DIY - Cabin Filter Removal
I know we have 1 in the DIY section, but the pictures don't work and it's not very helpful at all. There has also been an increase of people wanting to try this. Plus i'm kinda bored.
I'll divide this DIY into 2 sections. 1. glove box removal 2. A/c cabin filter removal 1. Glove box removal. Step one: You will have to remove the passangers side courtesy light assembly. This is held in by 3 plastic screws. Once you remove the 3 plastic screws, wiggle it around a little bit to free it from the hook in the back. The light assembly will drop. Now unclip the harness for the light. screws: ![]() harness in BLUE, latch in GREEN ![]() step 2 Next it's time to remove the glove box. Remove all 4 screws with a philips head screw driver. ![]() step 3 Remove the 3 clips that hold in the black fabric on the glove box. I used a flat head screw driver to pop them loose. ![]() ![]() step 4 you'll need to unclip the white glove box clip. What it's for I HAVE NO IDEA. I'm pretty sure it's located right there. ![]() Congrads... you have removed the glove box. Part 2: A/C cabin filter removal. step 1 Automatic climate control: you will have a relay in the blue circled part ![]() Manual climate control will have nothing. Step 2 You will look for a piece of metal. Please look at the WHOLE picture to get a better feeling of it's location. This is where most people get lost. it's EXTREMELY easy to find. ![]() step 3 You will now remove 2 screws that hold it in. Screws are located on the top and bottom of the long metal part (circled in green) ![]() step 4 You will now see the brown cabin filter. There will be a loose piece you can pull on. Warning: it might crumble apart. Pending your location, driving conditions and age, the filter will have collected A LOT or a little debree. ![]()
http://img.photobucket.com/albums/v3...44/avatar2.jpg |
just a fyi,, I did this but also removed the lower glove box bracket, then the four (maybe five) blower assembly bolts,, the blower can then be removed,, turn it up side down and or use compressed air to clean it out,,, mine was so full of leaves and small sticks they were hitting the fan,, once cleaned out the air volume and blower operation are a lot better,,
#4 (permalink) | |
@what fender4 said. You'll notice a dramatic change in airflow from the vents.
well the idea is that you buy a home airconditioning filter. cut it into the shape of our car filter, and slide it in place of the stock filter (if you can even call it that). you'll notice the air smells betters, and a higher rate of flow.
plus if you have allergies, i can imagine how much this could help. very good diy.
http://www.safetygears.net |
great stuff! very good DIY....
1st car - Honda Legend G1 (2.0 V6) -SOLD 2nd car - Honda Legend G2 - SOLD Changes I have made so far: - Koni Special Shock Absorber & Spring - E-Power2 Voltage stabilizer & Splitfire ground wire - 17" Advanti Rim + 215/45/17 Michelin Pilot Perceda 2 - Sound Insolation + Pioneer DEH-7750 CD Player & PLC speakers - K&N Air-Filter - Dual Exhaust Pipe (Brabus) - Acura Emblem - JDM Headlight (Black housing) + HID Philip 4,300K Now 3rd & 4th car - Honda Accord Exi 2.0 & Mazda RX-8 |
Mr. Hard to Find!
Ummm, I think I heard somewhere that the 91 and 92 model years didn't have a cabin filter. I hope that is wrong cause I would love to put a micro allergen filter in mine.
Thank You, L. Downes O-Town Legends C.C. Winter Haven, FL _______________________ Forum Rules Tapped (Term used mainly in New England) = Crazy + Stupid Contact me at: otown_legends_cc@yahoo.com |
#9 (permalink) | |
Don
if you leave the settings on recirculate, orange light, would you need a cabin filter? it looks like the cabin filter only keeps leaves and sticks from entering the vents from the outside. if you use inside air, wouldn't a filter just slow down how much air passes through the vents? im trying to understand the airflow system, i took out my old cabin filter last night, and will put a new one in tonite, i used to ac today, and it seemed like more air flowed through the vents without the filter in the way
James |
#11 (permalink) | |
Mr. Hard to Find!
With this new job I just got I'm planning on installing a brand new A/C system in the car. I previously removed the entire system due to a bad compressor and leaking evaporator core. But now I'll have the money to get the parts and repair it.
#12 (permalink) | |
| A/C Cabin filter change/removal tutorial w/ pics. | Flounder | DIYs | 62 | 10-12-08 03:06 PM |
| OEM Cabin Air Filter Replacement with NON Oem Filter | Mtnduey | DIYs | 23 | 12-17-07 10:41 AM |
| RL cabin air filter replacement DIY (56k beware) | jinny | First Generation RL (1996-2004) | 19 | 09-02-06 02:09 PM |
| DIY: How To Change Cabin Filter | ZiggyB | DIYs | 16 | 03-04-05 04:42 AM |
| A/C filter and Cabin filter. | nqk7111 | Second Generation Legend (1991-1995) | 1 | 04-17-03 02:02 AM |
