diaz | Second Generation Legend (1991-1995) | 1920 | 07-05-08 09:09 PM |
| Overheating 101 | Jetdoc | Second Generation Legend (1991-1995) | 48 | 06-27-07 04:38 AM |
| Cant find DIY coolant change | MaSTeR.LeGenD | Second Generation Legend (1991-1995) | 16 | 08-26-06 09:08 PM |
| Cant post in DIY. Help | Dethred | User Feedback | 5 | 04-28-04 05:37 PM |
| y cant i post in the DIY section? | Ken | User Feedback | 2 | 12-28-03 01:05 AM |
