DIY - EGR Removal Pics - Page 3 - The Acura Legend & Acura RL Forum
Old 10-29-07, 09:22 PM   #31 (permalink)
Black Type II's Avatar
Car 1: Carless
this is great now i can take on my type r badging i hope this takes care of my sluggish or lagging on full throttle. and this would also help on some slight engine vibrations? this is after i had done an oil change, spark plugs, oil stabilizer. i will still go ahead and clean the egr valve but if this doesnt work i will go ahead and check the packs
1995 Milano Red LS 6SPD where are you?
Black Type II is offline   Reply With Quote
Old 11-27-07, 11:46 PM   #32 (permalink)
Car 1: 94 Legend Coupe LS 6MT (Milano)
Car 2: 93 Legend Coupe LS
Car 3: 92 Legend Coupe LS
iTrader Score: 6 reviews
Hey guys does cleaning the EGR valve improve fuel economy? Hope this is relevant, I've been looking through the egr articles but there's not much info. Thanks
MXHalofan is offline   Reply With Quote
Old 12-03-07, 06:54 PM   #33 (permalink)
238Klegend95
Car 1: Legend 95 LS
Clogged EGR pipe ===> High NOx??? HELP
I'm a new member. I would appreciate greatly any advice on my Legend 95 LS failing VA Emission test. The test shows very high NOx (almost 2000). My mechanic suggested the following:
1) Clean the EGR - I did. He did not clean the EGR pipe yet
2) Use 10-40w oil (instead of 5-30w)and add one Anti-smoke can. I did as he suggested
The result is the NOx level went down to 1400+. I still fail the test.
Does cleaning the EGR pipe help with the NOx result? I will ask the mechanic to take apart the EGR and EGR pipe to do a good cleaning if this helps. Thanks1
PS: my 95 Acura Legend has 238K miles, never have EGR cleaned.
iwaylegend95 is offline   Reply With Quote
Old 12-04-07, 07:35 AM   #34 (permalink)
Car 1: Carless
235 and its never been done i would do it anyway
Old 12-04-07, 08:23 AM   #35 (permalink)
238Klegend95
Car 1: Legend 95 LS
Smile
Black Type II,
Thank you for your reply! Does it harm the engine if I'm using 10-40W oil instead of 5-30W oil?
Old 12-04-07, 08:52 AM   #36 (permalink)
Hey were you guys able to get an air rachet on the nuts holding this EGR together or did you have to get the racheting wrenches in there? I'm going to try today thought I'd check thanks alot
Old 12-04-07, 12:45 PM   #37 (permalink)
Originally Posted by iwaylegend95 View Post
Black Type II,
I'm no expert but I think the heavier oil will lube fine except for very cold temps, I am using 10 40 in mine and the car runs great, even around 25 degrees so far, no dry starts from what I can tell.
The heavier oil will help the oil seals and rings do their job and thus the reduction in emissions, the lighter oil will reduce friction and thus better MPG
I'm sure there's a little more to it with this engine, but what I've heard is if you're high miles and smoking abit it's good to go 10 30 or 40
Old 12-04-07, 04:17 PM   #38 (permalink)
238Klegend95
Car 1: Legend 95 LS
Smile
MXHalofan,
Thanks for your reply.
My car cannot pass the VA emission test. The mechanic thinks it's the engine valve seal. It's going to cost me lots of $$$ to fix. He think I should replace the engine with a low-mileage used engine. The labor will be much less. Any advice? Thanks!
Old 12-05-07, 03:18 AM   #39 (permalink)
Car 1: Carless
MXHalofan,
if u do an engine swap go get a 3.5
Old 06-25-09, 01:19 AM   #40 (permalink)
spcgloc13's Avatar
Car 1: Acura Legend 94 GS
Car 2: Acura TSX 05
This was a mother F&*#er to do. But thanks for the DIY because I would have been lost on trying to fix this thing. I recommend cleaning out all parts as you have mentioned and the check engine light will come off and the damn engine (at least for me) runs with more freaken power!!! Once again thanks for DIY!!
sittin sideways!
spcgloc13 is offline   Reply With Quote
Old 07-16-09, 09:18 PM   #41 (permalink)
MagicMikey's Avatar
Car 1: '91 LS Sedan
Send a message via MSN to MagicMikey
What can you use to fully clean inside the pipe? other than passing a pipe cleaner.
1991 Acura Legend LS Sedan
Granada Black
MagicMikey is offline   Reply With Quote
Old 07-17-09, 04:59 AM   #42 (permalink)
Factory Freak!
92drls's Avatar
Car 1: VGM KA8 5SP
Car 2: Downhill MTB
^^^^^^^^ I went to a local ACE hardware and got a really skinny pipe cleaner and some carb cleaner. Will prolly need to use the whole bottle of cleaner and some elbow grease in there. Once it gets soaked in and worked out it should come out in chunks. Have fun!
92drls is offline   Reply With Quote
Old 03-29-12, 10:17 PM   #43 (permalink)
Chico's Avatar
Car 1: 1991 Acura Legend LS
do you use a brake cleaner for that?
Chico is offline   Reply With Quote
Old 01-25-13, 11:56 PM   #44 (permalink)
Car 1: 2005 Acura TL
Thank you DIY and Ballistic for this post! My idle started running rough and sputtering earlier this week so I took it the dealer. They ran diagnostics on her ($60) and determined it was the EGR Valve that needed replacing and their price was $430!!!!
After doing a little research on it I decided that there was no way in 'H' I was going to pay that much money for something that seemed like a simple fix and decided I could do it on my own. I have a 2005 TL so things looked slightly different under the hood but not so different that I couldn't figure it out. I bought the part for $75 and replaced it in about 2 hours start to finish including cleaning the IM which was hardly dirty. The nuts were the only part that I needed a mans help to remove but other than that it was a cinch!
TLGRL is offline   Reply With Quote
EGR repair update stoporder First Generation Legend (1986-1990) 74 04-27-05 12:39 AM
Clogged Honda EGR Port - Honda Techs? Uncle Stinky The Lounge 5 03-22-05 11:09 AM
Panel removal pics CHABABY Second Generation Legend (1991-1995) 3 02-21-04 12:28 PM
Pics of a bumper install and removal? brooklyn legend Second Generation Legend (1991-1995) 4 01-27-04 09:42 AM
