DIY: G1 Steering Rack Removal - The Acura Legend & Acura RL Forum
Old 04-10-07, 06:16 AM   #1 (permalink)
Mabuhay...
pnoye2's Avatar
Arrow DIY: G1 Steering Rack Removal
I can't post this in DIY section... I'm NOT allowed, so here goes!
If I can do it, anybody can do it… I believe the key to a successful DIY’er is to have proper set of tools. Please protect yourself at all times and use some precautions when you crawl under any vehicle.
Safety equipment:
Floor jack
Jack stands
Wheel chocks
Oil drip pan
Creeper (card board will do)
Disposable rags
Knee pads
Safety glasses
Latex gloves (it’s going be messy)
Basic hand tools required:
Medium size needle nose pliers
Medium size wire cutter
” drive torque wrench (or a breaker bar)
” drive 19mm deep socket
3/8” drive ratchet
3/8” drive 6” extension
3/8” drive sockets; 17mm, 14mm and 10mm
Wrench; 19mm, 17mm, 14mm, 12mm and 10mm
Medium and small size adjustable wrench (as an option)
Tie rod ends removal or equivalent
Rubber mallet
Prep work:
1)Place wheel chocks in front and back of one of the rear tire.
2)Pop the hood up and open power steering reservoir (helps relieve the fluid out)
3)Loosen front wheels by using ” drive 19mm deep socket and a torque wrench (or a breaker bar).
4)Raise the front end and safely support the vehicle.
5)Remove wheels out and let the fun begin.
Removal sequence prior to the steering rack; work on one side first (same steps and procedures applies for the other side)
( I ) Tie rod end removal from the steering knuckle:
a)Unbend the two ends of the cutter pin with a needle nose pliers, pinch the opposite end and pull it out (wire cutter is more effective).
b)Unscrew the tie rod end ball joint castle nut halfway.
c)Break tie rod end ball joint loose using a tie rod end removal tool or equivalent.
d)Remove the castle nut and lift the tie rod end out from the steering knuckle.
( II ) Tie rod end removal from the inner tie rod:
a)Use 19mm wrench for the locking nut.
b)Use 17mm wrench for the tie rod end.
c)Place both wrench opposing each other (not too far apart).
d)Squeeze both wrenches to free up locking nut.
e)Unscrew tie rod end.
( III ) Inner tie rod removal from the steering rack:
a)Use 19mm wrench and securely place on notched lock washer.
b)Tap slightly with a rubber mallet to break it loose.
c)Unscrew inner tie rod.
( IV ) Steering rack removal:
a)Remove center beam bolts (8 total) and the beam, use 3/8” drive ratchet, 14mm socket and the 6” extension.
b)Remove gearbox shield bolts (4 total) and the shield to expose the rack, use 3/8” drive ratchet, 10mm socket and the 6” extension.
c)Place a drip pan underneath the gearbox, disconnect the 4 lines from the control unit and let it drip out for a few minutes (I’d use a small adjustable wrench).
d)Use plastic wrap to protect them lines from dirt or debris.
e)Remove rack mounting bolts (4 total) and holders, use 3/8” drive ratchet, 14mm socket and the 6” extension.
f)To expose the steering joint cover, you’d need to pull down the carpeting on the driver side foot well.
g)Unscrew the 3 flat and round plastic tabs and remove the cover.
h)Remove the steering joint bolt (bottom), use a 10mm wrench.
i)Once removed, cover gearbox with disposable rag to prevent squirting of power steering fluid all over the place.
j)For more maneuverability, slide the rack all the way to the right side.
k)Slide gearbox to the right and maneuver slowly to remove.
Oh, I almost forgot... to install, reverse the removal procedure!
I apologize for not having images attach along with the descriptions, the digicam I use to snap photos with was taken along for a spring break vacation by my daughter. I will revise this DIY with pictures as soon as she gets back, sorry for any inconvenience.
Judge Judy to prostitute: So when did you realize you were raped?!?
Prostitute wiping away tears: When the cheque bounced!?!
Tony (BDAZZGI) auto repair shop!
Old 04-10-07, 07:32 AM   #2 (permalink)
Battle! Champion, Big Uglies Champion
murderotica's Avatar
Car 1: '87 CA5 turbo
Car 2: '90 KA4 beast
Very thorough, pnoye!
Can't wait until you have corresponding pictures for this.
Nice work.
[CENTER]
murderotica is offline   Reply With Quote
Old 04-10-07, 12:30 PM   #3 (permalink)
because i can.
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Car 3: '03 Infiniti I35
iTrader Score: 14 reviews
Thanks Ferjie! Great work as always!
BTW Ive copied it to the DIY section...
Old 04-17-08, 03:00 AM   #4 (permalink)
Gangstar* User
Dance4Zak's Avatar
Car 1: 93 Legend Sedan *R.I.P
iTrader Score: 4 reviews
Send a message via AIM to Dance4Zak Send a message via Yahoo to Dance4Zak
Did you have a problem with your steering wheel not being straight when you finished the install ??
because my steering wheel will not get straight and I dont know what to do
or how to fix it =///
Dance4Zak is offline   Reply With Quote
Old 04-17-08, 01:53 PM   #5 (permalink)
Mabuhay...
pnoye2's Avatar
or how to fix it.
^^^ This can be easily address by disconnecting/removing the steering joint then re-position steering wheel to NORMAL location.
Very important pre-cautionary measure: Avoid over turning the steering wheel... doing so WILL compromise ALL convenience functions such as CC, horns, etc., etc.
PM me if you'd need further assistance on this issue... goodluck my friend
Steering Wheel Removal ! MikeD DIYs 11 06-03-10 12:20 AM
Acura-Legend.com/Acura-RL.com needs your help with making an official archive Mike Diaz Second Generation Legend (1991-1995) 23 12-02-09 11:29 AM
DIY: REVISED Steering Rack removal... G1 specific pnoye2 First Generation Legend (1986-1990) 5 04-10-07 02:03 PM
Steering Rack or tie rods or both?? MoisTiCaL Second Generation Legend (1991-1995) 9 02-17-07 07:32 PM
Steering rack upgrade. ssilk Engine & Performance Modifications 10 04-11-06 01:54 AM
