Old 09-25-06, 11:21 AM   #16 (permalink)
Work safe avatar.
Daddymac117's Avatar
Car 1: 1995 Legend GS
Send a message via AIM to Daddymac117 Send a message via Yahoo to Daddymac117
Originally Posted by Mike Diaz
I should do a video. I've only done this about 100 times in the past 6 years.
will you be including pond water in your video?
Please. Reading the FAQ and Wiki have been known to increase penis size in men and breast size in women.
Daddymac117 is offline
Old 09-25-06, 11:33 AM   #17 (permalink)
Pedobear is watching you
tnelson's Avatar
Car 1: 2002 TL-S, white
Look at the upper radiator hose. At the engine side of the hose, you'll see a valve with a hole at the top. Use a 12mm box ended wrench to open and close it.
or a 12 mm socket on a ratchet with a rag over it.
tnelson is offline
Old 11-12-07, 07:17 PM   #18 (permalink)
4 ALL UR TESTIN SUPPLIEZ
Double Glow's Avatar
Car 1: 94 Legend L Sedan
Car 2: 94 Honda Civic Dx
Car 3: 1986 Toyota Van
Send a message via AIM to Double Glow
Wheres that video diy!
PM Me About Custom Red/Clear/Red Sedan Taillights $500, or $425 with Deposit.
Parting Out 1993 L Sedan, Black - PM Me
Double Glow is offline
Old 11-13-07, 02:42 AM   #19 (permalink)
EDM KA8 owner
lgnd's Avatar
Car 1: EDM KA8 '91
Car 2: EDM KA8 '91 RIP
I always put a transparent tube to the bleeder valve I can see the bubbles in the tube.
lgnd is offline
Old 11-14-07, 10:23 PM   #20 (permalink)
Did it today! Was very easy! Thanks!
Old 11-16-07, 01:32 PM   #21 (permalink)
difficult to kill
brynosaur's Avatar
Car 1: 1995 L coupe
does this spill a lot of coolant?? like maybe i should do this in the street
just curious because it says to keep adding it after its full so its gotta be going somewhere right....
brynosaur is offline
Old 11-24-07, 04:12 PM   #22 (permalink)
mods: yes PLEASE!!!!
bboarder711's Avatar
Car 1: 1995 SE white/silver
Car 2: Flexdex Pro 36
Car 3: Nikon D70
iff you own a legend you need to do this actually this should be done with every oil change 3 months is enought time for even the smallest leak to put enough air in the system
yea youll spill some of it dont worry the more running out of the car means your pushing air out
My Mission:
-To create the hottest OEM "looking" legend.
http://www.legendaryphotos.net <-- Recently updated!!!
A-L.com T-shits for sale! <-- Click
Originally Posted by drtom182 View Post
just recieved mine today! great quality!!! i recommend to everyone thats a legend enthusiast!
fits too!
thanks again!!
bboarder711 is offline
Old 12-04-07, 06:12 AM   #23 (permalink)
Car 1: Acura 3.5RL
Exclamation help
what kind of problems can occur if there is air in the coolant system? When i press hard on the gas pedal, my temp guage goes down (towards lower temp.) a bit. Can air in the coolant system cause this?
ay0un is offline
Old 12-04-07, 09:07 AM   #24 (permalink)
Car 3: Nikon D70
where is the needle sitting normally??? and yes bleed the system anyway to be safe
My Mission:
fits too!
thanks again!!
Old 03-25-08, 11:35 PM   #25 (permalink)
Toronto Legends
fuzzy2k3's Avatar
Car 1: 1993 4dr Legend
Car 2: 2000 Corolla
Car 3: 1987 Pontiac Acadian
how come this isnt in the DIY forum when i click on it, but is when i search for it.......
fuzzy2k3 is offline
Old 08-19-08, 11:48 AM   #26 (permalink)
c_money14's Avatar
Car 1: 94 Acura Legend
First, fill the overflow jug to the MAX line.
Then when the car is cold, pop the radiator cap off and fill it to the top.
Next, start the car and turn the heat on high.
Then, open the bleeder valve (12mm valve on top of the engine, at the end of the upper radiator hose), and keep the coolant full.
When the fan kicks on the first time, close the bleeder valve. All the while, making sure the coolant is full in the radiator.
After each cycle of the radiator fan, open and close the bleeder valve within 3-4 seconds. Keep filling the radiator.
After about 4-5 times doing this, you should be good. Put the radiator cap back on and make sure your overflow jug is at the MAX line.
"When the fan kicks on the first time, close the bleeder valve. All the while, making sure the coolant is full in the radiator. " <----- This step, how do you make this work, do you leave the radiator cap off, and keep adding coolant, because when I did this my cooling system was all wacky I am assuming because they was no pressure in the system...
c_money14 is offline
Old 08-19-08, 12:19 PM   #27 (permalink)
1994gs6-speed's Avatar
Car 1: 1994 Acura Legend 6-Speed GS Sedan
if the needle drops on the gauge then i would assume it is the thermostat. You should change it out and then bleed the system.
Telion chip
1994gs6-speed is offline
Old 08-19-08, 04:53 PM   #28 (permalink)
c_money14's Avatar
I did both of these yesterday.. At the same time..
Is your 91-95 Legend overheating? Got a coolant problem? Post all questions in here. Mike Diaz Second Generation Legend (1991-1995) 1940 08-21-08 06:45 PM
Overheating 101 Jetdoc Second Generation Legend (1991-1995) 48 06-27-07 04:38 AM
Cant find DIY coolant change MaSTeR.LeGenD Second Generation Legend (1991-1995) 16 08-26-06 09:08 PM
Cant post in DIY. Help Dethred User Feedback 5 04-28-04 05:37 PM
y cant i post in the DIY section? Ken User Feedback 2 12-28-03 01:05 AM
